Brake Override Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProjectTgen3, Jul 19, 2017.
  1. Jul 20, 2017 at 4:52 PM
    #81
    ProjectTgen3
    ProjectTgen3 [OP] Well-Known Member
    Keandrew
    Pennsylvania
    2016 Super White Tacoma TRD Off-Road
    Bilstein 5100 with OME Lift Springs Fox Performance rear 2.0 shocks DX4 Tuff wheels 17x8.5 -6 Falken Wildpeak A/T3W 285/70/17 RCI Rock Sliders
    Like a hundred bucks which isn't bad for like 3 hours being there. I paid for it be a use it was my mistake for plugging the tails incorrectly or at least making sure everything lined up wire wise. But then again I'm glad because now the 2nd fuse that was missing is all good now. Will post pics of the final build so far. Did a photo shoot today as well
  2. Jul 20, 2017 at 5:10 PM
    #82
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    You said that a 2nd fuse from the infotainment system was missing?
    Without that fuse what wasn't working prior to this happening?
    tomwil, tcjacado and Braves95 like this.
  3. Jul 20, 2017 at 5:15 PM
    #83
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    What he said.
  4. Jul 20, 2017 at 5:48 PM
    #84
    Dobzeh
    Dobzeh Member
    I physically tested every fuse and they are all good.(under hood / dash)
    is there another location for the infotainment fuse, im having the exact same problem you had but i dont see how that fuse could cause it
    tcjacado likes this.
  5. Jul 20, 2017 at 5:50 PM
    #85
    Herniator
    Edmonton
    That reason from the dealer doesn't seem right.
  6. Jul 20, 2017 at 5:51 PM
    #86
    REDNECKTEX
    REDNECKTEX Well-Known Member
    TX
    2017 Inferno TRD Sport
    Kevlar seat covers Fox Shocks.
    I got in my truck and the pedal went almost. To the floor then it was fine any ideas I was not under influence of Copenhagen
  7. Jul 20, 2017 at 6:10 PM
    #87
    Dobzeh
    Dobzeh Member
    Thats what im thinking
  8. Jul 20, 2017 at 6:12 PM
    #88
    Herniator
    Edmonton
    Yup. His Truck was working fine. OP had a issue. The dealer said that a fuse from a unrelated component was missing. Put a fuse in and everything works?
  9. Jul 20, 2017 at 6:23 PM
    #89
    tcjacado
    tcjacado Well-Known Member
    Can you get a pic of where the missing fuse is located at?
    Dobzeh likes this.
  10. Jul 20, 2017 at 6:39 PM
    #90
    Herniator
    Edmonton
    Only place I can see is on the back of the stereo.
    tcjacado[QUOTED] likes this.
  11. Jul 20, 2017 at 7:20 PM
    #91
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yeah I should have asked where the fuse was put. Dealer's words not mine. What ever they did it worked at least. Something's definitely different now that I can actually use the new tails and everything is fine now. So I have no idea.
  12. Nov 27, 2017 at 9:42 AM
    #92
    Tacomerica
    Tacomerica Member
    I am currently having this exact issue, which lead me to this thread. I installed the "Winjet' tail lights last night. Should have been an easy 10 min plug and play. Instead, my truck won't start, stuck in park, "break over ride malfunction" warning is on the dash.
    The electronics turn on but the engine won't turn over. All lights in the headlight and tail lights work except the DRLs and the actual taillights (the blinkers, brake light and reverse light work.)
    My tail light fuse under the dash (7.5) was blown. When I replaced it, it blew again.
    I have a feeling it triggered some other issues.
    Going to have the Truck towed to the dealership ASAP. I'll keep everyone posted on the situation. Hopefully it's an easy fix like ProjectTgen3 said.
    BTW I just became a member here as I am a new 2017 tacoma trd offraod owner. Quicksand. I've got about 6,000 miles on the tuck. This issue is pretty irritating.
    FHC and ProjectTgen3[OP] like this.
  13. Nov 27, 2017 at 10:37 AM
    #93
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Blows with the stock tail lights too?
  14. Nov 27, 2017 at 11:10 AM
    #94
    Tacomerica
    Tacomerica Member
    Haven't tried yet. Out of replacement fuses.
  15. Nov 27, 2017 at 2:53 PM
    #95
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yeah so basically try the STOP fuse and it should turn over. It should be a simple fix because this like exactly what happened to me.
  16. Nov 27, 2017 at 3:11 PM
    #96
    Tacomerica
    Tacomerica Member
    Right on! I'll give it a try. Do you have after market tail lights? Is that what triggered the break override malfunction? Did you have to go back to the stock lights to keep it from happening again?
  17. Nov 27, 2017 at 3:48 PM
    #97
    ProjectTgen3
    Keandrew
    Pennsylvania
    Yeah I have he winjet ones same one as you and ran into this problem. Should be able to get it up and running. Keep me updated.
  18. Nov 27, 2017 at 6:51 PM
    #98
    Tacomerica
    Tacomerica Member
    Okay so here's the update:
    The STOP fuse was blown under the hood, and the TAIL fuse was blown under the instrument panel.
    With the winjet tail lights still installed, I replaced both with new fuses. When I hit the ignition nothing was fixed. Still wouldn't turn over, still got the break override malfunction error, and the STOP fuse blew again.
    I then reinstalled the stock taillights, and replaced the STOP fuse again. This time the engine started and the truck was running. But, still the tail lights were not on, or the DRLs.
    I turned the engine off, waited a minute, and attempted to turn it back on. This time the engine tries to turn over but does not start...
    Maybe it's time for a trip to the dealer.
  19. Nov 27, 2017 at 7:31 PM
    #99
    splitbolt
    NW Arkansas
    Probably fried the TAIL fuse again.
    Check the TAIL and STOP relays?
  20. Nov 27, 2017 at 8:11 PM
    #100
    bottlecap
    bottlecap Well-Known Member
    Eric
    Philly/SJ
    2017 DCSB TRD OR
