Bouncy after front suspension replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chestytaco, Dec 23, 2021.
  1. Dec 23, 2021 at 7:52 AM
    Chestytaco
    Chestytaco [OP] Member
    2019 Silver V6 Tacoma SR 4x4
    none yet, but do I intend to change that
    I recently did the following:
    -Installed DK LCA and UCA
    -Rebuilt Fox 2.5 Ext travel shocks up front and swapped old coil for a new 14" by 600# eibach coil; roughly 2 in of threads showing for the preload.
    -new KO2 load C tires at 32 PSI
    My truck has been riding rough, where I feel every bump on the road to the point it's been giving me a headached. I understand that the Derlin bushings are much less forgiving than the stock bushings but it feels excessive. I have also been told the new coils need a good amount to break in/soften up.
    How could I tell I'd somethings wrong or if that's just how it's gonna be from now on?
  2. Dec 23, 2021 at 12:15 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I bet the coils will soften up. Especially you go out and off-road and give that suspension a work out
    Junkhead and tclavell like this.
  3. Dec 23, 2021 at 12:18 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Back off the preload a bit, or measure your hub to fender distance. Could be pretty topped out height wise
    twitchhero likes this.
  4. Dec 23, 2021 at 12:40 PM
    Chestytaco
    Plan on taking to the desert this weekend for that exact reason. I shouldn't be, im sitting just shy of 22" hub to fender.
    71tattooguy likes this.
  5. Dec 23, 2021 at 12:42 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Have you had the shocks tuned? If so, on road will usually be stiffer, but thats what you need for offroad performance compaired to factory valving.
  6. Dec 23, 2021 at 12:51 PM
    Chestytaco
    Not that I know of, just a rebuild. I was hearing that tuning may help smooth it out though?
  7. Dec 23, 2021 at 1:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m skeptical that coil springs soften up a noticeable amount in such a short time. Depending on what tires you had before the new LT tires could be the culprit. They ride harsher than P rated tires. Have you measured your down travel? Too little down travel can cause issues.
  8. Dec 23, 2021 at 1:23 PM
    Chestytaco
    The tires prior were falken wild peaks. How would you measure down travel
  9. Dec 23, 2021 at 1:24 PM
    Chestytaco
    Falken Wildpeak AT3W in SL
  10. Dec 23, 2021 at 1:29 PM
    gudujarlson
    Minnesota
  11. Dec 23, 2021 at 1:32 PM
    gudujarlson
    Minnesota
    You are probably feeling the difference in tires. You can feel small imperfections in the road more with LT tires compared to P tires. Throw the old tires back on and see how it feels.
    Lt. Dangle and msgs350 like this.
  12. Dec 23, 2021 at 1:56 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    I had a bouncy ride too when I first installed my new suspension, it softened up after a while though. I don’t recall how long that took, a few hundred miles maybe? I did several slightly maintained trails that probably helped it along too.
    I would consistently check that everything is secure and tight, obviously if something looks out of place address that, but give it some time and see if they smooth out.
    EDIT: Delrin bushes are a bold move, I installed all poly bushes and I pretty much hate them at this point :rofl: even after installing extra zerk fittings.
  13. Dec 23, 2021 at 1:59 PM
    gudujarlson
    Minnesota
    Are you sure you didn’t just get used to it? I can’t think of any theoretical reason that the suspension would soften up with a small amount of use. Steel has good fatigue resistance (tolerance to repeated load-unload cycling) and that’s why springs are made out of steel as opposed to aluminum or something else.
  14. Dec 23, 2021 at 2:03 PM
    Chestytaco
    Would if I could, but discount tire has them now.
    Called discount tire and they are gonna be able to take back the KO2s and install the falkens for no charge. I'm glad you mentioned that because if I waited until next week, I would have passed the 30 day guarantee.
    Falken QA likes this.
  15. Dec 23, 2021 at 2:03 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    Positive, it was a weird distinctive kind of bounce. It went away for sure.
  16. Dec 23, 2021 at 2:06 PM
    gudujarlson
    Minnesota
    Did you perhaps change your tire air pressure?
  17. Dec 23, 2021 at 3:09 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I can back this up with empirical experience. Even the cheapest coil springs don't soften up or lose rate over time or with use. What they do do is lose free length and take a "set" so the rate will not noticeably change, but the height may.
    Over time you are either loosening up bushings, losing a tad of ride height, or getting used to it.
  18. Dec 23, 2021 at 3:17 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    So everyone saying coils soften up is BS ?
  19. Dec 23, 2021 at 3:21 PM
    ShimStack
    Ben
    NC
    Technically, yes. That's not to say items in the suspension don't settle into each other and free up over time but coils don't typically get softer but they can lose free height.
    71tattooguy[QUOTED] likes this.
  20. Dec 23, 2021 at 3:39 PM
    gudujarlson
    Minnesota
    Thanks. I’ve been googling trying to find an explanation for the “settling” and “breaking in” phenomena that people often refer to. The joints and bushings came to mind, but intuitively it seems like it must be a small effect.
