Brake Pads. Semi-metallic vs. ceramic?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TAC0MAMA, Nov 29, 2017.
  1. Nov 29, 2017 at 7:39 AM
    TAC0MAMA
    TAC0MAMA [OP] Well-Known Member
    Southern New Hampshire
    2010 Toyota Tacoma TRD
    So I’ve owned my taco for a few months now and last time I went to the shop, they told me the brakes are quite low. Looking at new pads I see the option between semi-metallic and ceramic. I’ve only looked on rock auto so far so I’m not sure which brand is best. I’ve seen the pros and cons of each but I’m still unsure. The ceramics don’t seem that much more expensive. I do live in Vermont which gets to negative temperatures in the winter. I don’t really tow anything and it’s just a daily driver. I’m not sure if that makes a difference. Also which rotors should I be looking at? The truck has 160k so should I think about replacing fluid? That’s for the advice!
  2. Nov 29, 2017 at 7:45 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You'll likely want ceramic pads and OEM rotors or Brembo rotors.
    gthupman likes this.
  3. Nov 29, 2017 at 7:46 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    regular daily driving I would use the OEM ceramic pads, cost effective,no dust, and get the job done. if I was heavy hauling trailering I would go with the more costlier OEM semi metallic pads for a slightly better bite
  4. Nov 29, 2017 at 8:07 AM
    TAC0MAMA
    Where do I find OEM pads?
  5. Nov 29, 2017 at 8:17 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    I have always had great luck with CENTRIC High Carbon Alloy Brake Rotors. As for pads, Hawk - Centric - Advics
    TAC0MAMA[OP] likes this.
  6. Nov 29, 2017 at 11:25 AM
    TaCoJoE650
    TaCoJoE650 Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Ceramic are quiter/less dust/softer
    Downside is they wear faster.
    Semi-Metallic are harder on rotors and more likely to warp. OEM for the win :yay:
  7. Nov 29, 2017 at 11:28 AM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    isn't it believed that centric makes the oem rotors?
    i've had the best luck with stock rotors (from toyota or centric) and akebono ceramic pads or oem pads
    i tried a few hawk trailering and performance pads that were semi-metallic and they abused rotors and warped them every time
  8. Nov 29, 2017 at 11:31 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I've always had fine luck with parts store brake pads and rotors. I normally get ceramic so that noise and dust is minimal.
    TAC0MAMA[OP] and gthupman like this.
  9. Nov 29, 2017 at 11:33 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  10. Nov 29, 2017 at 11:42 AM
    TAC0MAMA
    Good advice guys. Thanks. How about the rear brakes? Is it just the shoes I need to replace? I’m new to all of this although in my old jeep I had to replace the springs and everything in the drum. How hard is it to get in there and replace the shoes, granted that’s all I need to do?
  11. Nov 29, 2017 at 11:43 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    @gunny1005 for the best price around TW! :thumbsup:
    gunny1005 likes this.
  12. Dec 5, 2017 at 10:03 AM
    TAC0MAMA
    So does anyone have an opinion? Should I replace shoes, hardware, and drums? Do I need to inspect first or since I have 160k should I replace everything? Or just shoes? I’m new to all of this so anything helps. Thanks.
  13. Dec 5, 2017 at 10:05 AM
    vettehigh
    Jon
    Upstate, NY
    Would do all complete if needed
  14. Dec 5, 2017 at 12:13 PM
    cruiserguy
    Elijah
    SEKS
    Many here have found their rear brake shoes still with plenty of life left once they pulled the drum off. If I was in your shoes, I think I'd pull the drum and inspect before ordering anything for the rears.
  15. Dec 5, 2017 at 12:17 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'd pull the drums and see what you get. Even though you have 160k it's possible they don't need to be done, and since it's kind of a pain in the ass you don't want to do it if you don't need to. Pro tip: if you can't pull get the drum off, the bolt holding on the E-brake cable bracket is right there under your nose and is just the right size to thread in the little hole and force off the drum.
    Nice...
    Romaneo and cruiserguy[QUOTED] like this.
