brake light leak - silicone?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrain904, Feb 15, 2021.
  1. Feb 15, 2021 at 12:34 PM
    jrain904
    jrain904 [OP] Well-Known Member
    Anyone with the brake light leak diy fix with silicone? Did it work well? Mine is leaking and I do not want to pay $700 to fix it. Thanks
  2. Feb 15, 2021 at 12:41 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    It works, use the clear stuff
    Skydvrr likes this.
  3. Feb 15, 2021 at 12:47 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    I applied silicone on my years back. Like said above use clear type and mask off the area with tape to achieve a clean finish.
  4. Feb 15, 2021 at 1:00 PM
    jrain904
    I have a topper on mine so cant see. Thinking about doing 5200 lol
  5. Feb 15, 2021 at 1:12 PM
    eurowner
    eurowner Duke Sky
    Scoty
  6. Feb 15, 2021 at 1:15 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Feb 19, 2021 at 10:08 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    shakerhood and eurowner[QUOTED] like this.
  8. Feb 19, 2021 at 10:14 AM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    that boat stuff will hold up the longest, 3M 4200 or 5200. If it will keep water from entering a boat under the water line, it'll surely keep a little bit of water out of your brake light.
    eurowner likes this.
  9. Feb 19, 2021 at 10:30 AM
    Tacowin1013
    only comes in white?
    STuN likes this.
  10. Feb 19, 2021 at 11:00 AM
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    My third brake light was over tightened on my double cab so the housing broke from the bolts holding it in place. I could literally wiggle the light and feel it move. Dealer quoted me $400 for labor and parts to replace the light.
    Bought the light myself, pulled down the headliner, and installed the light and applied a bead of silicone beforehand. Cost about $150 total and maybe 4 hours of work since I didn’t know how to remove the headliner at first. It’s been holding up well for the past 3 years. The third brake light is different for the double cab and access cab Tacomas. Access cabs have screws outside and are easily assessable. Double cabs have to have the headliner removed to access the light from the interior.
    Online parts stores call the third brake light a “Center High Mount Stop Light”. Here’s a link to the light for double cabs if anyone needs it. https://parts.toyota.com/p/Toyota_2017_Tacoma/Center-High-Mount-Stop-Light/63228182/8157004030.html
  11. Feb 19, 2021 at 1:24 PM
    Lurod
    Lurod Active Member
    Luis
    2016 White Tacoma
  12. Feb 19, 2021 at 1:35 PM
    jrain904
    Grossomotto likes this.
  13. Feb 19, 2021 at 2:09 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Which one?
  14. Feb 19, 2021 at 2:09 PM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    Is this still a problem on 2020's and 2021's?
    Canadian Caber likes this.
  15. Feb 19, 2021 at 10:10 PM
    jimmerheck
    Vancouver, WA
    yes, white only.
  16. Feb 20, 2021 at 4:47 AM
    Tacowin1013
    Yikes, I'll stick to clear silicone
  17. Feb 20, 2021 at 4:59 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not that I know of. But then again I have a 2017 and have yet to have this issue.
    crashnrondo[QUOTED] likes this.
  18. Feb 20, 2021 at 5:04 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I fixed mine with the new light assembly. About $130 for the part brand new, and a couple hours work.
  19. Feb 20, 2021 at 8:51 AM
    jrain904
  20. Feb 20, 2021 at 8:51 AM
    jrain904
