Brake light flasher module?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jan 10, 2019.
  1. Jan 10, 2019 at 7:28 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I’ve noticed how effective these can be at getting my attention when the vehicle in front of me brakes, so I’m thinking about throwing a couple on my brake lights (can’t see my third atm so not worried about that one). But, I’ve read a couple posts where people have had no-start issues after swapping out bulbs so I’m a bit hesitant. Has anyone installed a flasher / strobe module on their third gen?
    Thinking of this one (I’ll need one for each lamp right? Or can I tap into the circuit farther upstream and only use one?):
    https://www.amazon.com/dp/B00FADDOL4/ref=cm_sw_r_sms_c_api_i_OYaoCbNBE06W6
  2. Jan 10, 2019 at 7:36 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    My third flashes and its stock...I think I did that when I was poking around in techstream and forgot. Just noticed it a week or so ago
    Edit: it was most likely added by the dealer before I purchased it, not sure why though
  3. Jan 10, 2019 at 8:28 PM
    Rujack
    I wonder if there’s a setting for all of them...
  4. Jan 10, 2019 at 8:34 PM
    Bishop84
    Bishop84 Well-Known Member
    Strobes/pulsating lights are illegal for on-road vehicles in most places. Be sure before going through with it. I've never seen that function on any toyota in Techstream customization.
    I agree it grabs attention, I like it on motorcycles.
  5. Jan 10, 2019 at 8:36 PM
    svdude
    svdude Well-Known Member
    jonathan
    For what it's worth, I have that on mine and I hate it. If you have a rack on your bed you'll get a really annoyed splash and you'll see it in your rear view mirror at night. I bought my truck used and the p/o had it on. I plan on deleting it when I get time.
  6. Jan 10, 2019 at 9:04 PM
    Rujack
    I’m happy to consume a bunch of nanny-state dollars for the price of a $10 fix-it infraction.
  7. Jan 10, 2019 at 9:07 PM
    Rujack
    I hear ya. I’d just pull the bulb from my third.
  8. Jan 10, 2019 at 9:21 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    OP I have the same module on my motorcycle. It’s really easy to program and has a ton of features. On a truck.. I’m not sure I’d do it.
    What if I told you it’s bulbless...
  9. Jan 10, 2019 at 9:31 PM
    Rujack
    Fine. The diodes. I’ll pull the :censored:in’ diodes. Or put some electrical tape on them. Or let them corrode in all the rain water that gets in.
    Point taken. :cookiemonster::D
    johntoyota likes this.
  10. Jan 10, 2019 at 9:35 PM
    Rujack
    Hmmmm. Why not? I’m just trying to get people off my tail...(I drive like your great great grandmother on a steam powered horseless carriage).
  11. Jan 28, 2019 at 6:53 AM
    Rujack
    Bump. Still considering this.
    Do these modules just get spliced into the positive wire to the lamp, or?
  12. Jan 28, 2019 at 8:36 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    BEWARE! She's comin' through!
    Clearly you didn't know Mabel... She was often referred to as a holy terror on that confangled abomination!
    Rujack[QUOTED][OP] likes this.
  13. Jan 28, 2019 at 8:37 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    OP, just get a "Student Driver" bumpersticker and not only will they not tail you... they will kindly wave when they pass... Problem Solved.
  14. Jan 28, 2019 at 9:21 AM
    Rujack
    Considering the lack of understanding of basic physics so many drivers demonstrate, I’m not confident they’re literate.
    Kodiak420 and NoOne[QUOTED] like this.
  15. Jan 28, 2019 at 9:25 AM
    Rujack
    Another thing I’ve thought of doing just for shits and giggles is putting a length of steel bar under the back of the truck on lever a somehow, that drops the back end of the bar down to the road to throw sparks. Behind the fuel tank of course. Could be spring assisted for maximum effect.
    Would have a reverse gear lockout.
  16. Feb 1, 2020 at 9:16 AM
    doublefisttaco
    doublefisttaco Member
    David
    2018 White Tacoma TRD Off-road
  17. Feb 1, 2020 at 9:24 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I drive a dump truck with a GVWR of 60,000lbs. I'm the slowest guy on the road AND I throw rocks at other drivers and I STILL get tailgaters like a mofo.
    My suggestion is just learn to not let it bother you. Flashy lights won't make any difference.
    Doobfucious and Joe23 like this.
  18. Feb 1, 2020 at 9:58 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Which lights are you planning on putting this on?
    The third brake or your regular lights?
    Something to consider is incandescent bulbs have a slower start time (like the ones you have in the tail lights)
    This might not even work on those because the pulse might be too quick and barely show a flashing brake light.
    Think of when idiots put cheap led bulbs in their signal then they get the hyper flashing.
    It's because the pulsing voltage the makes your signal flash is actually much faster than it appears to flash because of the slight delay for the filament to heat up and give off light. But with an LED it's more instantaneous hence causing the hyper flashing.
    I think most of those modules for pulsing brakes are for led. So if you aren't putting them on led might not really work.
  19. Feb 1, 2020 at 10:00 AM
    Joe23
    Best bet is just change lanes. I don't get why people tailgate when you're in the slow lane. It's like they just want to make you move its not about actually passing.
    Although I feel the flashers might be better at getting the attention of a distracted driver instead. But as you said will likely do nothing to stop tailgating
  20. Feb 1, 2020 at 10:01 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2 lane roads where I work. Fast lane, slow lane, all the same lane.
    Joe23[QUOTED] likes this.
