Boise, Idaho trails
Discussion in 'North West' started by IdahoNomad, Dec 17, 2011.
  1. Dec 17, 2011 at 10:40 AM
    IdahoNomad
    IdahoNomad [OP] Member
    Sean
    Boise, ID
    '10 Double Cab TRD Off Road 4x4
    Took off the front mudflaps. CB Radio
    Just moved back to Boise, Idaho after a 5 year adventure with the US Army. Anyways looking for some trails in the Boise area. I did the Boise Ridge Road from Rocky Canyon to Bogus the other day and it was a lot of fun. Anyone have any other recommendations? I've heard of trails out in the Owyhees but have heard they can be a bit difficult, I also dont have anyone to go with so would rather keep it simple and safe. I drive a 2010 DC TRD Off Road bone stock and am looking for something on the easier side. Any suggestions?
  2. Dec 17, 2011 at 2:18 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I lived in mountain home for a year and a half and I would take the truck out every weekend. That's one of my favorite things about Idaho, open ranges!!!
  3. Dec 17, 2011 at 5:17 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    that thread sucks ass, nothing cool in there:spy:
    welcome back to boise! i just sold the 2wd and got a 4x4 so im also trying to find trails locally. i just talked to a guy i work with that off roads a lot, he had a built 4runner, now he has a 92 pre taco, but he was talking about 2 really fun trails off of bogus road, both on the right hand side. the ridge trail you did might be one of the ones he was talking about. i still have to find them, but he said one was around the 5000 ft mark, and one was up right after the tree line starts i believe. he said they were pretty fun and technical. he described them as " they dont look like something a truck should be on" and "lets just say its not something you would take your subaru outback down". also there is 8th street that gets pretty technical once you get further back, but i believe that is getting closed soon. idaho city is also another place to check out.
  4. Dec 18, 2011 at 8:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I was digging through my map collection the other day and found a great little book entitled "Idaho Byways". It contains quite a number of "scenic" drives, appropriate for a mostly stock vehicle with many of the drives being off-pavement.
    I just googled it and was surprised to find it is still in print. Check it out:
    http://www.amazon.com/Idaho-Byways-Backcountry-drives-family/dp/1889329010
  5. Jan 20, 2012 at 11:51 PM
    birdhuntintacoma
    birdhuntintacoma Well-Known Member
    Aaron
    Idaho
    2011 4x4 Reg. Cab
    duratrac 265/75/16 on 16X8 raceline renegades
    Is that Boise Ridge Road mellow enough for a beginner off-roader to go by his self? I always want to go out but hesitant without another truck/buddy.
  6. Jan 20, 2012 at 11:56 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    never go alone man
  7. Jan 21, 2012 at 10:38 AM
    IdahoNomad
    Sean
    Boise, ID
    birdhuntintacoma, I've done the Ridge Road by myself in better conditions, but I would definitely not suggest it now, with all the recent snow its gotten. I've been on it in years past with friends who had full size rigs and 36" super swampers and we almost got stuck. Another place that has some easy trails is the Owyhees but they also might be snowed in by this point.
  8. Jan 21, 2012 at 4:25 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    The upper section of trails (where boise ridge road is at) has alot of snow on them and i would not try them without good tires, aired down, and a friend with a nice long recovery strap.
  9. Jan 21, 2012 at 6:07 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    how do you know?
  10. Jan 21, 2012 at 6:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Both vehicles require similar levels of capable tires and off-roading experience. And in many circumstances, tow/yank straps are not adequate to the task. If either one of you had had a winch, you would not have gotten into the trouble you had. :cool:
  11. Jan 21, 2012 at 6:50 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I had very little trouble actually. however, I'm putting a lift on this coming weekend and will have a winch as soon as my bumper shows up.
  12. Feb 16, 2012 at 10:11 AM
    IdahoNomad
    Sean
    Boise, ID
    I'd be down for a drive soon, I leave the 28th of Feb for a 3 month hiking trip if anyone wants to try for a day trip before then.
  13. Feb 16, 2012 at 2:57 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Too bad you'll be gone in May... You could have convoyed with us down to Moab
  14. Feb 16, 2012 at 8:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm thinking the Magruder Corridor in August. :stirthepot:
    C'mon Ben, you don't want me to do it all by myself do ya? :eek:
    Worthy links:
    http://www.tacomaworld.com/forum/north-west/174613-idaho-eastern-wa-bs-thread.html
    http://www.tacomaworld.com/forum/north-west/67395-montana-taco-202.html
    http://www.tacomaworld.com/forum/north-west/200381-northwest-moab-2012-team.html
  15. Feb 16, 2012 at 8:42 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    sweet man, welcome to the site from boise! Great looking 4runner! What base are you at? i learned 8th street was closed the hard way, drove up there all excited for a little trip only to find the gate locked. Im not sure about ridge road, not sure how much of the snow is melted but sure wouldnt try that without a friend and some good recovery gear, pretty sure there is still a good amount of snow up there. I haven't been boarding in a while so im not quite sure. Im going to be putting on a lift and getting new tires all within a month so i am going to need to go test them out.:D Im quite possibly more of a noob at this than you are so its good. I just found the link a few days ago to this place that i didnt even know existed.
    http://www.riderplanet-usa.com/atv/trails/info/idaho_12700/ride_d803.htm
    i guess it says its closed for the season so im not really sure where else to go. hemingway butte? I know there is quite a bit of crawling at blacks creek but im not sure the range of difficulty and dont want to tear my truck up.
    dam right they will:cool:
  16. Feb 16, 2012 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What day does school start? I'll time it right. :cool:
  17. Feb 16, 2012 at 9:44 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    sounds good, i ride dirtbikes out at murphy at hemingway butte. whats lost trail like? how many decent wheeling trails are out there? only ripped through on a dirtbike so i never slowed down enough to spot good 4x4 trails.
  18. Feb 16, 2012 at 9:45 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    This post belongs....
    ....Here!
    Nice Runner I'm :jellydance: i've always wanted a runner
  19. Feb 16, 2012 at 9:52 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    where is this?
  20. Feb 16, 2012 at 10:01 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    those 2 videos are the same, didnt you say one was by murphy? i googled it and it was all the way up in northern idaho by the border
