Boeshield T9 lubricant
Discussion in 'Product Reviews' started by Slimmjay, Jan 13, 2016.
  1. Jan 13, 2016 at 11:35 PM
    Slimmjay
    Slimmjay [OP] Un-known Member
    Seattle
    '15 DCSB Off-Road
    34's, Kings, SCS F5's.
    Disclosure: I don't work for Boeshield or Boeing.
    Just wanted to throw it out there for anyone with Uniball UCA's. I was using dry Teflon lube on my Camburg arms as was recommended by almost everyone I've talked to. I purchased my control arms used and they weren't all that well taken care of, the uniballs were very dirty and a small amount of surface corrosion was starting to show. I kept having to reapply every few days to stop the horrid squeaking/creaking and the Teflon lube would attract a lot of dirt and grime.
    Then I found this stuff, it's been over a month and a half since I just sprayed this to the top of the uniballs. Zero creaking since and the uniballs stay much cleaner than with the Teflon lube. I drive 50+ miles a day commuting in this lovely (rainy) Seattle weather for work and take plenty of trips up to the mountain passes so they definitely get used and abused.
    I just cleaned the uniballs and reapplied the T9 today since I had things apart to make some adjustment. The surface corrosion i had is all gone and all the surfaces in the Uniball assembly were very well lubricated. I just sprayed the T9 over everything then wiped everything down before it dried as per the instructions. Then just applied some more T9.
    Within a minute of spraying the T9 to the top of the uniballs I could see it seep all the way through down to the underside of the lower misalignment spacers. Much better penetration than the Teflon lubricant.
    I found it at a local ship supply store, but you can also get it at Www.boeshield.com.
    Anybody else have any experience with this stuff? So far it's been a godsend. I'm sure it would work great for any other exposed parts you want to keep lubricated.image.jpg
    GQ7227, Jared8907 and tinker_troy like this.
  2. Jan 14, 2016 at 1:38 AM
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    I've used T9 on camera equipment here in Hawaii. It works great. Another great product is this lube called Corrosion Block. I believe its available at West Marine. Corrosion Block has stopped rust and corrosion on our camera equipment for 6 seasons of "Lost". I've used it on my coilovers and rear shocks to clean off surface rust. Works wonders but I've never tried it on UCA uniballs.
  3. Feb 14, 2016 at 6:13 AM
    Ztextreme
    Ztextreme Well-Known Member
    Scott AFB
    2010 Tacoma DDl Sport
    Icon stage 1, wheelers aal, icons uca, wheelers superbumps, allpro flip kit, bora .75 spacers, mastercraft 265/70/17 mxt, frontrunner roof rack, relentless skids, bamf lca skids, Avid bumper guard,
    I have used it for 2 years on my uniball, every winter I spray and wipe my frame, all front suspension parts, shocks and coilovers, it's a 2010 and no signs of oxidation or rust, dries to a waxy finish that's dry to touch and doesn't collect a lot of dirt, better than fluid film imo. It also stopped all the noises I was having and lasts a really long time.
    I also used it on the wife's Nissan that had rust and it has prevented it from getting worse, also safe on all surfaces so I rub down my armor and fender liners, love this stuff
  4. Mar 17, 2016 at 6:36 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Interesting. I may have to grab some when I overhaul my UCAs in the near future. I've just been using the "dry" telfon they sell at bike stores and it attracts dirt like a magnet.
  5. Jul 19, 2017 at 6:59 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I've heard this stuff fixes squeaky leafs as well.
    Key-Rei likes this.
  6. Jul 25, 2017 at 8:01 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    It did for a little while but then the squeaks returned on my Dakars (~1 month). Fluid Film on the other hand has completely squashed all squeaks going on 6 months now. I soaked the replacement uniballs I installed in my UCAs with Boeshield and never had one squeak nor does it attract dust like the teflon dry lubes did. Highly recommend both products.
  7. Jul 25, 2017 at 8:04 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Got a link to the specific Fluid Film you used? Also, can you just spray this or the Boeshield directly on the uniball portion of an installed UCA?
  8. Jul 25, 2017 at 8:08 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes it does. blast it in there.
    KB Voodoo likes this.
  9. Jul 25, 2017 at 8:14 AM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    I've used Boeshield for years and have had good results, however after some time I noticed a small amount of "sludge" build so I decided to try other lubricants.
    I used it as an anti-corrosion lubricant on CNC machines so the lubricant was in contact with my coolant, this may explain the sludge build that I encountered.
    On any other applications it's been a god-sent lubricant.
    Here are my favorite lubricants:
    CRC-336
    Boeshield T-9
    Rustlick 606
    Ever since trying these I stay away from WD-40 :anonymous:
    Just an honest opinion as a machinist.
  10. Jul 25, 2017 at 8:14 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    http://www.fluid-film.com/ Lowe's is the most convenient place to buy it for me but they have their retailers on that website.
    I apply the Boeshield directly to the uniball and let it do it's thing. The fluid film would probably work it's way through and be fine but it's more viscous than Boeshield.
    Ever since buying FF/Boeshield I sneer at the can of WD-40 in my garage. It's great at cleaning off adhesive and plastidip but beyond that I have no use for it as a lubricant.
    boogie3478[QUOTED] likes this.
  11. Jul 25, 2017 at 8:16 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I've used it on bike chains, but there are other wax lubes that are easier to find around here for that. Wax lubes keep things cleaner and don't attract dirt and dust, but they need to be applied more often to friction surfaces. Does a great job protecting non-friction surfaces for longer periods of time. Just be sure to keep applying it so things don't run dry.
  12. Jul 25, 2017 at 4:17 PM
    Zwjense
    Zwjense Well-Known Member
    Just ordered a can of it to spray on my Fox coilovers and rear shocks. May use some on my Dakar's as well depending on whether or not they squeak once installed.
  13. Jul 27, 2017 at 8:36 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I'm considering using this soon to winterize my truck . I'm looking into either this or amsoil hdmp or fluid film to coat the entire frame and underside of the truck . I understand that it dries to waxy film which doesn't collect dust and dirt .
    Zwjense likes this.
  14. Jul 28, 2017 at 6:28 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Should work great. If I recall, it was invented for marine applications, like to spray on marine engines to protect them.
  15. Jul 28, 2017 at 6:29 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    You guys know if there is anything that Boeshield should NOT be sprayed on as far as suspension components, brakes, engine compartment is concerned??
  16. Jul 28, 2017 at 6:30 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I wouldn't get it on the rotors or pads, but it shouldn't hurt anything else.
  17. Jul 28, 2017 at 6:33 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Thanks, I was thinking the same thing. I want to hit my calipers/drums because those things get nasty quick.
  18. Jul 28, 2017 at 6:44 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    Boeshield is a non-acetone carrier that delivers parrafin wax. it's almost safe to eat.
    T-9 will not harm paint, plastic, rubber, fiberglass or vinyl. It can be used on engines, wiring and belts. T-9 is nonconductive and will not cause short circuits, so it’s also safe to use on electronics.
  19. Aug 12, 2017 at 4:12 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I use it on my mtn bike chain. Repels water and doesn't attract dirt. I imagine it would be great on our trucks.
    Rexfordian13, Zwjense and boogie3478 like this.
  20. Jan 16, 2018 at 9:44 AM
    T101993
    T101993 New Member
    2015 trd off road 4dr 4x4
    Awesome for garage doors too, i put it on all the hinge points , make um a lot quieter and stays on there for long time
