Brake pad tabs important?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Jan 19, 2019.
  1. Jan 19, 2019 at 4:03 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Mine was snapped off brand new. I’ll certainly never buy aftermarket pads again. But can I use these?
  2. Jan 19, 2019 at 4:37 PM
    beikokupilot
    beikokupilot Well-Known Member
    Utah
    1997 Red Tacoma 4WD
    Power steering pump, Steering rack, Tie rods, Radiator cap, Thermostat, New radiator, magnets to hold the fuel door closed, new starter drum/cylinder, dash lights changed to red, replaced all carpet in the cab. Not real “mods”, but all work
    If you bought them at autozone they should have a lifetime warranty
  3. Jan 19, 2019 at 4:39 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Where did you get them? What brand are they?
    beikokupilot likes this.
  4. Jan 19, 2019 at 6:12 PM
    pontoon
    Centric off of Amazon. I realized those are the wear indicators. They would squeal when the pads are worn. Nice but not mandatory in my opinion so I’m going with it.
    Centric pads are garbage. This wasn’t the only issue. Pin wouldn’t go thru due to misaligned backing plate.
  5. Jan 19, 2019 at 9:09 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Yeah I wouldnt worry about the squealer if you watch the mileage your putting on them. Beat pads on Amazon are Akebono Pro-Act Ceramics. Wouldnt touch any other brand after trying them. If you wanna buy local, Napa Premium Ceramics would be my first choice. All of the duralast and Oreilly brakes are made by Bosch last I read, and Ive never been a bosch fan outside of wiper blades.
  6. Jan 22, 2019 at 5:21 AM
    1997tacomav6
    Denver
    You might want to consider making sure you have the OEM shim plates that tend to get lost over years.
    When I reinstalled these shims my brakes worked better and didn’t have any warping issues.
    Believe it or not these made a big difference for me.
    pontoon[OP] likes this.
  7. Jan 22, 2019 at 7:55 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Some people just drive and never do maintenance
    1997tacomav6 likes this.
  8. Jan 22, 2019 at 9:12 PM
    pontoon
    Huh, good tip. My shim pads were missing. Whatever "mechanics" worked on my truck before I owned it messed up a lot of things. I've found sheared off bolts, broken wiring harness clips, loose bolts, clutch pedal bracket nearly falling off, etc.
  9. Jan 27, 2019 at 7:02 PM
    pontoon
    So after installing I realized by snipping the misaligned shim, it would allow the shim to rotate out of place if the backing shim were to come unglued. I don't want anything in my brakes moving out of place, given that a brake lockup could be fatal. I decided to buy another set of pads and redo the job.
    STAY AWAY FROM CENTRIC!!! The company produces a low quality product and doesn't stand behind the product either. I had a horrible experience on the phone with customer support.
    This is a product where the pads are hand glued. The company confirmed my suspicions about this. I now have 8 samples to look at, and I can see that none of them are perfect. Some of them are acceptable. Some of them are unsafe in my opinion. Should I, a layman, be required to tell the difference between safe and unsafe? I'm not an engineer and just have my unintelligent eyeballs to evaluate with. The long and short of it, stick with OEM. And stay away from Centric.
  10. Jan 27, 2019 at 7:16 PM
    1997tacomav6
    Denver
    I have had excellent luck with EBC pads, much better than OEM
    EBC Green Stuff 7000 Series For 1997 Toyota Tacoma DP7807
