Brake lines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brad7, May 13, 2019.
  1. May 13, 2019 at 3:41 PM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    I have a 2009 Toyota Tacoma TRD Pro 4x4 and the brake lines rusted through last weekend. I have done some searching but with no success.
    What’s the best thing to do here. Buy brake line and fittings and do it myself? If so where can I find everything I will need all the fittings and length of line needed.
    Or buy lines all ready to go with fittings on them? If I go this rout where would I find the pre made lines?
    I have went to an auto parts store and I was told they can sell me the lines but I would need to do some digging to figure out what fittings I would need.
    I also went to a Toyota dealer and they quoted me over $400 dollars just for the 4 main lines.
    On top of all tgatvwhat is the best line to use? Stainless, copper nickel mix or something else ?
    Any help would be greatly appreciated.
  2. May 13, 2019 at 3:46 PM
    Muddinfun
    Muddinfun Well-Known Member
    Get a frame inspection at the dealer. If you qualify for a free frame, you also get new brake lines.
  3. May 13, 2019 at 4:23 PM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    I had my frame inspection during the winter it passed. So it’s not getting fixed that way. Thanks for the idea though.
  4. May 13, 2019 at 4:28 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    tcjacado likes this.
  5. May 13, 2019 at 4:28 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW.
    @HeadStrong Off-Road should have what you need for parts. Tools, hammer, long flat head screwdriver and a line wrench. 10, 12 or 14 mm (cant remember) then you.
    Then search Google...
    How to bleed brakes on a Tacoma Tacomaworld
    Start reading.
  6. May 13, 2019 at 4:47 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If you're going to bend your own, go with cupronickel. Google Cunifer brake lines. That'll be the last set of lines you'll put on the truck. Bends and flares easily too. Only lines, I'd buy pre-made are stainless steel as the need a special hydraulic flaring tool. If you happen to be in CT, send me a pm and I'll show you how to make you own lines.
    whatstcp likes this.
  7. May 13, 2019 at 4:54 PM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    I don’t know how to reply to individual comments but. If I am wrong on the model I apologize. Would it just be a TRD? I know it has the off-road package on it.
    As for going OEM parts that’s where I was quoted the very high price and the were not stainless lines.
    I will check those links and look into cunifer. The hardest part is going to be figuring out what fittings I need. Unless someone knows an easy way to do that.
  8. May 13, 2019 at 4:59 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    A quick Google search (2009 Tacoma brake fitting size) looks like it's M10-1.0. A local NAPA store should be able to tell you as well.
  9. May 13, 2019 at 5:02 PM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    The auto parts store I went to was NAPA they weren’t much help. Said if I can figure out what I need they can get it.
  10. May 13, 2019 at 5:05 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  11. May 13, 2019 at 5:07 PM
    tcjacado
    There is also @gunny1005
    You can PM him with Vin number and parts description. He will get part numbers for you and a quote on price... he is Camelback toyota parts guy.
  12. May 13, 2019 at 5:09 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Ok, auto zone lists the thread on the rear wheel cylinders and the front brake hoses as M10-1.0 thread.
  13. May 13, 2019 at 5:24 PM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    The one that rusted through is the rear drivers side. It goes from back to about under the drivers door. But all lines look not far behind.
    Obviously I am not used to working on vehicles but the price to get it done at a shop is too high. So I am going to try and figure it out. Once I get the fittings and lines I think the hardest part will be connecting and bleeding them properly.
    M10x 1 fittings and 3/16 line. I’m thinking I’ll go with the copper nickel line I have only heard one bad thing about them but not sure if it’s true. But one person said if you ever need to undo a fitting good luck and that the line will twist all up.
  14. May 13, 2019 at 5:29 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I've never had a problem with cupronickel and have put them on a several vehicles over the last 10 years. If possible, buy or rent a hand vacuum pump to bleed the brakes. It'll get you pretty close to air free if not all the way. You'll want a fresh quart of brake fluid. Don't let the master cylinder go empty.
  15. May 13, 2019 at 7:26 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    As opposed to... steel? That'll rust and do the exact same thing? Never heard that of copper-nickel before.
    I've put brake lines on plenty of trucks, and if the dealer told me they'd do the bulk of them for $400, I'd jump on it. I usually charged 8 hours to do Silverados. They're not terribly hard to do, but I'd let someone else do it if they really meant $400, including materials. Of course if I could get a new frame and get new factory lines for $0, I'd do that too!
  16. May 13, 2019 at 8:40 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Don't mean to discourage you but this is not exactly a job for someone that is new to turning a wrench. Do you have a friend or family member that has some more experience working on vehicles (specifically brake systems) that can help you out?
  17. May 14, 2019 at 2:04 AM
    Brad7
    Brad7 [OP] Member
    2009 Tacoma TRD pro
    The quote from the dealer for over $400 was for parts only no labour. The parts being only the 4 main prefabricated factory lines.
    I’m thinking if I can at least get the lines in place yes I could get some help bleeding them by someone with more experience.
    vssman likes this.
  18. May 14, 2019 at 3:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Most auto stores loan the suction brake pump to pull fluid thru the lines to where you are at - instead of pumping the pedal. Remember to keep that ignition key out of the truck during all brake work as an empty master cylinder will trip the ABS module. Not hard work but can be messy and when connecting the lines get the threads started straight and do not force or cross thread. When I did my last brake job on my 09 I changed out the rubber flex lines for stainless also. Your rear wheel cylinders maybe full of crud so bleed till clean or replace. Front calipers when compressed and taken out will blow a lot of the old fluid out just use brake cleaner spray on the seals before you compress them (push back in). Buy a set of brake wrenches (open end but grab more sides and have a line slot to get on) first so you don't strip out any heads on bleeders or lines you want to reuse.
  19. May 14, 2019 at 3:58 PM
    fb40dash5
    11 V6 AC 4x4
    Getting fully premade lines in place is *usually* waaaaay more work than fabricating them on the truck, for one who knows how to flare lines. Equally important if your truck is rusty, that extra work is removing a bunch of stuff, which means you're probably going to break plenty of bolts.
    I watched my old boss spend a couple days, and a bunch of new parts to replace rusty stuff that broke, putting a GM kit in an Avalanche... that I could've fabricated and had bled in under 8 hours. Mine don't look as tidy, but at some point you have to ask how much you care about what brake hard lines look like.
    Unless you really care that bad how they look (like, probably paying 8+ hours of labor at $100+) I'd ask around for a good independent shop that'll do them in copper-nickel. Should be well under half that $400 for tubing and line nuts, and probably less labor... although I've never seen a book time on it, so everyone is kinda free to wing it on labor times.
  20. May 20, 2019 at 8:16 AM
    Boswarlosboy
    Boswarlosboy New Member
    06 Tacoma sr5 4x4 red 4.0 auto
    3 inch lift.
    Rear steel brake line routing 06 tacoma
