Body code?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LarryM04, Nov 15, 2014.
  1. Nov 15, 2014 at 3:44 PM
    LarryM04
    LarryM04 [OP] Well-Known Member
    Dayton, TN
    2014 BRM DCSB TRD Sport
    Amazon, nicely lets you set your vehicle so that it will show you just things that fit it. The first couple entries were easy, but then I got this:
    Mfr Body Code
    A Manufacturer Body Code, sometimes referred to as a chassis code, is a part number for the frame of the vehicle. The chassis of one vehicle may be used in other vehicles and over different year ranges.
    For example, the 2002 Honda Accord has six manufacturer body codes associated with it: CF8, CG1, CG2, CG3, CG5, and CG6.
    This code is generally marked or stamped on the vehicle. The location of the marking varies by manufacturer.
    Where is this "label" or, what is the code for a 2014 DCSB ?
    thanks!
  2. Nov 15, 2014 at 8:39 PM
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    I know in my old Honda the CG2 was a part of the VIN, i believe digits 2/3/4. Perhaps Toyota uses the same system?
  3. Nov 18, 2014 at 5:05 PM
    LarryM04
    Dayton, TN
    Bump
    Nobody knows where to find the body code?
  4. Feb 3, 2015 at 1:34 PM
    monkiboy
    monkiboy Well-Known Member
    did you ever figure this out? interested in what the chassis code is for my '15. thanks!
  5. Feb 3, 2015 at 1:43 PM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
  6. Feb 3, 2015 at 1:46 PM
    mdc1992
    mdc1992 Well-Known Member
    Matthew
    Waco TX
    2011 Black Access Cab. 2.7L 5 Speed
    Previous 2012 White DCSB 4.0L V6
    Its listed in your owners manual with the Trailer weight ratings. My 2012 dcsb 4x4 is GRN245
    DouginNC likes this.
  7. Feb 3, 2015 at 1:50 PM
    monkiboy
    thanks gents.
  8. Apr 16, 2017 at 8:55 AM
    tsteinhe
    tsteinhe New Member
    2014 Black Tacoma Limited
    The easiest way to find your Toyota vehicle's body code is by referring to the Certification Label along your driver's side door jamb. It will be the black and white sticker with the large horizontal barcode. Once you have identified the correct sticker, you can easily locate your Toyota vehicle's 7-character model code (a.k.a. "body code") in the line of text centered directly above the middle of that barcode. Hope that helps! Cheers!
  9. Jun 15, 2017 at 3:52 PM
    jokerj80
    jokerj80 Well-Known Member
    Jeremy
    O..H!!
    12 tacoma quad cab
    SS bull bar, K&N air filter, Pioneer avh8400, Kicker amp and sub, window tint, bug shield, T-Rex grille, Hella Ralleye 1000 behind grille, lund genesis bed cover
    So what is the body code for a 2012 trd sport 4x4 with tow package? I need it to purchase a primed rear bumper for my SR5. I hate chrome.
  10. Dec 24, 2021 at 7:20 PM
    rburke99
    rburke99 New Member
    2012 Single Cab Tacoma
    So I know this post was made forever ago, but if anyones still here... I decoded my VIN like the picture above said to & my MFR code isn't listed on Amazon... Am I dumb? Or is there a chance they don't have it listed
  11. Oct 3, 2024 at 2:38 PM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Color-matched Leer cap
    Amazon's software has some serious problems that emerge from time to time. Right now one such has surfaced.
  12. Oct 3, 2024 at 3:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    And you just kicked open a 3 yo thread. :goingcrazy:
  13. Oct 3, 2024 at 3:48 PM
    TDHofstetter
    TDHofstetter Member
    Tim
    Bradford, VT
    Not the first time I've Lazarused an ancient. :cheers:
