Bottle Jacks
Discussion in 'Recovery' started by eddyizm, Dec 25, 2018.
  1. Dec 25, 2018 at 5:09 PM
    eddyizm
    eddyizm [OP] Well-Known Member
    2018 TRD OR DCSB 4x4 Cement
    I am looking at getting a set of bottle jacks to compliment the stock jack and was wondering if anyone has picked up the harbor freight ones?
    What do you guys use for base plates? Thinking 2x2 wood would be easy but I have seem some of the nicer base plates.
    4 ton and 8 ton
  2. Dec 31, 2018 at 2:33 AM
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    I used to keep lots of chunks of wood in the bed of my truck when I was a carpenter and had a monthly if not weekly nail. I found that a piece of 4x4 about 2' long really useful for my 1 1/2 ton floor jack. The jack would straddle the 4x along the long axis and had 2x the footprint. If using a bottle jack i would look for a few 1' square piece of subfloor and 2x12maybe even some 1/2 hardwood ply from a cabinet shop. use them in different combinations to get close to starting height so you can use the full stroke. Use a small shovel to level a bed before you start. My jack was a harbor freight too. Lasted about 10 unmaintained years before it puked its oil. Plus it's good wood if you get really stuck
    eddyizm[OP] likes this.
  3. Dec 31, 2018 at 1:49 PM
    Lunchmeat79
    Kansas
    '18 Off Road
    MoTacoX likes this.
  4. Jan 1, 2019 at 9:16 PM
    eddyizm
    Cool. I ended up picking up the 8-ton to compliment the stock jack. Thanks for the wood suggestions, I was guessing along those same routes but appreciate the confirmation. That Alltrade looks solid.
  5. Jan 2, 2019 at 2:52 PM
    MoTacoX
    MoTacoX Well-Known Member
  6. Jan 15, 2019 at 10:12 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A “set” of bottle jacks??
    You only need one...
    But you don’t really need one to compliment your stock jack. They do essentially the same thing, you can just replace the stock one, if you wanted.
    Personally, I’d rather have a jack that can do more than just lift an axle off the ground. Bottle jacks are great, but have a fairly limited use. Ymmv
