Brake malfunction alert?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The.Taco.Stalker, Jul 14, 2021.
  1. Jul 14, 2021 at 11:08 AM
    The.Taco.Stalker
    The.Taco.Stalker [OP] New Member
    Lora
    Florida
    2020 TRD Off-Road.
    Tldr: 2020 TRD Off-Road is showing a brake malfunction message. Dealer won't investigate because of an aftermarket grill, but they surmised the four amber LED lights on the grill are causing low voltage to the computer and causing it to go squirrely. Error has vanished and returned three times. Looking for insight, advice, things to check, etc... before I take it back to the dealer and cough up the $600+ for them to look into it further.
    Hello TacomaWorld! I was envisioning a more fun post for my first one here, but hey. That's my own fault for not joining in and sharing my adventures before this.
    Sunday afternoon some of my family and I gently (the truck is very much babied) explored a maze of dirt roads we have near us. Two hours later on our way to get an early supper, my truck beeps and flashes a warning on both screen, saying a brake malfunction has been detected. I have not felt anything unusual with the brakes at all, including after the alert came on. I pull over, call my nearest dealer (who I avoid going to because I've had uncomfortable experiences with, I take my vehicle to a dealer an hour and a half away for services) and the service department is closed. My call get handed over to a nice sales guy who just relocated from the service department. He says they just had a similar situation come in a few weeks prior, and it ended up just being that whoever serviced the vehicle before had "knocked something loose and it just had to be plugged back in". He tells me to come by first thing in the morning and they'll check it out.
    Next morning I show up. On the way there, all the alerts vanished. They take the truck back, my brother picks me up and we go run errands and get some lunch. About 2 they call me back and inform me that they believe the four amber LED lights on the grill are pulling too much power, and the lowered voltage is making the computer in the truck go nuts. They also informed me that because I installed an aftermarket grill (yes, I did the bro dude thing and put the counterfeit Pro grill on) that this problem voided my warranty and wouldn't be covered. I'm kicking myself now for not thinking it through and putting the original grill back on, but hey. They asked for $600 to investigate further, but as I felt nothing wrong with the truck and the alerts had disappeared, I felt it best to do a little investigating of my own before I cough up the Big Cash Money Wad.
    I'm not as mechanically literate as I'd like to be, so I'll be having my brother join me who is when we look it all over today. The alert reappeared yesterday for about ten minutes and then vanished again, so I'm hoping it's a matter of dust being where it shouldn't and just needing some tidying and TLC. I've been searching and reading through the forum so there's a couple of things we're going to be checking out and trying.
    In the meantime, I was curious to know if anyone else has experienced anything similar, and if a solution was found. The truck has continued to drive perfectly through all this, never going into limp mode. I'm driving over to my brother's now, but I'll be checking back. Thanks in advance for advice.
    Stay Taco-y out there.
  2. Jul 14, 2021 at 11:30 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    my guess is one of 2 things, either a bad/low quality garnish in front of the radar sensor on the grill. or as the dealer said, the lights causing a low voltage. it would be more helpful to know the exact error message being displayed. If I were in your shoes, I would disconnect the amber lights if the error comes back and see if that changes anything. If that doesn't reslve the issue, then you know the lights are not the root cause. I would then replace the grill garnish with a better one. Do you remember where you bought the grill and TSS garnish from?
  3. Jul 14, 2021 at 11:35 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    Skydvrr likes this.
  4. Jul 14, 2021 at 1:09 PM
    The.Taco.Stalker
    Lora
    Florida
    2020 TRD Off-Road.
    I texted my boyfriend who bought it for me, could be a few days before he answers. I know it wasn't one of the more expensive ones like Cali Raised. I'll let you know for sure where it came from when he gets back to me.
    Twitchhero, not very similar to that. The truck does not go into limp mode at all, runs normal. I did read up on the problems that rear light mods can cause, but I haven't touched the ones on this truck. The only thing I've changed about it that isn't totally superficial is the grill.
  5. Jul 14, 2021 at 1:25 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    raptor lights huh?
    welcome aboard
  6. Jul 14, 2021 at 1:28 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    1st the dealer is NOT obligated to consider ANY after market or modification
    2nd NEVER cut into a OEM harness
    i know little about ‘ counterfeit ‘ parts ( that dont even sound right )
    if going to a dealer disconnect accesories/ after market parts
    take them out of the equation
    thereby leaving only OEM to diagnose especially under warranty
    skiploder likes this.
  7. Jul 14, 2021 at 1:35 PM
    BDSKJChris
    Albany, NY
    FWIW, I got mine, (grill and garnish) from runnin4tacos and have never had an issue, been on the truck for 2 years, been to the dealer for the fuel pump recall and inspections . They apparently did some testing to find a good supplier for the garnish, one that works and does not cause issues with the factory TSS systems that use the Radar sensor.
  8. Jul 14, 2021 at 3:11 PM
    The.Taco.Stalker
    Lora
    Florida
    2020 TRD Off-Road.
    I'm trying to laugh about it, but I wasn't going to keep them on when we first switched out the grill. It was more just to see how they looked, and then they grew on me, lol.
  9. Jul 14, 2021 at 3:19 PM
    The.Taco.Stalker
    Lora
    Florida
    2020 TRD Off-Road.
    Just to be clear, I'm not saying the dealership is at fault at all, I realize they're within their rights.
    And the use of "counterfeit" was me being sarcastic; my bad. Sarcasm does not translate well without tone of voice and a grin. It's been a good while since I've been active on a forum.
    Skydvrr likes this.
  10. Jul 14, 2021 at 10:18 PM
    ROAD DOG
    FEW
    no attempt to place blame or fault
    past OEM the dealer could have billed for diagnostic.....................resulting in several hundred $$$$
    some accessories are better than other accessories
    work better
    last longer
    look cool
    what i said about isolating ANY mods /additions will save U grief in the future
    no blame or fault
  11. Jul 15, 2021 at 6:06 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Do you have a remote start system or a pedal commander?
    If so, I guarantee that's what is causing it. If you don't have a remote start system or a pedal commander then its the raptor lights.
