Both reverse lights out
Discussion in 'Technical Chat' started by boshak, May 22, 2012.
  1. May 22, 2012 at 2:46 PM
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Not sure how long they've been out but noticed last night.
    Checked continuity on the following and all seem to be okay: bulbs and connections, 15 fuse, switch on transmission (no continuity when free, continuity when pushed per FSM).
    What else can this be?
  2. May 23, 2012 at 6:46 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :D Tony, since you checked for continuity at the switch and the fuze. the next area to check is the sockets in the rear. Use your meter and see if you have power going to the sockets with the truck in reverse. You know not to start it up,but turn the key to ON and put the truck into reverse with the emergency brake applied. If you have power going to the rear, then you have a ground wire problem. If you don't show power coming to the rear then you have a broken wire somewhere from the dash to the tail gate area. Good Luck.
  3. May 23, 2012 at 10:49 PM
    boshak
    AG
    CA
    Checking sockets for continuity or for voltage? Im obviously a newb... Just learning electrical as we speak :)
  4. May 23, 2012 at 10:59 PM
    boshak
    AG
    CA
    Edit: I am watching tutorials on multimeters and how electricity works. I'll come back when I have clear questions.
  5. Sep 17, 2012 at 10:24 PM
    boshak
    AG
    CA
    Update: The reverse lights turned back on randomly right after I originally posted this but now lights are intermittent.
    I can now tell that it has to somehow do with the transmission. Is there a switch in the reverse slot? Sometimes I can jiggle it or move it halfway into reverse and the lights turn on. Any ideas on how to fix this?
  6. Sep 18, 2012 at 6:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    As said above, the switch cab be found here..
    Pass side of the tranny... You can unplug the switch and jump the terminals. That should Illuminate the switch (with ignition ON).
    Here is the circuit for the back up lights. You can see they share a ground which would make both lights not work, as said above, if the ground was faulty.
  7. Sep 18, 2012 at 7:55 AM
    shemp
    shemp Well-Known Member
    Intermittent lights could indicate poor contact between the bulbs and the sockets. Clean the bulbs and sockets using an abrasive to remove all oxides, apply dielectric grease liberally, reinsert bulbs.
    Also make sure that any springs or springy contacts aren't bent/worn and actually apply adequate force against the bulb to make proper contact.
    Hope this simple solution works for you. If not, you'll have to inspect wiring and relays.
  8. Sep 26, 2012 at 4:57 PM
    boshak
    AG
    CA
    Thanks guys! I didn't get a notification you replied but I got it fixed for now.
    I removed the switch, tested continuity... still good. Noticed all parts were dirty so I sprayed the switch and connectors with MAF cleaner. Reinstalled and works again! If it starts acting up, I'll get a new switch. Dealer quoted me $28 for a new one.
    Thanks again!!!
