Brake lights went out in my 2008 Tacoma. Checked fuse in smaller compartment & brake switch.
Discussion in 'Lighting' started by Jewellstruck, Oct 18, 2016.
  1. Oct 18, 2016 at 12:31 AM
    Jewellstruck
    Jewellstruck [OP] New Member
    2008 Tacoma
    Don't want to accept it's the wiring yet. Automatic shifter was stuck in park a few weeks ago, I've been forcing it into gear ever since until I read about the button today. So that was pretty cool, I never knew what the hell that thing was, but yeah, been reading how lights and the shifter and such are tied together for lack of a better description of what I'm trying to explain. Not ready to get crazy on the wiring just yet,,or pay out the ass for Toyota dealership to handle it. Why did my brake lights just stop working? This hella sucks. And I'm not familiar with fuse box under hood but Is there a brake light fuse in there? I only checked and replaced the fuse in smaller compartment inside the truck on drivers side. Ok,,, I'm ready, advice ? Oh and I carefully cleaned the brake switch under pedal.
  2. Oct 18, 2016 at 12:35 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Replace the brake light switch.
  3. Oct 18, 2016 at 12:40 AM
    Jewellstruck
    2008 Tacoma
    I'll do that, just thought that would be too easy. I'll buy a new one tomorrow.
  4. Oct 18, 2016 at 12:44 AM
    inwood customs
    Dave
    Might be a 10a fuse in the engine bay labeled "tail".
    Im not 100% about that.... lemme go look
  5. Oct 18, 2016 at 12:45 AM
    Jewellstruck
    2008 Tacoma
    Is there a brake light fuse in fuse box under hood that may need to be replaced?
  6. Oct 18, 2016 at 12:47 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    10 amp. On the diagram in the picture, it is below the spare fuses, says STOP.
    inwood customs likes this.
  7. Oct 18, 2016 at 12:50 AM
    inwood customs
    Dave
    Thanx, its not easy getting to mine right now.
  8. Oct 18, 2016 at 12:51 AM
    inwood customs
    Dave
  9. Oct 18, 2016 at 12:57 AM
    inwood customs
    Dave
    Brake light switches can be intermittent....
    A fuse, well ive never seen an intermittent one personally.
    Messing with the switch may get u by for a day, week, hours, or minutes.
  10. Oct 18, 2016 at 1:05 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    There are a few here who have had intermittent fuse failures. Hairline crack that opens up as it heats up, but doesn't show issues when no load.
    Anyways, swap the fuse out to see if that fixes the brake lights and shifter lock. If it doesn't, change out the switch. If I remember right from others swapping theirs, it isn't that expensive and is easy to do.
    Also, if you have any other stuff going on, check IGN1 & IGN1 No.2 under the dash.
  11. Oct 18, 2016 at 1:06 AM
    inwood customs
    Dave
    Pretty sure i paid 30bux tops at dealership.... and yeah, its like a 30 second job.
  12. Oct 18, 2016 at 10:05 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  13. Jun 3, 2021 at 9:28 AM
    RT Taco
    RT Taco New Member
    2008 Prerunner DCSB
    Or you can try what I did. I pulled the switch out and took it apart and sanded the contacts and the prongs that slide into the contacts. Applied a little die electric grease, reassembled, reinstalled and it works now. I could see a small spot on one of the contacts that looked a bit burnt which is the one I focused on when sanding it down with emery cloth. I put a zip tie around the case to make sure that I didn't come apart over time. We'll see how long it last, but it saved me $30 and a trip to the store for now.
