Brake Backing Plate
Discussion in '1st Gen. Tacomas (1995-2004)' started by glennd_05, Mar 8, 2020.
  1. Mar 8, 2020 at 9:25 AM
    glennd_05
    glennd_05 [OP] New Member
    2004 Xtra-Cab 3.4L 4x4 MT
    I have a 2004 Extra Cab 4x4 MT. I'm currently replacing the rear axle bearings and seals and the brakes on both sides. Since it is a northeastern truck, the backing plates were more rust than steel and so I am replacing those as well.
    I ordered the backing plates from Conicelli Toyota and while they arrived quickly, they don't match the backing plates I took off the truck. Specifically, the parking brake bellcrank is in a different location.
    Old backing plate, the bell crank is low and at an angle.
    New backing plate, the bell crank is high and vertical.
    This perplexed me for a while and I scoured the internet looking for the answer when I remembered the seller stating that the rear axle had been replaced. Now, I'm assuming that it was replaced with an axle from a different year. Does anyone know what year the axle is so I can get the correct backing plate and brake parts?
  2. Mar 8, 2020 at 9:28 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Somewhere on your currently installed backing plate should be a number stamped into it xxxxx-xxxxx find that and take it to the parts guy and order that specific part.
    glennd_05[OP] likes this.
  3. Mar 8, 2020 at 9:36 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    glennd_05[OP] and cruiserguy like this.
  4. Mar 8, 2020 at 9:39 AM
    glennd_05
    Just went out to the barn and looked it over and I don't see a PN stamped into the old backing plate. I even cleaned up what is left of it with a wire wheel and I don't see anything. The new one doesn't have a stamped number either though, just a sticker.
  5. Mar 8, 2020 at 9:45 AM
    CrustyTaco
    Todd
    Louisville, KY
    phx70 and glennd_05[OP] like this.
  6. Mar 8, 2020 at 9:46 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    My 02t4r 03&04 Tacomas have the type like your old one. I think the early models have it up top, not sure and Im not much help on this -
    But noticed looking recently @Kwikvette rear suspension pics, thought “he’s missing the bell cranks”
  7. Mar 8, 2020 at 9:54 AM
    glennd_05
    Looks like it is 03-04 4WD and Pre-Runner which have the low bell cranks like my originals. This is what I had ordered, which is what came up when I put in the VIN.
    @CrustyTaco I think those are the parts I need.
    Thank you all for your help.
