Bluetooth with rear camera, radio
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jules517, Oct 18, 2021.
  1. Oct 18, 2021 at 11:58 AM
    Jules517
    Jules517 [OP] New Member
    Julio
    2004 Toyota Tacoma Pre-runner
    Good Afternoon,
    Looking to change my 2004 original radio, would like to upgrade with a blue-tooth and rear camera.
    Is there a replacement without major wiring or major adaptation to the middle dash?
  2. Oct 18, 2021 at 12:02 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Welcome to TW! :hattip::wave:
    You can buy a Toyota-specific wiring harness that splices to the wiring harness of whatever brand HU you buy; At this point, the new unit will plug directly into your truck.
    You can also get dash bezel specific to your truck; I believe that 2001-2004 dashboards might be slightly different than 1995-1997 and 1998-2000 with regards to 1st Gens, but not by much.
    As for a backup camera, you make this this work by tapping directly into reverse light on your taillight or into the "reverse wire" on your gearshift. :)
    Taco critter likes this.
  3. Oct 18, 2021 at 12:18 PM
    Glamisman
    Glamisman Well-Known Member
    Crutchfield.com is a good place to start.
  4. Oct 21, 2021 at 10:28 PM
    tylerthompson21
    tylerthompson21 Well-Known Member
    Tyler
    2022 Taco TRD-OR
    Custom Hiatus Pop-Up Hard Sided Camper
    Second the Crutchfield recommendation. Its a great place to start your research, even if you buy it elsewhere. The vehicle specific wiring harnesses are awesome, make it all a lot easier.
    Hamer95USA likes this.
  5. Oct 23, 2021 at 9:04 PM
    Jeremy Martin
    Jeremy Martin Well-Known Member
    1st Gen Taco
    I just added a Sony double din with Bluetooth and a back up camera. One of the things I like about the Sony is that you can change the background color to orange match the rest of the orange lights in the dash so it looks as close to factory as possible.
    Derby27 and Hamer95USA like this.
  6. Nov 20, 2021 at 6:32 PM
    taco bout it
    taco bout it Well-Known Member
    Los Angeles, CA
    2003 DC Tacoma PreRunner V6 Limited TRD
    which one did you buy? is the backup camera wired or wireless?
  7. Nov 20, 2021 at 8:15 PM
    Jeremy Martin
    1st Gen Taco
    It’s an older Sony. XAv-AX1000
    The camera is wired.
  8. Nov 22, 2021 at 7:59 PM
    Jeremy Martin
    1st Gen Taco
    Also I should add that I choose that one because it still has a volume knob. I didn't want to have to mess with volume buttons or touch screen while driving a bumpy truck.
