Body control module location?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freshtacomaowner, Nov 23, 2018.
  1. Nov 23, 2018 at 3:13 PM
    freshtacomaowner
    freshtacomaowner [OP] Active Member
    Eric
    2007 Tacoma
    a few just starting out
    I am looking for body control module (Toyota may call something else), I assume it controls interior lights operated with door, it works well, then out of the clear blue it draws to much and kills battery overnight, I wanna unplug and confirm before I purchase one (typically not cheap and might be a dealer item only)
  2. Nov 23, 2018 at 6:10 PM
    Taco'09
    Taco'09 Well-Known Member
    Toy also call it the Body ECU but hides it.
    On your '07 if you remove the coin tray to the lower left of the steering wheel you will see JB No. 1 (Junction Box No. 1). On the reverse side of the junction box is the Body ECU. Its a bit of work to get to the thing, but not terrible, and it makes matters a bit easier to remove the lower dash panel first.
  3. Dec 7, 2018 at 4:35 PM
    freshtacomaowner
    Eric
    2007 Tacoma
    I originally was thinking body control module was my intermediate draw. I think I inadvertently while parked in my driveway with the keys and fob in a basket (not in my pocket) the 2007 Tacoma was locking and unlocking frequently, noticed the lights flashing, is the keyless controller separate of body control module, is it a dealer item only? It may also have a wire shorting out causing it to be engaged, does the 2007 Tacoma have an inherit problem I should check into before I replace wireless lock controller?
  4. Dec 7, 2018 at 4:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here:
    Matajramon likes this.
  5. Dec 7, 2018 at 5:49 PM
    freshtacomaowner
    Eric
    2007 Tacoma
    Thank you much JimmyH
