Brake Malfunction Dash Indicators
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maffee88, May 18, 2023.
  1. May 18, 2023 at 6:36 PM
    Maffee88
    Maffee88 [OP] Active Member
    Michael
    Calimesa, CA
    2018 Tacoma SR5 DCLB
    3" Bilstein 6112 and AAL 265/70/17 OVTune and CGS Exhaust
    Yesterday I started up my 2018 and had these indicators displayed and flashing on my dash. The truck seems to drive normal and I don’t know what to do. I tried resetting the ECU hoping it would clear it and fixed this malfunction.
    Anybody ever experience this and know what I can do to try and fix it?
  2. May 18, 2023 at 7:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Did you change something lately? Windshield, suspension, electrical doodads?
  3. May 18, 2023 at 9:27 PM
    Maffee88
    Michael
    Calimesa, CA
    Nothing went to work as normal. Stopped at my brothers house and when I went to leave it started. It stopped as I pulled over. Drove home when no alerts. Turned it on today and now it’s on all the time. Very strange.
  4. May 19, 2023 at 2:57 AM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Check for a broken wire at the front hubs. Also check related-fuse.
  5. May 19, 2023 at 3:04 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Take a trip to auto parts store, ask them to check the code. Autozone or Orileys
  6. May 19, 2023 at 3:44 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Check your battery connections and put the battery on a charger. I've seen this on a quasi dead battery.
    newbbewb likes this.
  7. May 19, 2023 at 5:34 AM
    Maffee88
    Michael
    Calimesa, CA
    That’s a good idea. I was reading that it could possibly also be the wheel bearing.
    Getting this scanned is a must to help narrow this down.
  8. May 19, 2023 at 6:04 AM
    ANTupLIFE
    Anthony
    Chester, VA
    Most likely it's a bad wire. Doesn't take much to cut one unfortunately. If it was the bearing, you'd have other obvious symptoms.
  9. May 19, 2023 at 6:47 AM
    Maffee88
    Michael
    Calimesa, CA
    Thank you! I’m going to get it scanned today and also take a look under and see if anything is obvious.
  10. May 19, 2023 at 7:09 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    When you get all the brake related warning lights on at once it's electrical, not something obvious you're going to be able to see. Either an abs wheel speed sensor, the control module, abs solenoid, or the pump shit the bed.
    It's time to run a scan. This is precisely why you should always get a scanner that has ABS bleeding functionality. The cheapo models won't do you any good in this situation.
  11. May 19, 2023 at 8:22 AM
    Maffee88
    Michael
    Calimesa, CA
    Which one do you recommend getting that can read the ABS?
  12. May 19, 2023 at 9:23 AM
    Hairless_Ape
    South Jersey
    2021 F150
    Anything from Innova or Autel that has ABS functionality and fits within your budget. Every model that does ABS will have it all over the item page.
    Maffee88[QUOTED][OP] likes this.
  13. May 19, 2023 at 6:45 PM
    Maffee88
    Michael
    Calimesa, CA
    So I went to autozone and got the code C1403 rear passenger ABS wheel speed sensor. Checked voltage to sensor and cleaned it up. Reset the DTC and it didn’t work. Bought a new one and cleared code and it didn’t work either.
    I don’t understand what it could be then.
  14. May 19, 2023 at 7:01 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Pedal commander? Busted taillight/brake light bulb? Aftermarket led taillights ?
  15. May 19, 2023 at 7:47 PM
    Maffee88
    Michael
    Calimesa, CA
    None of the above. What is weird that it was always dirty when I pulled it out but when I did my check on the driver side it was perfectly clean. Do you think it has something to do with the rotor or bearing?
  16. May 20, 2023 at 12:14 AM
    newbbewb
    newbbewb Active Member
    D
    14 sport Doublecab
    Watch the data as you drive down the road. Did you pull the sensor and verify there’s no junk on it or in the hole. What voltage did you get? Mice and squirrels like to hang out on top of the fuel tank and nibble on the harness that houses the signal wires among other things. As noted above, a battery on its way out can do really odd things to these newer canbus equipped rigs. The fact that your dash lights up with error codes right away has me leaning towards a break in the electrical circuit…i.e. bad sensor or wire. If it was shit in the abs hole the lights would stay off until you start driving. It’s not passing the startup test.
    Edit: missed your last post. If there’s a bunch of shit in the sensor hole, pull the axle out and clean/inspect. The abs system, in your case, is completely seperate from the physical brake hardware. Unless your brakes are super f’d and it’s dragging the RR wheel. Jack up the right rear and physically move the wheel up/down/left/right. Any play denotes a bad bearing.
  17. May 20, 2023 at 2:06 AM
    Rik808
    Rik808 Well-Known Member
    fyi not saying thats what it is but when the radar on the grill stops working/shorts/blocked by mudand or snow it turns the abs off. might want to check that too.
  18. May 20, 2023 at 3:41 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Although you likely cannot perform all of the following exactly as described, see the attached. You can use any scanner capable of reading speed sensors in lieu of Techstream.
  19. May 20, 2023 at 7:07 AM
    Maffee88
    Michael
    Calimesa, CA
    Thank you for that. That’s the next step for sure. I plan on checking the wheel bearing. Brakes are not old changed them at year.
  20. May 20, 2023 at 7:09 AM
    Maffee88
    Michael
    Calimesa, CA
    I took that off first because I read that somewhere also. The radar in the grill is clean and seems to be ok.
