Brake Light/Pedal wiring
Discussion in 'Technical Chat' started by cowman71, Sep 3, 2013.
  1. Sep 3, 2013 at 10:22 AM
    cowman71
    cowman71 [OP] Member
    Central Texas
    '13 AC 4x4 base, Convenience and Tow Pkg.
    I am trying to install a switch to disable the brake light for hog hunting at night with night vision (private property- no public roads). I know that others have done this by splicing a simple switch into the wire that senses when the brake pedal is depressed. My problem is that there are four wires going into the fitting that plugs into the pedal sensor. Can someone tell me which wire will interrupt the brake light and maybe what the others are for? (pic included)
    Grable likes this.
  2. Sep 4, 2013 at 7:46 AM
    BamaToy1997
    Bill
    Navarre, FL
    The 2013 (As well as a few years older) Have an interesting situation. You have two different ways for the stop lights to come one. First is with the normal pressing of the brake pedal, and the other is with the ABS system when it applies the brakes automatically when in a potential skid. While off the main road you probably won't run into the skid situation, it is a good idea to know this as a "just in case" situation.
    As for you wanting to cut off the brake light switch signal to the brake lights for normal brake operation, you can put a switch in-line on either the green-white wire which is the power TO the switch, or the blue wire which is the signal FROM the switch.
  3. Sep 4, 2013 at 2:17 PM
    cowman71
    Central Texas
    Thanks guys, this place is amazing.
    BamaToy, do you think if I located the wire in the below pic (robbed from a search on this site with thanks to whoever took it) and spliced into it, that I could disable both the reverse lights and brake lights with a single throw/double pole toggle switch?
  4. Sep 4, 2013 at 3:29 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Just for your info, on 1st gen Tacoma's, the other pair of wires to that switch is for the Cruise Control (so that the CC is shut down when you step on the brake).
  5. Sep 4, 2013 at 5:42 PM
    BamaToy1997
    Bill
    Navarre, FL
    The OP truck is a 2013, not a 1st gen....
    Cowman, I will have to look at the wiring diagram tomorrow at the shop.
  6. Sep 9, 2013 at 2:18 PM
    cowman71
    Central Texas
    I made the pasture circuit Saturday night with some homemade curtains to block the dash lights and I unplugged the brake sensor plug to see what would happen. Everything worked fine except for one little hiccup... I have an auto transmission and when I disconnected the brake I couldn't disengage the shift lockout without fiddling with the override button. If I brake the circuit on the green wire or blue wire is it going to screw up function of the brake disengaging the shift lock mechanism?
  7. Apr 10, 2018 at 1:00 PM
    Grable
    Grable 2010 TRD OR 6spd 4x4 DBL CAB
    Clovis, Ca 93612
    2010 Tacoma Double Cab Silver TRD Off Road 4x4 6 speed manual
    just wanted to revive this thread.
    anyone have any answers or solution?
    looking to do this to mine. i doubt ill run into the same issues since i have a 6 speed manual. but any input would be awesome before i start cuttin shit up.
  8. Nov 11, 2019 at 12:49 PM
    johnny340
    johnny340 Member
    Vancouver BC Canada
    2015 TRD Sport
    I'm in the middle of wiring in a parking sensor kit and need the brake light signal. Is it from this blue wire on the stop light switch? I'm not showing any power on it with the brake pedal applied.
    Many thanks for a quick reply!!
  9. Nov 11, 2019 at 5:06 PM
    johnny340
    johnny340 Member
    Vancouver BC Canada
    2015 TRD Sport
    OK to end this already dead thread for good just in case anyone is searching here is what I learned:
    The brake light signal can be obtained from the trailer brake harness middle wire of the three small wires. That harness is clipped into the drivers kick panel and not hooked up. I used the trailer brake harness connector that came in a bag with my truck so no cutting was required and it was a green and white on that harness connector. (different colour than the main wiring harness...I think it was blue?)
    The red/wht wire shown in the pic above is the reverse light wire. (It was solid red on mine.)
    I tapped off IGN2 which is switched power.
    Make your own ground and you should have everything you need to install one of those cheap Chinese 8 sensor parking sensor kits. Good luck!
    Camazon likes this.
