Body Lift vs Suspension Lift
Discussion in 'Suspension' started by PreRunnerMan, Nov 2, 2014.
  1. Nov 2, 2014 at 10:17 AM
    PreRunnerMan
    PreRunnerMan [OP] Well-Known Member
    Alex
    SoCal, Whittier
    White 2010 PreRunner SR5
    ADS Coilovers LR UCAs Bilstein shocks in the rear Dakar Leaf Pack CMC 287/70/17 BFG K02s
    I know like the basics of the two lifts, but I was curious as to the pros and cons of both. I also would like to know what is involved with a body lift.
  2. Nov 2, 2014 at 10:26 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Body lift
    Pros: cheap
    Cons: a ton of spacers, stretched wires and steering and everything, very ugly. Lack of ground clearance. You will see through your truck between the frame and body.
    Suspension lift
    Pros: proper way to lift a truck. More ground clearance. Depending on type, more travel or better ride. Looks cooler. More respect from TWers haha
    Cons: More expensive. Also depending on type, lack of down travel or possible worse ride. Bad cv angles.
  3. Nov 2, 2014 at 12:24 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    a body lift is kind of a joke around here in the world of lifts. a body lift in my opinion should only be used AFTER a suspension lift in order to clear oversized tires. but to each his own.
  4. Nov 2, 2014 at 1:39 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Thanks. Ya I have seen body lifts and think they look shitty, but I was wondering as to why someone would ever get a body lift done.
  5. Nov 2, 2014 at 1:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For different reasons.....
    "Lift on a budget"
    I've done a 1" body lift on my jeep. That's the max I'd ever do. Why?
    We put taller shock towers in which gave us more up-travel. The extra uptravel was awesome but tires were rubbing in the fenders slightly. The 1" body lift was enough clearance to prevent the rubbing.
    I will tell you this....a friend/coworker owned a Jeep with a 3" body lift. He had told me about a time when he had to do an emergency panic stop on the highway to avoid an accident. His entire jeep body shifted off the pucks and slid forward. The body lift bolts /pucks broke under the pressure.
  6. Nov 2, 2014 at 5:45 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Thanks I appreciate the replies, are there any complications with a 6 in suspension lift? Like needing to replace the steering column or anything? Like I know the UCA's i should change but anything else?
  7. Nov 8, 2014 at 7:17 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    let me ask, I've looked for body lifts for a second gen, cheapest I've seen is about 180$ anybody seen cheaper ?
  8. Nov 9, 2014 at 2:14 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    You may run into problems with driveshafts and need to have a double cardon special made.
  9. Nov 9, 2014 at 2:49 PM
    vegenaut
    vegenaut Well-Known Member
    vegenaut
    Las Vegas, NV / Mountain Pass, CA
    '14 Reg Cab 4WD
    My previous tacoma, an 03 x cab, had a 6 inch DB lift and a few inches of body lift. That thing was up in the sky. I could sit under it indian style (which was AWESOME). Too bad it rode like crap :) The body lift was just to prevent tire rubbing.
  10. Nov 10, 2014 at 7:53 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Thanks for the response. That is nice to know.
  11. Nov 10, 2014 at 1:00 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Actually, with a 6" Drop bracket you will not have to replace the UCAs as it drops down the crossmember and retains stock angles on everything. I advise you not to drop bracket though. It makes you more top heavy, gives you less ground clearance than a 3", and (imo) looks gross too ;) . Additionally you get more extreme driveshaft angles which cause more strain on your U-Bolts
