Box Rocket 1995 FZJ80 Build
Discussion in 'Other Builds' started by Box Rocket, Dec 8, 2014.
  1. Dec 29, 2018 at 10:12 PM
    #781
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Need some pics please
  2. Jan 17, 2019 at 11:59 AM
    #782
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I've been on an LC100 kick for a while now, but I didn't know they came in groovy purple. That makes me think a little harder.
    ThatguyNick[QUOTED] likes this.
  3. Jan 18, 2019 at 5:23 AM
    #783
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    B829D907-30AB-475E-8DFF-4C741B2828AA.jpg AD3B2EF0-266A-4DD5-B2FF-72E03F241477.jpg
    BYJOSHCOOK likes this.
  4. Jan 23, 2019 at 12:08 PM
    #784
    Box Rocket
    Box Rocket [OP] Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Still making tweaks for fitting the 37's while trying to keep flares etc intact. I started to address the bumpstops this weekend. Different suspension setups might need a slightly different solution but this will work well for the 3" Slinky suspension. Just to review, a 3" Slinky kit with 35's is an excellent combination and doesn't require a few extra mods that are necessary to run 37's. With 35's, no front bumpstop modification is necessary. With 37's, you want to have an additional 1" of bumpstop. That could be just adding a spacer to the stock inside the coil bumpstop, but there's an easier solution that doesn't require removal of the coil. The Slinky kit already comes with a 1" taller bumpstop for the rear (it measures 3.5") that is used with 35's. I got another pair of these bumpstops from Kevin at Endless Horizon Outfitters and it was a simple bolt-on bumpstop to the front frame. These add the necessary additional 1" needed to keep 37's for jamming into the wheel arches, but still maximize travel.
    Here's the taller bumpstop.
    [​IMG]Slinky Parts by Adam Tolman, on Flickr
    Bolted in place using the factory threaded holes on the frame. Note: I think '93-'94 US spec 80s have the holes but not the captured nuts in this location. the '95 and later trucks should have captured nuts. I haven't verified this 100% but this appears to be the case, so if someone with an earlier model wanted to use these bumpstops, a captured nut would need to be welded in or the bumpstop could be attached with two short welds.
    3.5" total height.
    I have had some LCP swaybar disconnect brackets installed in this same spot and I had to remove them in order to use these bumpstops. I've found that with the Slinky kit there is very little difference in wheel travel with or without the swaybar attached. But I've still liked having the brackets. One example of why they've been helpful even if I don't regularly disconnect the swaybar, is while on a trip this past summer, the swaybar bushings at the axle came apart and fell out, leaving the swaybar eye clanking around on the pin. It was nice to disconnect the swaybar and pin it up purely for the sake of not having to listen to the noise, but also so I didn't damage the eyes or the pins with no bushing in place.
    I plan to modify the brackets so that I can continue to have the option of disconnecting the swaybar.
    JKU3000 likes this.
  5. Jan 23, 2019 at 12:08 PM
    #785
    Box Rocket
    Adam
    Syracuse, Utah
    The other swaybar related thing I tackled this weekend was to replace the front swaybar spacers. I have been running a set of spacers that were on my last 80 with the OME kit. When I did the Slinky kit on my current truck it wasn't exactly purchased as the standard kit and I didn't get the f/r swaybar spacers since I already had them. The old front spacers were only 1.5" tall. They worked fine with my OME kit, but with the Slinky kit they have resulted in some contact with my DC front driveshaft at full droop. So I picked up a set of the spacers that are part of the Slinky kit to replace my old ones.
    Old vs new.
    where the swaybar has contacted the driveshaft. Not a big deal since it's just the dust cap but a good thing to take care of.
    la0d0g likes this.
  6. Jan 23, 2019 at 12:09 PM
    #786
    Box Rocket
    Adam
    Syracuse, Utah
    OK last piece of the puzzle regarding bumpstops. I got a full set of bumpstops from Timbren. I've heard good feedback from @woody and others who have Timbrens and since woody also has the Slinky suspension I was particularly interested in his opinion of them. He's a fan, so I got some to address the rear, but was also sent a pair for the front if I want to try them. Here's what I got from Timbren.
