Brake line bracket, what to do after the lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JAL, Oct 6, 2022.
  1. Oct 6, 2022 at 7:33 PM
    JAL
    JAL [OP] Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    I tried finding something
    in the search function but couldn’t locate what I’m needing.
    Just installed the Ironman Foamcell Pro stage 1 kit and there’s no place to re-attach the rear brake lines after new leaf pack changed out (or the mechanic things so). What have others done to attach?
  2. Oct 7, 2022 at 4:51 AM
    Bucciwil19taco
    Bucciwil19taco New Member
    W
    2019 6spd trd off-road
    There should be a threaded hole in the leaf spring bracket that the factory bracket bolts to with original hardware
    Check to see if the hole is there or at the other end of the springs if they are on backwards
  3. Oct 7, 2022 at 7:55 AM
    Tacomoomoo
    Tacomoomoo New Member
    Chad
    2022 White Tacoma TRDOR
    None-yet
    Those are your emergency brake cables, mechanical not hydraulic. I honestly cut that bracket off. I'm still getting to 500 miles on the new lift at which point I'm going to retorque everything and check for any rubbing issues. If I see some, I'll use a coated hose clamp and section of slightly larger hose as an insulator. I've climbed under there, no visible wear yet.
    Ricardo13x likes this.
  4. Oct 7, 2022 at 8:13 AM
    JAL
    Mississippi
    So your just letting it hang free, right? And adding the rub protection as preventative.
  5. Oct 7, 2022 at 8:23 AM
    Tacomoomoo
    Chad
    None-yet
    For now. It's a pretty ridged cable. It's connected at the frame still. I too didn't have the threaded hole in the replacement springs. I didn't want to deal with drilling and a tap and die on the spring clamp.
  6. Oct 7, 2022 at 10:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    One of the other leaf keepers should have a crossbolt? Just mount it there. You may have to open up the hole on the factory bracket with a stepped drill bit.
    Ironman picture for reference, not sure which end is for the front:
  7. Oct 7, 2022 at 10:50 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I let mine hang loose and free. :anonymous::anonymous:
    Puga10 and MR E30 like this.
  8. Oct 7, 2022 at 11:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've seen that setup chaf the sheath and get hung up on the wrong side of the keepers.
    I reamed, attached mine to a keeper, and then bent it with channel locks to follow the angle of the line.
  9. Oct 7, 2022 at 11:16 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    This hole here should be it. You might need to trim that rubber a bit for that stand-off on the cable to sit flush though.
  10. Oct 7, 2022 at 11:17 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Here mine from my install
  11. Oct 7, 2022 at 11:52 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    chop it off. Icon RXT states that in their install instructions.
  12. Oct 7, 2022 at 11:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but that is the wrong answer. Mine with RXTs was already catching on a keeper. Thankfully I didn't cut them and was thinking about what to do.
    TS4x4 and hyrule_trd like this.
  13. Oct 7, 2022 at 12:09 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  14. Oct 7, 2022 at 12:11 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Zip tie a heater hose around the part that rubs.
  15. Oct 7, 2022 at 12:15 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Cut it and do this ^^^
  16. Oct 7, 2022 at 2:33 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Chop it off
  17. Oct 7, 2022 at 4:20 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I took mine off about 45,000 miles ago. So far no worries.
  18. Oct 7, 2022 at 5:29 PM
    JAL
    Mississippi
    Copy and thanks for all the helpful records! After taken another look I see the threaded holes are indeed there. I just to now find what size bolts attach that bracket. Anyone with the kit have an idea?
    I think I feel better with it attached. I’m not going to over flex mine, at least not on purpose, :thumbsup:
    @hyrule_trd
    hyrule_trd likes this.
  19. Oct 7, 2022 at 5:47 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I think it was the same bolt they came out of the other leaf pack… or I had a spare one from another project, sorry I can’t quite remember.
  20. Oct 7, 2022 at 9:38 PM
    JAL
    Mississippi
    Thanks
