Both Door Handles Broken on the Outside
Discussion in '1st Gen. Tacomas (1995-2004)' started by mypoortruck, Jan 4, 2022.
  1. Jan 4, 2022 at 1:31 PM
    mypoortruck
    mypoortruck [OP] New Member
    03 Tacoma
    Both of the door handles on my 03 Tacoma are broken from the outside due to ice and now I can't get in. Both doors are unlocked (I have the keys) but both of the handles are loose. The passenger door broke last week and I ordered a new one, but it hasn't arrived to replace it, but now the driver side broke and I have no way in. Is there a way to get in without breaking a window?
    Help!
  2. Jan 4, 2022 at 1:36 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    If you have a rear slider the latch is easy to pop from the outside so you can pull the inside handle with a coat hanger.
    Good luck:fingerscrossed:
  3. Jan 4, 2022 at 1:40 PM
    Archaic2021
    Archaic2021 Well-Known Member
    I really need to stop procrastinating and replace the passenger side handle on my truck...if the driver side breaks im in the same situation. I have done had the door not latch properly and squezz myself through the back glass to reach the handle with a rod.
    Yeah if you have a back slide glass...very small screwdriver or knife...slide it in where the latch is...one good little tap should unlatch it.
    Rachelsdaddy likes this.
  4. Jan 4, 2022 at 1:41 PM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    that sucks, my passenger handle was broken for a bit and i was worried that would happen to me. can you get a shoelace through the door crack at the top, loop the inside handle and pull it? a metal hanger may also work if you can't get the shoelace in by flossing it into the top corner of the door
  5. Jan 4, 2022 at 1:50 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    First off, If you are in a situation that you need to get in your truck ASAP, call AAA.
    Secondly, having tried various methods to get into my truck, you're almost always going to scratch something unless you have the right tools (see AAA above).
    If you got in now, leave a window open? I hope you have a garage...
  6. Jan 4, 2022 at 2:46 PM
    mypoortruck
    03 Tacoma
    Thanks everyone for your suggestions, calling roadside assistance to try first. I luckily do have a garage so I'll just leave the windows down in the garage to reach in and open the doors if the help I get actually works.
  7. Jan 4, 2022 at 2:53 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Once you get the doors open, replace the handles right away. It's a simple process, but you probably want to pick up some extra door panel clips because they tend to break when you remove the door panel. I've had to replace mine a few times and it just takes maybe 20 min once you know the process, super easy.
    I've always been afraid of this happening when one of mine breaks so I usually try to do it right away. I agree with the rear slider window option, it's pretty easy to pop open from the outside. Then use something long to reach in and pull the handle.
    Superdave1.0 and mypoortruck[OP] like this.
  8. Jan 4, 2022 at 3:02 PM
    JerZ1980
    JerZ1980 Member
    98 Tacoma 2.7 4x4
    Look under the door latch. Mine broke at a spot where I still had enough of a tab left to open by getting a screwdriver under it to work it with that.
    Superdave1.0 likes this.
  9. Jan 4, 2022 at 3:13 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Break off the outside handle since Im assuming it's worthless if it's broke where I think it is. Then drill a small pilot hole in the part that broke, screw a screw in, then use pliers to pull the latch via the screw
    Edit: if it'll help I can literally go demonstrate via video right now since I have a broken handle and spare I need to install
    JerZ1980 likes this.
  10. Jan 4, 2022 at 3:15 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Buy a lockout/break in set and never have to worry again. Might only use it once but it's nice to have. Otherwise call some roadside assistance to break into the truck for you, then completely remove one of the handles for the time being.
    tcjacado likes this.
  11. Jan 4, 2022 at 3:22 PM
    JerZ1980
    JerZ1980 Member
    98 Tacoma 2.7 4x4
    My passenger handle is broken and I have the spare behind the seat. I think I'm going to go put it in now.
    otis24 and mypoortruck[OP] like this.
  12. Jan 4, 2022 at 4:07 PM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    I would love to see it. I see how that would help down the road when someone is in a sh*t situation and doesn't have time to wait for responses
  13. Jan 4, 2022 at 4:34 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
  14. Jan 4, 2022 at 4:35 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    K, uploading it now to youtube
    Trowbocop[QUOTED] likes this.
  15. Jan 4, 2022 at 4:56 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have learned that lesson if the door is frozen closed yanking on the handle will only break the handle
    I put enough pressure on the handle to release the door and pry the door open with a flat screw driver .
    If it is really froze I break out the heat Gun.
    Breaking one long ago on a Celica cured me of the yanking
    mypoortruck[OP] likes this.
  16. Jan 4, 2022 at 5:25 PM
    treyus30
    Trey
    Mesa / AJ, AZ
  17. Jan 4, 2022 at 5:58 PM
    mypoortruck
    03 Tacoma
    I got in thanks to calling roadside assistance and they came with those blow up tools to get a rod in there and open the door from the inside. Now just need to replace both and be better about not pulling on the handle in icy weather!
    Thanks again for the suggestions!
    JerZ1980 and Black DOG Lila like this.
  18. Jan 4, 2022 at 7:43 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Dude. +1000 internet points.
    treyus30[QUOTED] likes this.
  19. Jan 4, 2022 at 7:44 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    *tips fedora*
  20. Jan 4, 2022 at 7:54 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Duh, if one is broke, likely the other will soon. Now you know. JerZ do it now.
