Brake pads recommended
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hgiljr, Jun 16, 2020.
  1. Jun 17, 2020 at 11:00 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I’ve had no long term luck turning rotors. They’re cheap, replace them and be done. OEM pads are good, but I’ve really been liking the Napa Ultra Premium coated rotors and Adaptive One pads. I put a front set on my 07 Tacoma after two OEM sets (no longer own) and recently a front and rear set on my sisters 05 Trailblazer. In both cases the braking has been better than OEM, in my opinion. The Adaptive One pads are ceramic, so the OEM semi metallic pads are a better option if you are towing a lot.
    Whatever pad you go with, I highly recommend the Ultra Premium Rotors. They have a guaranteed lateral run out of less than two thousandths. There other good rotors out there, but I keep going back to these. I have nothing but good things to say so far.
    https://www.napabrakes.com/products/rotors/ultra-premium.html
  2. Jun 18, 2020 at 4:15 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    .002" is not a very tight tolerance for run-out. Radially it would be but laterally it is not. I wonder if they meant to say two tenths (.0002)?
  3. Jun 18, 2020 at 4:19 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    70K miles on OEM pads and looking at same on 2nd set. Can't beat that IMO.
  4. Jun 18, 2020 at 4:28 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Akebono ProAct ceramic pads paired with Brembo blank rotors on my truck. Barely any noticeable pad wear at 20k miles, and it stops way better than stock.
    Micbt25 likes this.
  5. Jun 18, 2020 at 5:22 AM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Idk, but they’re priced in line with OEM rotors and look better (being coated) for longer. Like I said, I’ve had no issues with them so far. Most of the cheaper rotors on Rockauto say 4 thousandths or less, if they give a spec at all. Most people and shops pay no attention to runout, they just slap new pads/rotors on with whatever’s cheap and send them out the door.
  6. Jun 18, 2020 at 5:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I find OEM to be the best compromise for performance, noise, dust, and durability. However, unless you see large foreign debris embedded in the pad material, your vibrations typically aren't caused by the pads.
    My own experience across three vehicles (two Tacomas and a Subaru):
    Akebono (AST and ASP models) - noticeably reduced initial bite, feels as if the truck isn't stopping, quiet and dust-free, good corrosion resistance
    Hawk HPS Street - similar performance, quietness, and dusting as OEM, but backing plate gets rusty after just two years
    Centric Posi-quiet ceramic - similar performance, quietness, and dusting as OEM, but backing plate gets rusty after just two years
    For rotors I would go with OEM, Centric Premium, or StopTech (which is made by Centric). StopTech slotted rotors clean better if you go off-road and drive through mud.
  7. Jun 18, 2020 at 6:15 AM
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    Had Hawk (SUV/LT) pads on my 07, and now on the 2015 with EBC black-coated rotors. Amazing pads No fade, really nice bite and no noise..
  8. Jun 18, 2020 at 8:08 AM
    tshuldd
    tshuldd Active Member
    Taylor
    Western MA
    2010 AC Tacoma 4x4
    I replaced mine with OEM rotors and TRD pads, would definitely go with this setup again. Noticeably improved bite with the TRD pads. I replaced all of the caliper pins at the same time as well.
  9. Jan 31, 2021 at 3:51 PM
    hgiljr
    hgiljr [OP] Well-Known Member
    Do the 2015 TRD model pads fit on the non TRD model? Anyone with a 2015 done such upgrade? Thanks
  10. Feb 1, 2021 at 1:18 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Should work just fine. I’ve heard the trd pads produce more dust tho. I’ve never tried them myself.
  11. Feb 1, 2021 at 2:29 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Lots more dust.
  12. Feb 1, 2021 at 2:43 PM
    gasgasman
    gasgasman Well-Known Member
    I have the EBC pads. Pedal feel and stopping is way better than stock. But, brake dust is horrible.
  13. Feb 4, 2021 at 7:29 AM
    tshuldd
    Taylor
    Western MA
    2010 AC Tacoma 4x4
    As others have said they should fit. Here's a link to the fitment guide I referenced: https://www.liaparts.com/oem-parts/toyota-trd-brake-pads-ptr0989111
    I also noticed more dust but the improved bite was worth it.