    The short ones are the fronts. They would need to have the bracket trimmed a little so that they don't contact the coil during compression. But when compressed they should be the same height as the Slinky bumpstops I just installed so if I decide to use these they should work fairly easily.
    Front:
    The rears are another story. I don't know how Timbren is designing these for the rear with that massive bracket. Even with a 6" lift these would be too tall. But at least its a simple cut and weld to shorten the brackets. These also would need to be trimmed to not contact the spring and tire in the rear but I can get these set to add the additional 1" to the rear for the 37's. My initial calculations end up with a bracket that's roughly 1.5" tall. I'll post an update when I get them modified and proper fitment is confirmed.
    Rear:
    jubei and la0d0g like this.
  7. Jan 23, 2019 at 12:09 PM
    #787
    Box Rocket
    Adam
    Syracuse, Utah
    After the bumpstops are sorted, the last step will be to relocate the front axle ~1.5" forward. I plan to do this using the method Darren McRae has been using in Australia for some time now with the Slinky kits and factory radius arms. New plates are welded in to the frame bracket for the radius arms and new holes drilled farther forward. These will give better tire clearance at the firewall. Don't want to move it to far or there are clearance issues with the front panhard.
    [​IMG]RadiusArmPlates by Adam Tolman, on Flickr
    Nimble9, la0d0g and duvinclunk like this.
  8. Jan 25, 2019 at 8:03 AM
    #788
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Once you've completed that, we're gonna do a trade, right?
    You keep putting this off....and I feel bad (a little) because you're getting a stock 3rd gen runner....
    duvinclunk likes this.
  9. Jan 25, 2019 at 11:09 AM
    #789
    Box Rocket
    Adam
    Syracuse, Utah
    I'm afraid I work really slow so this could take a while before I'm ready for the trade.
  10. Jan 28, 2019 at 12:59 PM
    #790
    Box Rocket
    Adam
    Syracuse, Utah
    Saturday was spent doing my front axle relocation to improve tire/firewall clearance. Not a terrible job but maybe a bit slow because of my mostly basic tool set. EHO did not have any of the bracket plates on hand so I made my own from some 3/16 plate I had on hand.
    Tools needed:
    Angle Grinder with cutoff wheel to cut the plates.
    18mm drill bit to drill the plates and frame brackets
    22mm, 24mm sockets for the radius arm bolts.
    Jackstands.
    Hammer/drift to knock bolts out if they don't just slide out.
    Antisieze for the bolts
    Welder.
    Moved the axle 30mm forward (~1.25"). Drove it around town Saturday night, and 200 miles on the highway yesterday. No change in driving behavior (as expected) but an improvement in tire clearance. This is a worth while mod to help fit larger tires (37s or larger) to minimize the amount of fender/flare trimming. There is still a bit of trimming but nothing extreme so far. Still need to do a full stuff flex test but I think I'm just about there with proper 37"tire fitment with the 3" Slinky kit.
    [​IMG]Axle relocation by Adam Tolman, on Flickr
    It was getting late and I still had a date with my wife so I didn't take additional pics of the welding process and only snapped one pic after it was all buttoned up. Fresh paint makes my welds look worse than they actually were, oh well.
    Coils are nice and straight now instead of the slight curve to the rear that you get with stock radius arms on a lifted 80.
    NYCO likes this.
  11. Feb 5, 2019 at 1:10 PM
    #791
    Box Rocket
    Adam
    Syracuse, Utah
    Here's a bit more info as I find my way through the rabbit hole. Used the ramp at a local shop to check for tire clearance and get better bumpstop measurements. First off, the truck will go quite a bit farther up the ramp but I stopped where the tires were making contact so I can see where I may need to do a bit more trimming or spacing of the bumpstops.
    The rear tires seem to be stuffing pretty well for the most part. As a reminder I have longer lower links (11mm) and 1.5" wheel spacers installed. The rear axle is centered well at ride height but because of longer lower links the tire moves to the rear as the suspension compresses. Even with the spacers it looks like it's going to tuck inside the wheel arch. I will still trim a bit of the flare, especially at the rear of the wheel arch. I think I will also trim a bit of the fender lip at the top of the wheel arch and some of the flare.
