Body plugs (circular rubber) under carpet
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Feb 22, 2018.
  1. Feb 22, 2018 at 9:11 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    After I removed my seats yesterday and cleaned, I noticed 6 round rubber plugs (3 on each side of the front drivers/passengers floor mat area) I ordered 6 new ones from Toyota and I would like to now if I should just clean the area when I remove the old plugs and just reinsert the new plugs or should I coat the new plugs with silicone?
    Here's what they call them, but to me they are round rubber plugs
    90950-06119 (2) Cover Hole
    90950-01872 (4) Heat Shield Hole Plug
    90950-01086 (2) Plug Hole
  2. Feb 22, 2018 at 12:01 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    No need to coat them with silicon, but when you'll put them back, put grease around the edges to seal them properly and prevent rust from forming around the hole in the floor
    vettehigh[OP] likes this.
  3. Feb 22, 2018 at 12:22 PM
    vettehigh
    Jon
    Upstate, NY
    So basically clean around the hole above/below.....then insert plug.....then coat edges of rubber with grease?
  4. Feb 22, 2018 at 12:52 PM
    onakat
    Canada
    2000 indestructaco!
    You want to have grease between the sheet metal and the lips/edges of the plug, or else, rust can form between the plug and the sheetmetal
    Put grease around the edges of the plugs, then around the edge of the holes and then put the plug in. No need to put an enormous amount, just a dab of grease on both the plug and around the hole
    vettehigh[QUOTED][OP] likes this.
