Bolt heads rounded off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Oct 1, 2010.
  1. Oct 1, 2010 at 3:40 AM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Me and my brother were going to install my lift this weekend.
    We took off the front tires, and discovered that we could not get a single bolt off.
    We said fuck it, and decided that we were going to bring it to our friend who has a shop.
    When in the process of putting the drivers side tire back on... a wheel stud broke off.
    Fucking cheap Japanese shit
    So anyway... this bolt is completely rounded off. We can't get the brake caliper off so we can replace the broken stud.
    We can't even pull the brake caliper directly off with the brake line pinched. The brake caliper bolts were tightened retard strength tight.
    In the picture, the red highlighted bolt is 100% rounded off.
    Is this going to make it a costly repair?
  2. Oct 1, 2010 at 3:47 AM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Is that the one for the swaybar end link?
    I don't remember if the stud for the end link has a hex slot it it. If it does, shoot some liquid wrench on it and give it a go with a visegrip and hex key.
    If that doesn't work, you can dremel the nut down to the threads and split the nut.
    How'd it get stripped like that in the first place? Box end wrench and a hammer takes apart almost anything w/o damage, if you don't have an impact gun.
    btw...I've owned cheap japanese shit all my life. Never broken a wheel stud. Did you over torque?
  3. Oct 1, 2010 at 3:47 AM
    rab44
    rab44 Well-Known Member
    pa
    10 toy tacoma
    Were you using air tools if not that shit is hard to get off .
  4. Oct 1, 2010 at 4:07 AM
    BarefootBandit
    We stripped it just trying to remove it with a socket wrench.
    The wheel stud actually broke while using a torque wrench. I might just replace all the bolts with longer ones. The studs are way too short.
    Doesn't have a hex slot either. Probably going to end up having my friend do it at his shop. Either way it's time to buy an impact gun.
  5. Oct 1, 2010 at 6:15 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    most of the bolts on this cheap japanese shit are lock tighted into place to prevent them from moving from the factory this is why they are so hard to remove also you are useing wheel spacers, the directions for those spidertrax wheel spacers are to tighten to 80 foot lbs. there is no way that should have broken a wheel stud unless something was wrong with it. installing a wheel stud is not hard. it requires a lot of beating the crap out of it with a big hammer, also if your having a hard time removing the breaks try starting the truck sometimes this really helps.
  6. Oct 1, 2010 at 8:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Were you using the proper sized tools?
    The wheel stud probably broke because you have spacers.
  7. Oct 1, 2010 at 8:44 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    impact? you will just round them off with more speed and theatrics.
    did you use 6 pt sockets? i have never rounded off a nut that i could get at easy...ever. do you have cheapo tools? (no offense).
    that highlighted bolt is a non-issue. go and buy a $25 kit from sears..called a bolt out. it would come out easy. they work amazingly well.
  8. Oct 1, 2010 at 8:48 AM
    Janster
    Jandy
    Lancaster, PA
    I've used impacts on a lot of bolts and haven't rounded anything off.
    He's better off cutting the nut off and punching it out. No need to buy a kit.
  9. Oct 1, 2010 at 8:51 AM
    aficianado
    back to bone stock.
    that kit is priceless for anyone that wrenches. i keep it next to my vicegrips..for emergencies.
    isnt he highlighting the drop link nut? you want him to split it and remove it off the threads?
  10. Oct 1, 2010 at 8:53 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Cheap tools is my guess. Decent wrenches and sockets of the CORRECT size won't tear shit up. Shouldn't be too much drama to get a stripped nut off if you take your time.
  11. Oct 1, 2010 at 8:58 AM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    you need to find some one with a welder. weld a long tube to the rounded off head and then your set. just make sure the weld is solid and the tube won't break off.
    i've used this method more than once, although they were on small stripped bolts. but the concept is the same.
    your other option is to drill it out.
    before you start either, do soak it with penetrating lube for a while. also try the heat and cool method right before you weld it.
    those together should loosen it up.
  12. Oct 1, 2010 at 8:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the highlighted bolt is for the swaybar end link. the only way I got mine off was with a impact wrench, it spun fast enough to keep the whole unit turning. I first tried with a hand wrench and that was a no go...it would just free spin.
    For rounded out bolts I have used an angle grinder to grind to flat spots on the nut and then use a pair of vise grips to grip it and get it loose.
  13. Oct 1, 2010 at 9:03 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    The caliper bolts are held in place with lock-tight. Heat helps break that stuff free.
    As for the rounded-off heads, use the right size 6-point socket and you should never have that problem. You'll break the bolt before you round anything off.
  14. Oct 1, 2010 at 11:00 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yeah I wouldn't blame the cheap japanese shit. The bolt wouldn't round unless you were using the incorrect size socket.
    But a new replacement nut and split the old one. Just be damn careful not to over do it and damage the threads on the swaybar connector.
  15. Oct 1, 2010 at 4:37 PM
    boss1041
    boss1041 Well-Known Member
    chad
    valdosta, georgia
    07 dc 6 speed trd or, 95 auto
    lol krazie is the king of spliting nuts. jk man
  16. Oct 1, 2010 at 7:44 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    You're safe.
    You require nuts in order for them to be split. ;)
  17. Oct 1, 2010 at 8:01 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I've done all my brake work and suspension work on my rusty 2006 bolts and have never had an issue! Try spraying stuff with a generous amount of PB Blaster the day before, it helps alot! I agree with the other posters: quality tools and 12 point sockets will round off stuff faster too.
    Impact guns are nice, but hand tools are best for breaking a bolt free. Impact guns do not provide constant torque like your arms can, which is sometimes needed to pursuade a bolt loose.
    Also, in the pic, it looks like the sway bar link. There's a hex hole in the end of the bolt to hold the ball joint still while you loosen the nut. If you don't, the ball joint will just spin. If it's jacked up, I just replaced a sway bar link for $50 in parts and took 5 minutes to remove...simple.
  18. Oct 1, 2010 at 8:14 PM
    boss1041
    chad
    valdosta, georgia
    :facepalm: lol kinda left myself open for that one
  19. Oct 1, 2010 at 9:11 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Insert unlubricated comment into opening here...
    No shit hey? That would have been useful information to know when putting on my coilovers.
    I just jacked up one tire putting pressure on the link which held the ball joint firmly in place with the tension put on the swaybar.
  20. Oct 1, 2010 at 9:16 PM
    larryde09
    Larry
    Boston, MA