    [​IMG]Bumpstops by Adam Tolman, on Flickr
    As mentioned the suspension will still compress farther in the rear, but at this point on the ramp (front tires were rubbing) there was ~4" of space between the frame bumpstop and the rear axle. My best guess at this point until I can trim up the front a bit is that a 5.5" rear bumpstop should be about right. We'll see how close my guess is at the next test.
    [​IMG]Bumpstop measurements by Adam Tolman, on Flickr
    The front is a little different story. The axle relocation mod looks to be very effective in improving tire clearance at the firewall. As the suspension compresses the arc of the radius arm pushes the tire forward for even better clearance when stuffed. However, it also causes some contact at the front of the wheel arch. I'm going to need to trim the bumper wings a little and do a little surgical hammer work to the inner fender in the front. The inside edge of the flare will get trimmed some, but I don't see anything too extreme to get this all sorted. Again, still lots of travel available in the suspension once I get the proper tire clearance.
    More to come.
    Genypig and BYJOSHCOOK like this.
  12. Feb 5, 2019 at 1:11 PM
    #792
    Box Rocket
    Adam
    Syracuse, Utah
    BYJOSHCOOK, la0d0g and duvinclunk like this.
  13. Feb 5, 2019 at 1:27 PM
    #793
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Nice! I need to find a ramp somewhere close where I can really get a flex on to figure out what needs trimming. Having trouble getting mine to compress entirely with more mellow loading ramps locally and haven't ventured offroad yet with the snow and cold. Truck is looking good with those 37's though!
  14. Feb 5, 2019 at 1:32 PM
    #794
    Box Rocket
    Adam
    Syracuse, Utah
    Thanks. There's a lot of travel left in the suspension, just gotta create the room for the tires. Don't want to add more lift. I love the height of the truck. Most guys with 37's have 4-6" of lift, I used to have almost 6" too. But I love how the truck behaves with the 3" lift and with these tires it feels great. Just a bit more "massaging" and things will be good.
  15. Feb 5, 2019 at 1:35 PM
    #795
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Agreed. I always appreciate the least lift with biggest tire concept.
  16. Feb 25, 2019 at 4:19 PM
    #796
    Box Rocket
    Adam
    Syracuse, Utah
    I've needed a second swingout for my rear bumper for a while and I finally got to working on it the past weekend. Using a Ruffstuff hinge kit. Spindle is in place and passes through the entire bumper, welded to the top and bottom. Main arm is done with a small bend to batch profile of the bumper. Simple pocket on the end of the new arm to fit the old arm so I don't need to add another latch. Should finish it up tomorrow.
    [​IMG]Untitled by Adam Tolman, on Flickr
    Don't mind the heavy layer of salt on the truck. We had a bit of snow this week and the salt trucks were out in force.
    Not a great pic but you can kinda see the the spindle just through the bottom of the bumper.
    2.5" square 1/4" wall for main arm. Didn't get a pic of doing the bend, but it was just a cut through 3 sides and weld it up.
    "Stop" welded to the bottom of the arm to match the other arm and a pocket on the end.
    Acerwin, la0d0g, Clark27 and 3 others like this.
  17. Feb 25, 2019 at 4:20 PM
    #797
    Box Rocket
    Adam
    Syracuse, Utah
    All finished up. Pretty simple setup overall to tide me over until I get a Delta bumper. Single fuel can basket (with room for a second if needed), hilift, shovel.
    I replaced the gas struts on my lift gate a few weeks ago and the old ones still work well enough that I re-purposed them for the swingouts.
    [​IMG]Bumper by Adam Tolman, on Flickr
    All done.
    Genypig, NYCO, la0d0g and 10 others like this.
  18. Mar 15, 2019 at 10:12 AM
    #798
    Roll Tide
    Q
    01 T4R
    Ok look. I'm not sure I even want this thing anymore....
    You better hurry up and send it to me, as I'm getting really close to changing my mind.
    Box Rocket[OP] likes this.
  19. Mar 19, 2019 at 6:23 AM
    #799
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    looking good Adam :thumbsup:
  20. Mar 19, 2019 at 9:43 AM
    #800
    Box Rocket
    Adam
    Syracuse, Utah
    Thanks Bob.
