Brake Caliper Torque Help
Discussion in 'Technical Chat' started by fadecement824, Jun 19, 2024.
  1. Jun 19, 2024 at 12:57 PM
    fadecement824
    fadecement824 [OP] Member
    Seattle, WA
    2019 Off Road
    I was replacing my pads and rotors on my 2019 Off Road and accidently took out the wrong bolts on the back of the caliper. I took out the 2 bolts that hold the caliper halves together.
    Does anyone know what the torque specs are on those bolts?
    I have not found an exact answer but one I saw said 90 ftlb. Is this correct?
    Thank you
  2. Jun 19, 2024 at 3:27 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    A couple ugga duggas will do it
    Robnik and nudavinci64 like this.
  3. Jun 19, 2024 at 6:56 PM
    fadecement824
    Seattle, WA
    2019 Off Road
    I gave it a couple good ugga duggas but just trying to make sure nothing falls off. :(
    TomTwo[QUOTED] and Robnik like this.
  4. Jun 19, 2024 at 6:57 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Loctite would be good.
    Robnik likes this.
  5. Jun 19, 2024 at 7:05 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    As Bill said, a couple ugga duggas will suffice. Can't use a torque wrench for everything.
    TomTwo likes this.
  6. Jun 19, 2024 at 11:18 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Caliper halves are machined flat and there is a small o-ring in there so as long as you did not actually pull them apart tight is good.
    I rebuilt mine and just tightened up. If you know bolt size and rating here is a chart if OCD.
    fadecement824[OP] likes this.
  7. Jun 21, 2024 at 12:49 PM
    fadecement824
    Seattle, WA
    2019 Off Road
    Thats great, thanks for the chart!
