Bolts that require re-torquing: why not just thread lock?
Discussion in 'Technical Chat' started by Cannikin, May 21, 2020.
  1. May 21, 2020 at 8:52 PM
    Cannikin
    Cannikin [OP] Well-Known Member Vendor
    Rob
    San Marcos, CA
    2012 TRD Offroad
    I’m putting a u-bolt flip kit on my 2nd gen. The instructions say that the bolts require re-torquing after 50 and 500 miles. Is there a reason I can’t just put some threadlocker on them (blue or red) and skip the re-torquing?
  2. May 21, 2020 at 8:53 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    The new u bolts can “stretch” therefore come loose slightly even tho the bolt doesn’t turn. Slightest amount usually they just say retorque as a precaution. I’ve done many lifts and trucks that come back for a retorque never have loose bolts.
  3. May 21, 2020 at 8:55 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    1) Liability
    2) Safety
    Better safe than sorry.
    joeyv141 and suaveflooder like this.
  4. May 21, 2020 at 9:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There was a third gen who lost his rear axle because he didn’t re-torque. Some instructions exist for a reason.
    Hobbs likes this.
  5. May 21, 2020 at 9:11 PM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Yes. U-bolts will stretch. I've gone on trips through the Fordyce trail with my bro-in-law and watch him torque his u-bolts before the trip and after and he does get the slightest turn when off the trail.
    Jason TRD OR[QUOTED] likes this.
  6. May 21, 2020 at 9:19 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Always a guy knowing how to do it better that hasn't done it yet...
  7. May 21, 2020 at 9:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A lot a times it is recommended to recheck lug nut torque after so many miles.
    It usually depends on the wheel type and or manufacturer.
    I know when we bought our new utility trailer, it was required that you check the torque every 50 miles for the first 150. Then each 500 miles after. Yes, the first time we checked the lugs did turn slightly before the torque wrench “clicked”.
    I guess my point is, I’m not sure I’d want to run loctite on my lug nuts?
    That would not be too fun, while changing a flat on the side of the road.
  8. May 21, 2020 at 9:24 PM
    Bishop84
    Bishop84 Well-Known Member
    I've never had to retorque a ubolt but its a good idea.
    The big ones for me are the control arm bolts. Both upper and lower after major work I'll bring back in after alignment test drive and reef on them one more time.
    TnShooter likes this.
  9. May 21, 2020 at 9:32 PM
    tsab916
    Sacramento
    02 DC 4x4
    Ha, if your referring to me, I never mention I know how to do it better, I'm only explaining what I've seen and experience.
    CaptainBart45[QUOTED] likes this.
  10. May 22, 2020 at 1:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am sure he meant me!!
    CaptainBart45 likes this.
  11. May 22, 2020 at 1:32 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    This more then any other reason
  12. May 22, 2020 at 4:20 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I got a partial turn out of some of the u bolt nuts on both my dads 08 and my 04. Maybe 1000 miles after initial install. Would they have come apart? I doubt it, but Im glad I checked.
  13. May 22, 2020 at 7:10 PM
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Thanks for the replies! I didn't think about the u-bolts stretching! I thought the worry was the bolts would loosen themselves from vibration so I figured you could loctite those and problem solved! But if the bolts themselves get longer, that's a different story!
  14. May 22, 2020 at 7:44 PM
    CaptainBart45
    Bart
    Work in progress...
    U-bolts holding leaf springs together. You don't want to thread lock and be done with it. Let it find it's happy home and toqe it down. I was just joking about with the "always a guy knows best" crap. I am usually that guy...
    tsab916 likes this.
  15. May 25, 2020 at 12:46 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i will refer U 1st to ' ARP " for Ur edification
    they KNOW bolts .....fasteners ....... studs ETC!!!!!!!!
    years ago they published a table of a common bolt
    stud
    fastener
    from rods ..... heads etc
    Same size........SAME torque........SAME torque wrench
    using ALL fo the usual culprits in a typical garage
    WD40.......engine oil diff weights.......3n 1 oil.......polishing the threads
    several types o thread lockers
    ******* i have not been able to find that table
    After the designed their product & offered it.......... they may have deleted it
    some reduced the actual torque values dramatically
    subsequently ARP developed they own dedicated product
    essentially which was MORE consistent & gave reading closer to the desired values
    many MARQUES & racing teams assemble more DRY than most know
    When i say DRY there is a distinct abscence of chemicals / spray/ etc
    ive taken many an engine & vehicle apart & found NO evidence of thread lockers
    NO way U get the same torque !!!!!!!!!!!
    vibration & stretch are NOT the only or major concerns
    if the initial construct is OFF a direct result of lubricants .............questionable tools
    later after breakdown ...... teardown
    whichwver come 1st
    can lead 1 to believe a component failure when assembly was a factor
  16. May 25, 2020 at 12:47 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If thread locker is not called for then don’t use it, thread locker actually changes the torque spec.
