Brake pads recommended
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hgiljr, Jun 16, 2020.
  1. Jun 16, 2020 at 5:28 PM
    hgiljr
    hgiljr [OP] Well-Known Member
    Hello all. I have done some reading on this forum regarding brake pads and see several recommendations. I’m looking at replacing my OEM pads after 37k on them. I only do daily driving, no towing or off roading. Should I go with OEM, EBC or another brand? Just looking at replacing pads not rotors. Any guidance appreciated. Thanks
  2. Jun 16, 2020 at 6:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just because?
  3. Jun 16, 2020 at 6:20 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    37,000 miles is pretty early for front pads. Are you sure they're actually shot?
    Naveronski and Island Cruiser like this.
  4. Jun 16, 2020 at 6:22 PM
    hgiljr
    They are beginning to vibrate when braking at high speeds.
  5. Jun 16, 2020 at 6:33 PM
    Too Stroked
    Tom
    That would be the rotors, not the pads. That said, when you replace the rotors, you need to replace the pads. I'm a huge fan of OEM brake parts for any Japanese vehicle if you want my 2 cents. Beware of cheap Chinese "white box" rotors and / or "high performance" pads. The cheap rotors will wear out / warp in very short order and many high performance pads dust like no tomorrow.
    Rick's 2012 and durtkillon like this.
  6. Jun 16, 2020 at 6:34 PM
    durtkillon
    durtkillon Well-Known Member
    Kurt
    Fort Collins, CO
    2010DCLBV64X45SPAT 1E7 BASE
    Sickest Mod: Synthetic Oil
    It's worth investigating why. Vibrations are usually due to warped or thin rotors, not pads. The OEM stuff is very good quality and don't squeal. How many miles on the rotors? Do you tow or haul heavy stuff?
    Naveronski likes this.
  7. Jun 16, 2020 at 6:35 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Factory pads are the best.
  8. Jun 16, 2020 at 6:36 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    When mine started vibrating I replaced them with stoptech cryo slotted rotors and toyota trd pads.
  9. Jun 16, 2020 at 6:43 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Rotors don't actually warp. The vibration under braking is usually due to uneven transfer layer deposits on the surface of the rotor. This commonly happens from heating the pad/rotor to or over the working temp range and then sitting stationery with pressure on the brakes. Like an emergency stop from a high speed and then holding the brakes after coming to a complete stop. If it's not excessive, going through a bedding procedure can sometimes remedy the uneven layer. I've had vibration in the brakes on my beater car after it sits for extended periods of time and a corrosion layer develops but a couple miles of driving and a firm stop or two cleans it up. Going through a bedding procedure, if safe to do, might save you some $ if the pads and rotors are otherwise in good shape.
  10. Jun 16, 2020 at 7:20 PM
    hgiljr
    37k miles. No towing or haul heavy stuff. Just regular daily driver. I have had to stop at times heavy. I will try bedding first and tho from there.
    Jimmyh likes this.
  11. Jun 16, 2020 at 7:51 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    I bought TRD pads and they throw dust like crazy. They may work well but I won't be installing them next time.
  12. Jun 17, 2020 at 12:43 AM
    TacoTuesday1
    FL
    first off, 37k miles is not an indication of anything, pad depth is
    that's why you stick your head in the wheel to look how much millimeter thickness the pad has
    second, if you have access to a lathe, the warp can be cut out of the factory rotor for as cheap as free
    which may then end up warping again later on because supposedly Toyota spec'd it too small of a size from factory
    but hey, your money. If you want to drop $200+ on new pads and rotors when your stock ones have life left, only for the new ones to end up doing the same exact thing, go ahead.
    pad slaps are often done to save money, keeping note of their thickness to not end up on a worn rotor and worn pad that can allow the caliper piston to pop out with that extra room.
    That being said, functionally speaking, whether cutting the rotor to a fresh new surface when replacing pads or not, it will still technically work as a brake from the hydraulic force making the pad squeeze the rotor, regardless of it's condition, during average driving
    factory pads come in ceramic or semi-metallic, this post doesn't really specify
  13. Jun 17, 2020 at 8:43 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    We have an 07 HHR we bought new and at this point in time has very low miles for the year, my wife's car, and just after warranty, the front end started to shake when braking. When I would drive it, after a few miles the shake would subside but, never really go away. Well, my wife drives with her left foot on the brake, never enough to trigger the brake light, and right foot on the accelerator so you can imagine what's happening to the rotors. I attributed it to so-called warped rotors. Because I can't convince her to keep her left foot off the brake when not needed, I refused to do anything with the brakes until the pads wore out. It's one reason I don't want her driving my Tacoma or any other vehicle that's my main use. At 41,000, the pads finally failed and I put new rotors and pads on. It drives and brakes like a new car and we may keep it a while longer and because she drives it very little now, (retired) and only short distance the shake hasn't yet come back.
  14. Jun 17, 2020 at 9:09 AM
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    Not entirely the wife's fault. Its actually a well know issue with HHRs. GM even admitted that the rotors fitted to these cars were simply too small to effectively shed the heat generated from normal brake operation, made worse if the driver tends to have a heavy braking foot. Typical GM en-jun-nearing.
    As for OP, I have to agree with TacoTuesday1 that mileage is not the best indicator for brake wear. Lots of other factors can lead to premature pad wear or warping. Find an old school shop that still actually turns brakes and have em turned, through some new OEM pads on it and your probably good for another 37k miles.
  15. Jun 17, 2020 at 9:14 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I love my stoptech sport pads buts after a long trip my bronze wheels turn black, kind of annoying but they grip well.
  16. Jun 17, 2020 at 9:32 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    1 year+ on my Carquest/Wearever Premium Ceramic pads + Stoptech basic-rotors, and new OEM piston seals. Stops just as well/quickly as the TRD Pads in street use. Wheels stay clean too. Best $130 brake job ever.
  17. Jun 17, 2020 at 9:33 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    Pull the calipers off and clean and grease the slide pins before you drop money on rotors and pads.
  18. Jun 17, 2020 at 10:21 AM
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    I'm at 94k on the OEM pads...I think I'll go OEM again.
    Jimmyh likes this.
  19. Jun 17, 2020 at 3:08 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    This should be done, for inspection at the least, every time the brakes are touched. I find a stuck pin every few times I mess with brakes on any of my vehicles. Stuck as far as I couldn't slide it easily with my hand. Pulling it out with pliers and a fresh coat of high temp silicone grease or brake lube has always made it nice and buttery smooth. 2 minutes of work for insurance that a caliper won't stick.
    Greg.Brakes.Tacos and TOMB like this.
  20. Jun 17, 2020 at 4:17 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Have the rotors turned.. and go back with a fresh set of oem pads... and then bed them in properly.
