Boiling water from 3rd Gen 400w bed outlet?
Discussion in 'Outdoors' started by Egbeem, Oct 1, 2022.
  1. Oct 1, 2022 at 6:01 PM
    Egbeem
    Egbeem [OP] Well-Known Member
    Iowa
    2022 Lunar Rock TRD Sport
    Does anyone use an electric hot plate or other device to boil water using the factory 400w outlet in the bed? I’m planning on potentially doing some truck camping in mild weather with some very basic necessities for a little getaway. Hoping I can get by using some type of hot plate to heat water for making coffee in a French press. It seems like most hot plates are rated for more watts but, would a ~500w plate on a low setting get the job done even if slowly?
  2. Oct 1, 2022 at 7:14 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    No, a 500W hot plate won’t work with a 400W outlet. It may work somewhat but would take a long time to heat to boiling if ever. Just get a single burner propane or butane stove and be done with it. The stove will be much more versatile, you can heat water and most everything else.
    TnShooter and IvanhoeTaco like this.
  3. Oct 1, 2022 at 7:19 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Buy a jet boil
    Taco 422, RedTruck and Tyler7544 like this.
  4. Oct 1, 2022 at 7:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    3.3A is all you get.
    It’s ok for charging batteries and stuff.
    Personally, I can’t say I’ve used mine more than 3 times.
  5. Oct 1, 2022 at 7:28 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It might work, depending on the hot plate low power setting being less than 400w
    That said, 400 watts is about 1/7th the power of a backpacking stove. You’ll need to be patient waiting for your coffee.
  6. Oct 3, 2022 at 2:16 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    JetBoil will get your water hot in about 100 seconds.
  7. Oct 4, 2022 at 9:36 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Another vote for Jetboil for quick heating; mine lives in the back of my truck even though they kinda suck to actually cook on (the newer models are supposedly more adjustable). Bonus is that you can get a French Press piece for it. Even one of the $15 Chinese stoves will work though.
    If you plan to actually cook meals a better option is a true camping stove (having two burners can be really nice) or one of the single burner butane stoves from the Asian grocery stores. Being able to brew a cup of coffee or tea on the side of the road is great, but being able to make an actual meal while camping is even better. :hungry:
