Bottle Jack - Anyone actually needed to use it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Janster, May 22, 2012.
  1. May 22, 2012 at 5:29 AM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Has anyone actually needed to use their bottle jack for an emergency tire change?
    So, yesterday..... something about 12" flat and probably metal.... went bouncing around in front of me and I could only swerve enough to hit it with my passenger side (tire) of the truck. I thought I was in the clear.... until the TPMS light came on. Got off the highway and found a parking lot.... front passenger side tire went completely flat as I got out of the truck.
    I've changed many tires but never using this cheesy bottle jack and setup they give you. My fault for not having a flashlight - took a bit to aim the hook to get the jack down. Durr... I'm a girl, so I'm not all that strong. Had to rig up some origame with the kit to get leverage to loosen the lug nuts. Again - my fault...I used to carry a cheater bar in the truck. Durr...
    So...wheel is on the ground. I get the bottle jack under the frame and start cranking. It lifts the truck up about 1/2" and stops....I'm cranking and cranking and cranking and nothing is happening?? WTF???
    The main shaft was out entirely and the outter sleeve just barely sticking out.... What was I missing?
    Husband works only a mile from where I was. He picked me up and we drove home (3 miles) to get the floor jack.
    I came home and manually cranked the bottle jack up - and it went up another 2". Tried to lift the truck with it this morning and it barely lifted it...but damn, not sure I'd trust to use this thing if I had to!!
    And what's up with the spare tire wheel not being 'compatible' with the lug nuts??
    Ok...rant off. New tire is on order - sucks. My tires only have 8000 miles on them (Dueller Revo). It has a slice in it about 1.5" long.
    Thoughts? Insight? Lol
  2. May 22, 2012 at 5:36 AM
    Uglydog
    Uglydog Member
    Oregon
    stock 4x4
    I changed rims on my truck, I had better throw in a set of lug nuts and hope the jack works if needed.
  3. May 22, 2012 at 5:46 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    I use a bottle jack often, but not the one that comes with the truck. I like floor jacks also but sometimes bottle jacks are more portable and easier to fit in small ares. I dont think i have ever touched the one that comes with the truck ( i assume its simply for emergency use, not exactly intended for routine maintenance) .
    Agreed the one that comes with the truck is next to garbage. I literally have a floor jack in the back of my cab now with a bunch or baords and other shit necessary for tire change
  4. May 22, 2012 at 5:54 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yeah Jan it is an interesting setup pretty much unchanged by toyota.
    It reminds to check on the tundras setup for it is the same bottle jack!
    I have used the them on the trailer.
    For years I kept a had a wood block with a recessed area for the jack's base to give it some lift in case of an emergency tote.
    Also a gorilla extend bar for cracking the lugs. I have recently added a headlamp just in case.
    I am overly ocd when it comes to my kit lol....
    Being in the northeast, it was customary for the cranking mechanism to corrode which, even with the best of maintenance.
    I had two cut off on my previous toyota trucks.
    Great report on the tpms doing its job. Sorry to hear about the tire.
    SR-71A likes this.
  5. May 22, 2012 at 8:49 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I don't usually like the OEM jacks that come with vehicles these days so i replaced the stock jack for a 8 ton bottle jack from Canadian Tire. Fits perfectly in the same spot but much more heavy duty. For $30 or less i'd recommend the same thing to anyone.
  6. May 22, 2012 at 9:06 AM
    OnTheTrail
    OnTheTrail Well-Known Member
    San Jose, CA
    2006 TRD Offroad
    I used it once to change a flat front tire. That little jack extended just enough to lift the tire off the ground and get the job done. It looks small and cheap but it worked for me.
    gkomo likes this.
  7. May 22, 2012 at 9:11 AM
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    I used it to help me install my sliders. Seemed to work ok, didn't have any problems :notsure:
  8. May 22, 2012 at 9:16 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Hmmmm, never had to use mine yet, knock on wood, but now I want to try it! And what do you mean the lug nuts are not compatible with the spare? Just curious, as I don't want to be stuck anywhere.
    I think its sad on any car/truck you buy these days, they really cheap out on the jacks for changing a flat.
  9. May 22, 2012 at 9:17 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    @Janster: where are you jacking the truck from? For single front tire change, jack from the LCA, not from the chassis jacking point. This way the jack only has to extend a little for the tire to come off the ground, without having to take up all the suspension droop travel. For the rear, jack from the diff pumpkin housing.
  10. May 22, 2012 at 9:18 AM
    KenLyns
    Belly of the Beast
    BTW, take a look at the newest Prius models the next time you are at the dealer. Due to the bulk of the battery pack, the spare tire has been eliminated. All you get is tire sealant and a small electric pump.
  11. May 22, 2012 at 9:20 AM
    Uplander
    Uplander Active Member
    Idaho
    2012 Barcelona Red DCLB Sport
    TRD Supercharger, URD 2.825" Pulley, TRD Exhaust, Moroso Catch Can, MB Chaos Wheels, 265/65/17 Hankook Dynapro's, 5100's @ .85", ARE MX Topper W/BedRug
    I was able to use mine in the garage to swap all 4 wheels. I'd imagine in an offroad situation or with oversized tires it would be virtually useless.
  12. May 22, 2012 at 9:22 AM
    KenLyns
    Belly of the Beast
    ^I can confirm it still works with 32" tires. Off road, a hi-lift or inflatable cushion should be mandatory.
  13. May 22, 2012 at 11:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It has worked a few times for me.
  14. May 22, 2012 at 11:12 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I used it to push out my stock fenders :D
    SR-71A likes this.
  15. May 22, 2012 at 11:13 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It only works on the LCA which is scary. I need to mount the hi lift in the bed so I can use that.
    I've never had a flat in the Tacoma by the way, but I have tried the worthless jack.
  16. May 22, 2012 at 11:15 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I used it when I was inspecting the truck pre-purchase jacking up all corners as the manual said to but that's it. Knock on wood no flats yet.
  17. May 22, 2012 at 11:23 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    We used the bottle jack on a recent leaf pack install to flex the springs away from the truck so we could line up mounting bolts. I think that's about all it's good for on a lifted truck. Stock trucks, use the LCA or pumpkin like stated above.
  18. May 22, 2012 at 11:33 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    It works fine on all the lift points stated in the manual. Lift should have no impact on the front, unless you have a lift with more down travel. Use 2x10"s under the jack equal to the height of the lift for the rear. That is, if you don't feel like buying a new jack.
  19. May 22, 2012 at 11:55 AM
    Janster
    Jandy
    Lancaster, PA
    Yeah Judy...I was thinking the same thing (Tundra Jack)!! Can you imagine using that thing on a Tundra? :eek:
    Ken, I was using the frame mounting point. I thought about using the LCA - but decided against it. I didn't like the surface area I would've had to work with PLUS the small 1.5" nub on the end of the bottle jack..... slippage....
    I wasn't in a dire emergency. Help was only a few miles away.
    I don't know if this jack had a 'hiccup' or what. As soon as it reached the max lift amount on the inner shaft, it wasn't moving the outter sleeve at all. But yet, when I did it at home under no pressure....it worked. I'll have to try this tomorrow when I get my new tire back....tomorrow.
    Deevon, The Lug nuts for the stock wheels (SPORT wheels) are conical. And perhaps that's specific to alluminum wheels/centering. The stock steal wheels are flat. Just feels WRONG to torque a conical lug nut on a flat surface. Thank God the spare will only be on the truck for a day......
    Gylar,
    What's the specs on that bottle jack? Total height? Even Harbor Freight has some pretty beefy 20 ton bottle jack for $40 - max height 18". I don't even know what the stock bottle jack goes to....I should measure it. Not a bad idea......You could sell the stock one for $40 on ebay! ;)
  20. May 22, 2012 at 12:03 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Not trying to call you stupid, but I assume the spare is on the correct way? My owners manual shows that the spare has the same conical type of lug holes.
