Brake booster and master cylinder upgrades
Discussion in '1st Gen. Tacomas (1995-2004)' started by Troublesbowma, Dec 10, 2020.
  1. Dec 10, 2020 at 12:07 PM
    Troublesbowma
    Troublesbowma [OP] Member
    Trevor
    03 tacoma
    Looking at upgrading brake booster and master cylinder .
  2. Dec 10, 2020 at 12:11 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    You putting on bigger wheels/tires, adding bumpers, armor, tents, gear that will add weight?
  3. Dec 10, 2020 at 12:15 PM
    Troublesbowma
    Trevor
    03 tacoma
    I got bigger tires lift bumper and everything else .my brake booster feels lik not working I replaced rear shoes and turned drums adjusted to tight. Front are new rotors pads and calipers just stock.
  4. Dec 10, 2020 at 12:17 PM
    Troublesbowma
    Trevor
    03 tacoma
    Just not much braking
  5. Dec 10, 2020 at 12:21 PM
    stevesnj
    Do a pressure flush with a high quality synthetic brake fluid. That will pull out all the old fluid and the new fluid is much more stable than OEM type fluid. A pressure flush should pull the old fluid from the ABS and everywhere else a regular bleed wouldn't get. You can get one from Harbor Freight if you have an air compressor or a good mechanic/brake shop should be able to flush it for you. Did this on ,my 6k pound Land Cruiser and made a noticeable difference.
  6. Dec 10, 2020 at 12:43 PM
    Troublesbowma
    Trevor
    03 tacoma
    I have blead system numerous times. What do know bout load proportioning valve would that make whole system bad and how do u bleed that.
  7. Dec 10, 2020 at 12:47 PM
    stevesnj
    How did you bleed the system? The service manual has a specific procedure. If you didn't bleed the LSPV you didn't do it correctly.
  8. Dec 10, 2020 at 12:48 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    An extension to the LPV actuator rod is essential with a lift.
    Without it you will have NO rear braking.
  9. Dec 10, 2020 at 2:26 PM
    Troublesbowma
    Trevor
    03 tacoma
    I never got extension for lpv. And bleeding normal bleeding of system from farthest , pump 10 to 20 pumps hold pedal, releasing air or till pedal is all the way down to floor, and repeat. when do u bleed lpv
  10. Dec 10, 2020 at 2:26 PM
    Troublesbowma
    Trevor
    03 tacoma
    Thankyou for the interchange booster and master cylinders
  11. Dec 10, 2020 at 2:33 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If you get to the point of not getting better braking after correctly repositioning the LPV arm and bleeding again, look into the Tundra brake upgrade.
    https://adventuretaco.com/making-it-right-tacoma-to-tundra-brake-upgrade/
    On my 2003 I put on the OME suspension (~2" lift), a BAMF relocation bracket for the LPV and the stock brakes were crap when I was loaded up. So I did the Tundra brake upgrade with remanufactured 13WL Tundra calipers from Napa auto parts, EBC Greenstuff 7000 pads and StopTech slotted rotors. I didn't think about the braking power being weak ever again - even while loaded up.
  12. Dec 10, 2020 at 2:44 PM
    FirstGenTundra
    FirstGenTundra Well-Known Member
    Knoxville, TN
    2002 Tundra
    ICON suspension, SCS Ray 10's, Brute Force Fab bumper,
    This is hilarious for those of us with Tundra's. Probably the single biggest complaints about the 1st gen Tundra is the 13WE/WL calipers. That's good that they help the Taco's though.
    ElTaquitoJr likes this.
  13. Dec 11, 2020 at 8:54 AM
    Troublesbowma
    Trevor
    03 tacoma
    Whst steps to bleed system with lpv. And I'll get the bracket I havent done 13 wl I have everything but the brake lines. And the booster someone mentioned, does it matter on 2 or 4wd
