Brake Issues on 2006
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BassMaster06, Jul 4, 2022.
  1. Jul 4, 2022 at 9:48 AM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Searched a few threads but can’t seem to narrow down my issue. Did a full brake fluid flush, replaced both front calipers, and I’ve been bleeding the shit out of this truck for the last 3 days with multiple methods and no luck.
    When the truck is off, everything bleeds fine, no air bubbles whatsoever. The pedal is stiff as a board during the process. Finish up all 4 wheels in the proper sequence, turn the truck on and the pedal essentially goes to the floor.
    Just gave it another shot this morning and I bled the master cylinder beforehand just to make sure it wasn’t holding air. Same thing, bled well, no air in the lines, pedal stiff as can be. Turn the truck on and it turns in a mushy sponge.
    I wasn’t having this issue before I replaced the calipers. Any ideas or suggestions are appreciated.
    Edit: just to add, not leaking fluid anywhere. Is there a way to test the master cylinder to verify? Air in my ABS module?
  2. Jul 4, 2022 at 10:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You need a scan tool to bleed the abs.
    Or find a gravel/dirt road and press the brake pedal hard enough to make the ABS come on.
    Jimmyh, wilcam47, Key-Rei and 2 others like this.
  3. Jul 4, 2022 at 10:27 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Odd that you'd need to bleed the ABS module just because of a caliper swap, unless you let the system drain down to empty at some point.... regardless, that's what it sounds like. If you don't have a scan tool with that function, or access to one, than a gravel road, or neighbour's wet lawn are good alternatives. You will probably need to cycle it 2-3 times, and then re-bleed all four corners. Should be good after that.
    Raylo, wilcam47 and BassMaster06[OP] like this.
  4. Jul 4, 2022 at 11:12 AM
    BassMaster06
    Dan
    South Carolina
    Gotcha. When I started the brake fluid flush prior to installing the new calipers, I used a turkey baster and sucked out virtually all of the old fluid in the reservoir. Refilled it prior to cracking open any lines for the flush. Unlikely I got air in then.
    My FIL came down for the weekend and brought his vacuum bleeder. We tried that yesterday. He was watching the fluid level in the reservoir for me while I was under the truck. He didn’t realize my reservoir has a front and rear section, so while we were doing the rears wheels, he was watching the front reservoir, so we bled the rear reservoir dry. That’s likely what did it.
    :annoyed:
    Bled it again today and it feels a lot better but pedal still sinks when truck is turned on. I’ve got a dirt road nearby I’m gonna try out. I’m guessing the ABS dash light coming on will be my indicator for successfully getting it to cycle?
    Thanks!
  5. Jul 4, 2022 at 11:45 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    and the pedal with vibrate when your ABS kicks in..
    BassMaster06[OP] and tirediron like this.
  6. Jul 4, 2022 at 12:10 PM
    tirediron
    Ummm… dual circuit master cylinders have been standard since about 1966 - was your father's last repair job for a family named 'Flintstone'?
    You'll know when the ABS kicks on! :rofl:
  7. Jul 4, 2022 at 12:29 PM
    BassMaster06
    Dan
    South Carolina
    Haha, idk man, I think he just wasn’t paying attention. I’ll report back when I have a chance to hit the dirt road and bleed the system again.
    tirediron[QUOTED] likes this.
  8. Jul 4, 2022 at 5:28 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The scan tool is only for trucks with traction/skid control.
  9. Jul 4, 2022 at 6:07 PM
    Waasheem
    Waasheem
    2007 xrunner
    This problem repeats something like once or twice a month. We should have a permanent on top stickie, BRAKES, READ THIS FIRST. Then explaining the problem, how to prevent, how to fix.
  10. Jul 4, 2022 at 7:02 PM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Had the same spongy pedal thing after my frame replacement in '16, finally went and bought all new brake parts
    rotors, pads, calipers, rubber hoses.
    Took it to my buddy who's a mechanic to do the work and he returned it in perfect order with a hard pedal, said all he did was gravity bleed the brakes cause he was alone and that's what worked.
    BassMaster06[OP] likes this.
