Brake pedal almost goes to floor to stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luke090, Mar 1, 2018.
  1. Mar 1, 2018 at 8:57 PM
    Luke090
    Luke090 [OP] Member
    Luke
    2007 tacoma pre runner
    magnaflow muffler
    Recently my brakes on my 2007 Tacoma pre runner, have been getting worse and worse. I’ve checked the, master cylinder, lines, pads, rotors, and everything is good. Bled all the air out of the lines. No leakes in the brake system. My brakes just aren't stopping as good as they used to. And I almost have to push the pedal to the floor to stop. I don’t know what else it could be.
    Any input is greatly appreciated.
  2. Mar 1, 2018 at 10:31 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    The brake booster or master cylinder might be going out. Look around there and make sure the vacuum hoses going to the booster are good.
  3. Mar 1, 2018 at 11:10 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    adjust the rear shoes
  4. Mar 1, 2018 at 11:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is a good place to start.
    ADJUST REAR DRUM BRAKE SHOE CLEARANCE
    (a) Provisionally install the hub nuts.
    (b) Remove the hole plug, and turn the adjuster to expand the shoe until the drum locks.
    (c) Using a screwdriver, release the adjuster 15 notches.
    (d) Install the hole plug.
    Micbt25, Aw9d, Sandman614 and 4 others like this.
  5. Mar 2, 2018 at 4:17 AM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    Brake booster and master cylinder are all good.
    JDawg562[QUOTED] likes this.
  6. Mar 2, 2018 at 4:20 AM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    I’ll give it a shot. If this doesn’t help is there anything else it could be?
  7. Mar 2, 2018 at 4:46 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    If the brake booster and master cylinder are all good and you are positive there is no air in the system. I don't know other than the adjustment of the rear brakes.
    TexasWhiteIce likes this.
  8. Mar 2, 2018 at 6:33 AM
    Pigpen
    Northwest Montana
    When you bled the air out, did you replace all of the fluid? Old brake fluid will absorb moisture. Under pressure that moisture turns to vapor, which compresses. This could easily be your problem.
    PzTank likes this.
  9. Mar 2, 2018 at 6:45 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    First, how do you know the master cylinder is good? Did it tell you so?
    If in fact the master cylinder is fine, rear shoe adjustment is correct, a faulty ABS module WILL also cause excessive brake pedal travel.
    Oh, and I see you said nothing about the condition of the rear brake shoes or wheel cylinders, pull the drums, check the shoes, and pull back the boot on the wheel cylinders (each side) and look for fluid leaks.
    blu92in99 and PzTank like this.
  10. Mar 2, 2018 at 8:18 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Based on what you've described, the Master Cylinder is most likely suspect. Just because it doesn't show signs of leaks doesn't mean it's good. I'm not sure how you determined that it was good, but the seals and or valving are probably bad. If everything else in the system appears fine, the master cylinder would be the first thing I would change. It's the most common reason for mushy feeling brakes and or the pedal going to the floor.
    desertrunner24 and JDawg562 like this.
  11. Mar 2, 2018 at 8:23 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    I had to replace my master cylinder once; $1,200...
  12. Mar 2, 2018 at 8:39 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    X2 it's the master or the booster. Not sure how you determine those are "good" with a spongy pedal, especially if you've gotten all the air out of the system like you say.
    Try rear brake adjustment, try bleeding one more time, if not it pretty much has to be the master...have you checked all the lines for leaks?
  13. Mar 2, 2018 at 9:19 AM
    Pigpen
    Northwest Montana
    Start simple. Do a full fluid flush and adjust the rear brakes. Even if you've used the parking brake every day, there's a chance the self-adjustment is off. If you don't use your parking brake every day, they aren't self-adjusting.
    If those two things don't do it, then look into diagnosing the MC and booster. But adjusting the rear brakes and flushing the fluid are normal maintenance you should be doing anyway.
    blu92in99 likes this.
  14. Mar 2, 2018 at 10:34 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Have you looked at the rubber brake lines? They can get soft and expand with pressure giving a soft feeling pedal. Worn / slack rear shoes are most likely for a low pedal though. Our NYS inspection station flagged the soft lines on an 06 BMW for cracks and deterioration,but no leaks. We replaced them with some kind of red colored braided steel aftermarket lines and the pedal feel was much better.
    blu92in99 and taco2010trd like this.
  15. Mar 2, 2018 at 11:35 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Agreed with adjusting the rear brakes first. Then, if that doesn't correct the problem...
    Pinch off the rubber brake hoses going to each wheel. If pedal feel is restored, then the issue is at one of the wheels. Remove the clamp, one wheel at a time, rechecking pedal feel each time. When you remove a clamp and the pedal feel goes to shit; that's your suspect.
    If pinching off all four hoses does not restore the brake pedal; then the problem is upstream; either master cylinder or ABS unit. You can plug off the ports to the master cylinder; same results expected - if pedal feel is restored, then the issue is in the ABS unit. If pedal feel is still low/spongy, the problem is the master cylinder.
    Don't use vice grips or pliers to pinch off the lines. They make clamps just for brake hoses: https://www.amazon.com/Lisle-22850-Hose-Pincher/dp/B0002NYB78
    Let us know what you find.
    stickyTaco and Jeffs68 like this.
  16. Mar 2, 2018 at 12:15 PM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    I took of the lines running to the master cylinder and screwed in caps and pushed on the brake pedal and it stayed firm, and didn’t sink.
  17. Mar 2, 2018 at 12:16 PM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    I have metal brake lines, and no kinks in them. I readjusted the rear brakes and that seems to have helped a little. My next move is to completely flush out the old fluid with new.
  18. Mar 2, 2018 at 12:20 PM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    Replaced shoes 15k ago looked at them today and they are fine.
  19. Mar 2, 2018 at 12:23 PM
    Luke090
    Luke090 [OP] Member
    Luke
    magnaflow muffler
    I checked master cylinder by screwing in caps, to where the lines go into the cylinder. Next I pushed on the brake pedal, didn’t sink at all and was very firm. Booster can’t be bad cause if I pump up my brakes while the car is off, and then hold the pedal down while I turn on the car the pedal goes down easy
  20. Mar 2, 2018 at 12:24 PM
    blu92in99
    Elk Grove, Ca
    There is a rubber hose at each caliper and two at the rear axle (one for each wheel cylinder). If there wasn't, those metal pipes would break from flexing.
    I thought you already flushed the fluid? Nope, re-read and saw you just bled the system. Flush it and see where you're at.
