Brake controller installation on 2013 double cab 4wd SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013SR5, Feb 22, 2023.
  1. Feb 22, 2023 at 8:43 AM
    2013SR5
    2013SR5 [OP] New Member
    Kevin
    2013 double cab SR5
    None
    Hi, I’m a new member. I have a 2013 double cab v6 4wd Tacoma with a factory towing package. I want to intall a REDARC tow pro to elite trailer brake controller. But I just found the toyota wiring harness for this in my glove box—not installed as part of the towing pkg. I thought controller installation would be simple with the prewired harness. Now that I have to first splice in the harness, not so sure. Has anyone done this? Not sure how to tell which wire is which in the existing truck wiring. Any suggestions?
  2. Feb 22, 2023 at 8:51 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Feb 22, 2023 at 9:06 AM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Tucked up under the dash and driver side kick panel there is a plug. Tucked behind the wiring harness. it's white. If you got a prewired harness when you got your brake controller one end should plug into that plug in the truck the other into the brake controller.
  4. Feb 22, 2023 at 12:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    No splicing needed just need to find the open plug and plug in as mentioned. its WAY up under there above the dead pedal / clutch pedal , get a flashlight and get comfortable.
    TnShooter likes this.
  5. Feb 22, 2023 at 2:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeap, it’s WAAYYY up in there.
    Look for the foam tape, it’s close to that.
