Bolt/nut size for driveshaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Jul 22, 2010.
  1. Jul 22, 2010 at 2:15 PM
    JKD
    JKD [OP] Well-Known Member
    I'd like to pick up a clawfoot adapter for my torque wrench so that I can complete the "torque driveshaft bolts" maintenance item on the standard maintenance list.
    If anyone happens to know the size, it would save me crawling under the truck when I get home this afternoon with a set of wrenches to check...
  2. Jul 22, 2010 at 2:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What bolts are you talking about?
    U-joint straps? Flange bolts?
    You should look them up on the online FSM's.
    Did you try calling a dealer?
  3. Jul 22, 2010 at 2:37 PM
    JKD
    Flange bolts.
    From past experience with dealers, calling them would just result in a half hour on hold and a "bring it in for service and we'll take care of it".
    I figured someone here would know it off the top of his/her head.
  4. Jul 22, 2010 at 2:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i cant remember for sure, but i think i used either a 13 or 14 mm wrench....or maybe a 1/2 or 9/16 wrench..............pretty sure its one of those.:eek:
  5. Jul 22, 2010 at 5:50 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Pretty sure its a 14mm...
  6. Sep 12, 2010 at 5:23 PM
    JKD
    Confirmed: 14 mm bolt and nut (four of them) attaching the driveshaft flange to the diff flange.
