Bolt size for mounting Running Boards
Discussion in 'Technical Chat' started by Auroraboy, Nov 12, 2016.
  1. Nov 12, 2016 at 2:23 PM
    Auroraboy
    Auroraboy [OP] Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    Hoping someone can confirm the bolt size for mounting running boards in the factory mounting holes in the body. There are six holes per side, and each has a black plastic threaded plug in each hole in the 2017. I believe all generations of Tacomas are the same, but not 100% sure.
    I believe the correct bolt size is M8-1.25 x 20 (Metric 8mm nominal diameter - 1.25mm thread pitch (coarse thread) x 20mm length.
    Thank you
  2. Nov 13, 2016 at 7:43 PM
    Warles
    Warles Well-Known Member
    SoCal
    2015 Tacoma TRD,
    OME Suspension, Pelfreybilt bumper & skids
    I can't speak for a 2017, but on my 2015 they're M8-1.25...
    Auroraboy[OP] likes this.
  3. Sep 29, 2018 at 4:27 PM
    Grizzlee72
    Grizzlee72 New Member
    Life savers, just stopped in to grab some bolts for my son’s 2014 and they fit (thread wise) just bought a used set of running boards on a buy sell group.
    So the M8x1.25x20 should do the trick...
  4. Aug 19, 2022 at 2:38 PM
    SkinnyT
    SkinnyT Member
    I just picked up a set of side steps on FB for my 2016 and this post took all the guesswork out of finding the right bolts for getting them installed. Thanks!
  5. May 6, 2023 at 5:41 PM
    JAR in GA
    JAR in GA New Member
    2022 Tacoma Trail
    The correct bolt size for side railing is M6-1.0x25.
    I just replaced them all EIGHT and they are the correct size.
    Keep in mind they come with Locktite BLUE, so they will be hard to unscrew.
  6. Nov 2, 2023 at 11:25 AM
    tacomatrddave
    tacomatrddave Well-Known Member
    2023 Tacoma Access cab sr5 v6 4wd
    Sumo springs. Shocker air hitch.
    This bolt size is for gen 3? Can someone confirm? I just got a 2023 sr5 access cab 4wd. Took my tube steps off my 2016 to reuse. But the oem bolts were rusted well beyond usable.
