Box Suggestion
Discussion in 'Audio & Video' started by DannyD303, Oct 22, 2018.
  1. Oct 22, 2018 at 10:03 AM
    DannyD303
    DannyD303 [OP] Well-Known Member
    Question for the smarter people out there. Looking at adding a sub-woofer to my 17 OR DblCab non-JBL. I designed 2 different options that will go behind the 60 portion of the the bench seat.
    Red line shows a 6th order bandpass box using a JL Audio 6W3V3-4.
    Green line is ported box using a Dayton Audio UM8-22
    As you can see the 8" is a little louder but I feel like the 6" looks like it will hit lower. Not trying to win any SPL contests but we all know how these trucks need some more low end.
    Let me know which way you would go!
  2. Oct 22, 2018 at 11:28 AM
    2Loud
    2Loud Well-Known Member
    TRD Pro Grille Predator Step Tube 17" Maverick Alloy Wheels Nitto A/T Terra Grappler (265/65R17) Tri-Fold Hard Tonneau Cover with LED Lights V6 Tow Package Chrome Exhaust Tip XP Badging Stereo Pioneer AVH-X5800BHS Arc Audio 900.6 - 6 channel amplifier (4x60 watts + 1x550 watts bridged) Arc Audio 300.2 - 2 channel amplifier (2x180 watts) Hybrid Audio Technologies Clarus 1" tweeter Hybrid Audio Technologies Legatia 3.5" mids Hybrid Audio Technologies Legatia 6.5" midbass Image Dynamics IDQ10v4D2 10" DVC sub Stinger Roadkill Sound Deadner 200 AMP Circuit Breaker: Rockford 200 Amp Circuit Breaker Krystal Kable RCA Cable KnuKoncepts wiring and interconnects
    What software are you using for your plot?
  3. Oct 22, 2018 at 11:35 AM
    DannyD303
    Speakerboxlite.com
    I have WinISD at home but haven't put in all the T/S parameter for either speaker yet
    2Loud likes this.
  4. Oct 22, 2018 at 8:01 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    From a personal preference, I'd pick lower over louder. Has a lot to do with your music choices though
    DannyD303[OP] likes this.
  5. Oct 23, 2018 at 6:05 AM
    DannyD303
    That's what I'm thinking/prefer
  6. Oct 31, 2018 at 9:55 PM
    shonuff
    shonuff Well-Known Member
    07 DCab 4x4
    Although I've never had the Dayton sub I have played on as many different boxes for that JL the V2 version. The best when I came up with was about .35 sealed that thing absolutely slams! For about 2 years I had it running off a KAC-5001 amp pretty much daily the entire time I was in my truck. It took that power and smiled right back never miss a Beat and still looks and sounds fantastic. Sorry I know you weren't asking for my biography with this sub but maybe it'll help you better decide which one to run between the two
  7. Nov 1, 2018 at 9:09 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Cone area is king!
    Beyond that something doesn't add up using a seat of pants estimate. The Dayton claims SPL of 84.2 dB @ 2.83V which translates roughly to 80.7 dB at 1W/1m. The JL's sensitivity is a bit lower and power handling is half that of the Dayton's. I think we can call sensitivity a wash, but as the Ultimax will handle twice the power, it should be louder by roughly 3 dB. Considering that distortion also increases with cone excursion, I'd choose the Dayton. It isn't really fair to compare these plots either as one uses filters and one doesn't. Or is it the bandpass box shaping the response like that?
  8. Nov 1, 2018 at 10:08 AM
    DannyD303
    Both graphs are just using T/S parameters in the website. Doesn't account for any sound processing, just the enclosure. I THINK that's what you were referring to (No idea of your background so I apologize if you know a lot of this already). The YouTube video below explains 4th, 6th and even 8th order band-pass boxes pretty well.
    https://www.youtube.com/watch?v=tKMEULLaYes
    https://www.youtube.com/watch?v=kwa5EwwpZrQ
    I've been playing around with some other drivers and I was surprised when I threw the Kicker CWRT672 in the program. Looks like this speaker was designed for 6th order BP enclosures and makes the response extremely flat, louder and with a bigger bandwidth than the JL (For a lot cheaper too :D)
    Here's a similar enclosure the the one above but with the Kicker:
    I'll add the 3D rendering of the box as well:
    The biggest issue I see is using 1" ports. I think they might be a little loud with the air flow.
    Maybe this weekend I'll try putting this stuff into WinISD and see what it says there
    Thank you for your input though!
  9. Nov 1, 2018 at 10:18 AM
    rob feature
    rob feature Tacos!
    Colorado
    Yeah, I'd expect noise out of 1 inch ports too unless power is really low.
    Never actually bothered modeling one. I built a bandpass enclosure some time ago - before computer modeling software. Not sure if I did it wrong, but I hated it. Output was anemic and it sounded like garbage. And it was really tough to build. Looks like a fun project though...subbed up!
  10. Nov 14, 2018 at 9:26 AM
    DannyD303
    So I was happy with a design and started laying out the cut sheets and that's when I realized that a 6.5" driver is still too big to be placed perpendicular to the rear seats. Even using 1/2" sheets of wood there simply wasn't enough space.
    So instead of trying to build a 6th order band-pass I'm thinking I'm going to try my hand at a 6th order "bass-reflex" design.
    Basically, still using a 6.5" driver (Dayton Audio DCS165-4), I'm going to have a large vented enclosure but instead of having the vent directly into the cab, it's going to be vented into a smaller enclosure which will be vented at a different frequency.
    Playing around with Sketch-up it looks like there will be plenty of room using the entire back wall.
    Problem is I don't know how accurate my output graphs (WinISD, Bass Box 6 and Speakerboxlite.com) will be since they do not include this type of design. I tried reaching out to Pete Kuliki about the software he uses but he gave me a pretty vague answer (not really surprising but still a little disappointing).
    Hopefully this will work out and will keep this updated on what I find out.
