brake fluid dirty 10k miles after brake job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billthehiker, Jul 19, 2019.
  1. Jul 19, 2019 at 9:57 AM
    billthehiker
    billthehiker [OP] Well-Known Member
    Does it seem reasonable that my brake fluid is dirty just 10k miles/11months after front brake job that included bleeding and adjusting the system?
    The shop that did the brake job is not the one that is telling me the fluid is dirty.
    2008 v6 4wd TRD offroad
  2. Jul 19, 2019 at 10:00 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    What does "dirty" mean? Are they talking about the master cylinder or the wheel cylinder? Is the fluid at the wheel cylinders burned? Do you do a lot of off-roading and/or hard braking? If so, it's possible.
  3. Jul 19, 2019 at 10:03 AM
    cjsqueeky
    cjsqueeky Well-Known Member
    chris
    Chesapeake VA
    15 tacoma dbl cab
    front 2.5 headstrong lift, Freedom offroad UCA, 3 inch rear custom helwig lift, custom double cardon 2 piece drive shaft
    They are trying to sell you on a brake fluid flush... Don't do it..
    All it is going to do is push any grit in the system into wheel cyl and calipers, which will cause them to freeze up.
  4. Jul 19, 2019 at 10:09 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    every year?? something is wrong if you are changing it every year...Ive had multiple vehicles and toyotas and never had to change the brake fluid.
    spitdog likes this.
  5. Jul 19, 2019 at 10:22 AM
    billthehiker
    How would I check it myself -what to look for?
  6. Jul 19, 2019 at 10:23 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    no it should be clear, like corn oil in the master cylinder
    b_r_o likes this.
  7. Jul 19, 2019 at 10:26 AM
    wilcam47
    Will
    Bourbon state
    you should be able to see the fluid, where the brake fluid reservoir is. It should be a littler darker than the plastic but still clear. what looks normal..
    BillsSR5 likes this.
  8. Jul 19, 2019 at 10:27 AM
    wilcam47
    Will
    Bourbon state
    of course if its really black looking then theres issues...
    b_r_o likes this.
  9. Jul 19, 2019 at 10:28 AM
    wilcam47
    Will
    Bourbon state
    good left bad right....
    BillsSR5 and b_r_o like this.
  10. Jul 19, 2019 at 10:32 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    PzTank and b_r_o like this.
  11. Jul 19, 2019 at 10:34 AM
    BillsSR5
    bill
    2014 SR5
  12. Jul 19, 2019 at 10:39 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    These kinds of vague upsells are commonplace at cheapie lube shops. Get a little tester like the one mentioned above and keep track of it yourself.
    Brake fluid doesnt wear according to mileage, its more of a time thing. Its hydroscopic and designed to soak up moisture from the system. If you live in a region where its rainy you may need to flush it more often.
    Up here in WA i sell lots of brake flushes, once every 2-3 yrs is a good rule of thumb
    blu92in99, whatstcp and Skyway like this.
  13. Jul 19, 2019 at 10:47 AM
    billthehiker
    Thanks folks. Fluid looks very clear and clean, just like the pics you posted.
    wilcam47 and b_r_o like this.
  14. Jul 20, 2019 at 7:52 AM
    wilcam47
    Will
    Bourbon state
    I wouldnt mess with it unless you had problems braking...
    b_r_o likes this.
  15. Jul 20, 2019 at 8:46 AM
    wilcam47
    Will
    Bourbon state
    but OP says 10K miles...i dont think theres a problem there...just the shop trying to UPSell some unnecessary maintenance.
  16. Jul 21, 2019 at 11:17 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Unless you are changing the brake fluid yes it makes sense its dirty when you keep using it and don’t change it.
  17. Jul 21, 2019 at 12:10 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Could be the grease used when replacing the caliper piston seals causing it to look dark. I've seen it happen in just a few months.
    Anytime the fluid looks darker than normal it gets flushed in my vehicles, or every two years regardless. Maybe an hour job and 2 quarts of Prestone Dot 3 synthetic from Walmart.
