Bosch LSU 4.9 PN cross reference and compatibility
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Jul 19, 2017.
  1. Jul 19, 2017 at 6:04 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    After a failed trip to my local Autozone to pick up a new Bosch LSU 4.9 sensor, I begun doing some research, which like usual led to heavier research than I initially intended on doing so. This thread is purely for informative purposes on all the different options available from the different AFR sensor manufacturers which utilize the Bosch LSU 4.9 style technology and connector.
    I have been having issues with my 4.9 sensor lately and will be swapping out to a Denso because in the past I have replaced 2 4.2 style sensors, and now I will be on my 2nd 4.9 sensor, so I'm done with Bosch. If you would like to swap yours out to a different manufacturer because you are having issues, I have supplied all the different part numbers available that I am aware of which should work with your AFR gauge. Longevity of listed sensors may vary.
    Denso:
    - 234-5102
    - 234-5116
    - 234-5119
    - 234-5125
    - 234-5136
    - 234-5137 (38.66 long)
    - 234-5138
    - 234-5139
    NTK (made by NGK):
    - 24315 (39.3" long)
    - 24323 (35.5" long)
    - 24324 (33.5" long)
    - 24325 (15.8" long)
    - 24328 (29.5" long)
    - 24326 (28.5" long)
    - 24329 (14.8" long)
    - 24330 (21.8" long)
    - 24333 (41.5" long)
    AC Delco (high possibility exists that they are made by Denso):
    - 213-3934
    - 213-3936
    Again, bear in mind, longevity will and may vary, but these are all the part numbers on record which are cross compatible with the original style Bosch LSU 4.9 style type AFR sensor/ connector. The prices vary WILDLY I found between all of the different part numbers, as does wiring length, but if you want the cheapest priced one, you will find the 234-5116 on Amazon for $75.42 right now. The one I chose for myself was the Denso 234-5137, as the wiring appears to be much shorter.
  2. Jul 21, 2017 at 7:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just as a follow up update to this thread I received the sensor today (234-5137 Denso) and the plug is the perfect shape of the old Bosch 4.9 sensor. Wiring is a few inches shorter, which is actually good because then there is less need to zip tie excess. Upon inspection I noticed a small little leg inside of the plug itself that would hinder me from installing it into the AEM connector for the gauge. I took a small screwdriver (you may use needle nose pliers if they are fine point enough to fit) and carefully massaged the leg back and forth until I fatigued the plastic to break it off at the base. Just watch the pin by it otherwise you could bend it out of place and will have to bend it back. After doing that the sensor plugged in perfectly and locked into place just like original.
    If you receive a sensor like this, you may find the same thing in your plug or not but at least you know what to do now. This update is to make you aware, and to confirm YES it WILL WORK fine with the AEM gauge. I now am able to actively monitor Air Fuel Ratios once again, and maybe it is just me, but the sensor seems to work BETTER than the old Bosch 4.9 ever did.
    BassAckwards, garciav, Norton and 3 others like this.
  3. Jan 9, 2018 at 9:52 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Update on the longevity of the of your new sensor? The Bosch 4.9 sensor only lasted me 5 months.
    12TRDTacoma[OP] and Mech_Eng like this.
  4. Jan 9, 2018 at 10:13 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    You get a 1 year warranty at AutoZone if you use one of the above mentioned sensors. Just exchange it annually, which is actually about as long as they last anyway in a turbo application.
  5. Jan 9, 2018 at 10:46 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Still working as amazingly as it did from say one. Bosch sensors are horrible and Japanese cars tend to break them for some reason. This Denso sensor has been great to me.
    Norton and mightytacoman[QUOTED] like this.
  6. Apr 29, 2018 at 3:16 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Are all the sensor plugs the same for all guages. I thought I read somewhere that Innovate has special plugs on theirs to keep you buying their overpriced Bosch sensor? I mean if they are all "about" the same and all I need to do is knock off a tab I am definitely getting a Denso sensor. Do you happen to have any pictures of your sensor plug, either sensor or guage end for you AEM?
  7. Apr 29, 2018 at 5:50 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Figures. I was just about to order one.
  8. Apr 30, 2018 at 10:07 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Doing plug research over the next few days. Gotta get through month end paperwork and long hours first. But I need to find an answer to if my AFR's are correct or not. If they are I need to stay out of boost before I end up washing my cylinders and having to put a motor in my truck. But why not, I just did a transmission and 4.88's and front ARB. Why not a new motor too. LOL But I can't make myself cut my losses and just get a Tundra. Too much money into this truck and I did the same thing with my '98 Taco.
  9. May 1, 2018 at 2:09 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    What's the question here ^
  10. May 1, 2018 at 2:18 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    That is in reference to the earlier question about A/F sensor plugs. I am going to do some research to see if I can find a Denso sensor that will plug into the Innovate guage. So the real question is are the plugs the same for all the guages or does the AEM have one plug while the Innovate has a different plug. The OP lists lots of sensors, and he said what one he used with his AEM. I need to know if they will work with my Innovate MTX.
