Brake Fluid Leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sfcmcmahon, Jun 27, 2023.
  1. Jun 27, 2023 at 7:25 AM
    Sfcmcmahon
    Sfcmcmahon [OP] Well-Known Member
    Central Florida
    2013 Tacoma TRD Sport 4x4
    While bleeding my brakes after changing my front brake pads, I noticed this moisture on my right rear wheel area. Any idea what this might be leaking from?
    Even after installing new pads and bleeding the brakes, the pedal is a bit mushy. My brake fluid is very dark and I'll replace that soon. Hopefully that will fix the mushy brakes, if not, could it be caused by this leak?
  2. Jun 27, 2023 at 7:30 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It may be the wheel cylinder.
    Pull the drum and take a look.
    The only 2 possibilities are differential fluid or brake fluid.
    The axle seal doesn’t usually cause moisture on the outside of backing plate.
    It usually leaks inside the drum and then gets slung all over the wheel well.
    HondaGM and Sfcmcmahon[OP] like this.
  3. Jun 27, 2023 at 11:45 AM
    Sfcmcmahon
    Central Florida
    This doesn't look good. Any idea what's going on here?
  4. Jun 27, 2023 at 11:50 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    wheel cylinder is gone?
  5. Jun 27, 2023 at 11:50 AM
    TnShooter
    Deogee
    STOCK
    It’s either brake fluid of differential fluid.
    The smell would give it away. Differential fluid stinks.
    Look around the rubber boots on the wheel cylinder really good.
    You may even need to clean that up some to find the source.
  6. Jun 27, 2023 at 11:54 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    yep...need to pull those boots back and take a look...i cant see it up close but that may be an axle seal
  7. Jun 27, 2023 at 12:12 PM
    Sfcmcmahon
    Central Florida
    I can easily rotate the boot on the left, the right one seems solid. My sniffer doesn't work very well but it doesn't stink.
  8. Jun 27, 2023 at 12:13 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Pinch the boot and see if its inside of it..
    Kwikvette and b_r_o like this.
  9. Jun 27, 2023 at 12:14 PM
    Sfcmcmahon
    Central Florida
    See if what's inside? The liquid?
    HondaGM[QUOTED] likes this.
  10. Jun 27, 2023 at 12:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think you found the source of the mushy brakes and the leak.
    No stink indicates wheel cylinder leaking.
    HondaGM, Kwikvette and TnShooter like this.
  11. Jun 27, 2023 at 12:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't be afraid. Grab that wheel cylinder boot and squeeze it, see if brake fluid comes out. If not that then it needs axle seals
    HondaGM and TnShooter like this.
  12. Jun 27, 2023 at 12:17 PM
    TnShooter
    Deogee
    STOCK
    Those boots pop off.
    But like the others said, squeezing them usually usually does the trick.
    HondaGM likes this.
  13. Jun 27, 2023 at 12:17 PM
    Sfcmcmahon
    Central Florida
    So, just replace that cylinder then flush brake fluid?
  14. Jun 27, 2023 at 12:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The brake fluid is between two pistons and they get pressed out when the brakes are applied. Each piston has a rubber seal to prevent leaking past the piston. The end is covered with a rubber boot (the part you can see). If one of the piston seals is leaking the results would be what you have there. If there is fluid behind the rubber boot the wheel cylinder needs to be rebuilt or replaced.
    wi_taco and HondaGM like this.
  15. Jun 27, 2023 at 12:21 PM
    Sfcmcmahon
    Central Florida
    Nothing comes out when I squeeze the boots. I looked inside the boot and didn't see any liquid.
    GrandMasterChooch and HondaGM like this.
  16. Jun 27, 2023 at 12:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Squishy brakes could be caused by shoes that are out of adjustment. You'll be dealing with all that anyway when you do the axle seals
  17. Jun 27, 2023 at 12:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If both boots are dry then you need an axle seal.
    wilcam47 and HondaGM like this.
  18. Jun 27, 2023 at 12:23 PM
    TnShooter
    Deogee
    STOCK
    Pretty much.
    I don’t like working in a mess, so I cap the brake like with a vacuum cap to keep the fluid from running out the line when swapping the cylinder.
    I gravity bled my cylinder. Then did the old tried and true - pump, hold, crack bleeder process.
    Jimmyh and HondaGM like this.
  19. Jun 27, 2023 at 12:24 PM
    TnShooter
    Deogee
    STOCK
    Tell me about it. :rofl:
    That’s the reason my brake system got flushed.
    The truck kind of forced me into it when replacing the axle seal.
    HondaGM and b_r_o[QUOTED] like this.
  20. Jun 27, 2023 at 12:29 PM
    TnShooter
    Deogee
    STOCK
    Advics is the OEM suppliers for the 2nd Gen trucks.
    You would probably be fine with an aftermarket cylinder.
    I hate drum brakes, every thing about them.
    I’d buy the best one the parts store had one had.
    Dorman is NOT the best one in my opinion. Raybestos would be my pick if OEM (Advics) can not be found.