  11. Jun 25, 2018 at 5:19 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    I think I am going to order the NTK 24324 sensor. Need to measure and see what I have for length now as it is about 6" short of being convenient to plug in and unplug to calibrate the gauge. Awful zone has it for $116. And one thing I have found that I don't care for is that the dense numbers never tell you the length of the wire. And they seem to cross with 2 or 3 other NTK numbers that all have different length wire so I am not sure which one is the actual cross and has the same length wire as the Denso. But the NTK 24324 has 33.5" of wire and crosses to many of the Denso numbers. And for some reason, the longer the wire, the less my cost seems to be. The most expensive one I have found has a 15" wire and the least expensive is 57" of wires. I am going to go with a longer wire so the plug isn't right at the firewall and hard to get to. I have no problem having the plug in the engine bay where it is easy to get to.
  12. Jul 7, 2018 at 6:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I cannot say one way or another if the Innovate plugs are special as I only ever used an MTX with a LSU 4.2 design plug, but I'll tell you right now, the AEM ones can use universal AFR sensors as long as the plugs are the same. In this case, the one I got had a small tang inside of the plug on the sensor that needed breaking off, easy to remove with a little screwdriver or tiny needle nose pliers.
    I do not have a picture of the plug but I am sure I can get one in time. Have you already bought an AFR sensor? Gotta tag me in your posts or quote me if you want me to reply back, otherwise I don't always get notices that you have posted with a question for me. :)
    Biscuits likes this.
  13. Jul 10, 2018 at 7:30 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    @12TRDTacoma All good on the response time. I get slightly backed up with work and the personal truck projects get put off to the side. As for the AFR sensor. I am about 98% that any of the sensors you listed will work also. I have not ordered it yet as all of my vendors seem to be higher priced that Amazon. Go figure. So I am really trying to decide if I should go with the Denso that has had great success or try a NTK. Also I am debating on whether or not I should order a bung extension. I really think I am just cooking the shit out of them. But then again, when the Ucon shows up and I do all of this that should end too. I don't want to run a bung extension if I don't have too. Just in case it were to affect the readings.
  14. Jul 10, 2018 at 1:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Run a bung extension. Better safe than sorry.
    NTK Are oxygen sensors made by NGK. I cannot say one way or another that it will be compatible or work well with the system though.
  15. Jul 21, 2018 at 8:42 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Installed a denso 234-5116 on my innovate this morning. Lasted a solid 10 minutes before it started jumping like crazy. Then 20 minutes and it went E8. Just like the 3 Bosch sensors have. But I at least got a few weeks out of the Bosch. So? Bad guage and I have 4 sensors that will work with the AEM or Tanabe guage? Cause this is really pissing me off. Lol
  16. Jul 22, 2018 at 8:57 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You have a bad gauge which is exactly why I trashed my old Innovate AFR gauge. I was getting the same code. Those things are high failure rate junk. Get an AEM gauge, they are solid and imagine this THEY ACTUALLY PERFORM the function they were built to do. What a concept huh?! Hahaha.
    Use the Denso AFR sensor in conjunction with the AEM gauge. I promise you'll be happy.
    mr.trd[QUOTED] likes this.
  17. Aug 3, 2018 at 9:40 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Pretty sure the Denso sensors won't work with the Innovate MTX guage. Tried to re calibrate the Denso about 10 times while in MT. Never worked, always times out and goes to E8. So I just unplugged it. Got home and plugged in the Bosch and it calibrated right away. No matter, going to order a AEM x-series.
  18. Feb 17, 2019 at 2:37 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Great thread, about to use this reference guide to pull the trigger on some denso sensors for my AFR gauges.
    Curious how everyone else was able to tell that their bosch 4.9 sensors were bad? my gauges seem to be reading differently than what my UCon shows the stock sensors are at so i think my 4.9s are toast
    Mech_Eng, 12TRDTacoma[OP] and mr.trd like this.
  19. Mar 26, 2019 at 10:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There would be an error message or code number displayed on your gauge. For some, (myself included) the sensor is not limited to that and can begin to start taking highly highly erratic readings which will be all over the place in the rich to lean spectrum. That was my indicator that the sensor was craptastic.
    That and Bosch has a history of producing pure garbage sensors. Most of the local parts vendors and warehouses in my area refuse to carry and will not sell you a Bosch oxygen sensor because the defective/ return rate on them are so astronomically high that all parties involved in the sale and usage of the sensor typically lose nothing but time and money.
  20. Jun 21, 2019 at 11:15 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    So has anyone confirmed if one of these replacements will work an Innovative gauge?
