Blown speakers or bad amp?
Discussion in 'Audio & Video' started by rondog, Nov 27, 2012.
  1. Nov 27, 2012 at 6:31 PM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    Today I notice my rear driver side speaker (It is an infinity reference) sounded all "crackly"..lots of distortion. I just figured it was time for a new speaker there.
    So I removed the door panel and took the speaker out. Turned the radio on and my rear passenger side is doing the same thing!
    I bought them at the same time..what are they chances they both go bad at the same time? What causes a speaker to have that distortion? What would be bad about the amp that could cause it?
    I didn't install the stereo system so the way it is hooked up, I am completely clueless.
    I have 4 infinity references and 2 tweeters up front. I have 2 10" JL sub woofers. I have two amps in my truck. I know one amp is for the speakers and one amp is for the two 10" subs.
    Any ideas :confused:
    also, everything is about 5 years old
  2. Nov 27, 2012 at 7:06 PM
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Yes its totally possible because im sure the rears are on the same channel on the amp. If you said it was one front and one rear i would say no but since its both rears its def. possible! If you had a spare speaker laying around you can just hook it up and see if its making the same noise. Unfortunatly thats your only option at this point.
  3. Nov 27, 2012 at 7:07 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Could also be bad rcas or bad rca input for the rear channel if its a 4 channel amp
  4. Nov 27, 2012 at 9:07 PM
    rondog
    Ronnie
    Escondido/San Diego
    It is a 4 channel amp and in fact my front passenger side is completely off now..the tweeter works however ahhh...I'm leaning towards bad amp..I'll see if I can find a spare speaker
  5. Nov 27, 2012 at 10:11 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What he said..heck, if you have house speakers you could even use one of those in your driveway just to check it out.
  6. Nov 27, 2012 at 10:16 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    The tweeter might now be hooked to the four channel amp but if it is then its not your amp bc the tweeter would have to be hooked up with one of the other sets of speakers....hmmm now you have me thinking......
  7. Nov 27, 2012 at 10:58 PM
    rondog
    Ronnie
    Escondido/San Diego
  8. Nov 27, 2012 at 11:24 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    And you are sure that all of this happened at once? Heres my best guess. The rear channel is bad or rca to the rear channel is bad and the front right speaker is bad or somehow came disconnected at the speaker or at the amp. Only way to figure out both problems is with a test speaker. Not a hard issue to track down and fix though.
  9. Nov 27, 2012 at 11:25 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Nice diagram btw ;)
  10. Nov 28, 2012 at 9:27 AM
    rondog
    Ronnie
    Escondido/San Diego
    haha thanks :p
    I am pretty certain this all happened within the last two weeks. I noticed my driver side rear was bad two weeks ago...a friend sitting in the back told me. He didn't mention the passenger side at the time but I can assure you it is now bad.
    I left out of town for thanksgiving last week, came back sunday and when I got into the truck it sounded like my front passenger was quieter than normal so I leaned over and could still hear it. I thought it was fine, but that was just the tweeter I was hearing.
    I'll get under my seat after work and check all the connection going into the amp. I am now leaning more towards the amp being bad considering 3 bad speakers within the past couple weeks.
  11. Nov 28, 2012 at 12:36 PM
    rondog
    Ronnie
    Escondido/San Diego
    Well I checked all the connectors to the amp and they're all firm and connected fine. What are the chances that the RCA cables themselves are bad? I found a speaker that I am going to use after work to replace one of the rears just to determine if its the speaker itself or the amp
  12. Nov 28, 2012 at 12:59 PM
    rondog
    Ronnie
    Escondido/San Diego
    !UPDATE!
    Ok so I plugged a computer desktop speaker into the connectors of the bad speaker to test if it was actually the speaker. I know these computer speakers work and same thing! It sounds all crunchy and distorted....sooo again, what are the chances it is the RCA cables and not the amp itself?
    I also just read online someone had the same symptoms and the fuse coming off the battery was bad. He said it was slightly deformed so I'm going to go check that real quick
  13. Nov 28, 2012 at 1:12 PM
    rondog
    Ronnie
    Escondido/San Diego
    ok so fingers crossed it is because of this 60A fuse! Looks bad to me. I have two and they are located between a capacitor and the two amps I have..in fact I am almost sure this is the reason. My subs have been working fine. Took this fuse out, turned the radio on and all I hear are subs now...
  14. Nov 28, 2012 at 1:53 PM
    rondog
    Ronnie
    Escondido/San Diego
    Didn't fix it :( dammit...so RCA cables are cheapest to test next but a bitch to run.. Maybe I can borrow an amp from a friend
  15. Nov 28, 2012 at 2:11 PM
    rondog
    Ronnie
    Escondido/San Diego
    You know what I noticed..when I turn the volume up and down I hear a clicking noise in the speakers...it's never done that before...maybe the deck is going bad :confused:
  16. Nov 29, 2012 at 7:52 PM
    rondog
    Ronnie
    Escondido/San Diego
    It was my head unit! Who woulda thought
  17. Nov 30, 2012 at 11:20 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Sorry for the lack of responses! So you confirmed it was the head unit? How did you figure it out? And I figured it was a signal issue but the head unit is usually the least likely option to be bad that's fairly rare hmmmm well I'm glad you fixed your issue! Troubleshooting can be a pain sometimes but there are only so many variables sometimes you just have to check them all!!
  18. Nov 30, 2012 at 11:26 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Btw man your truck is sickkkkk
  19. Nov 30, 2012 at 11:33 AM
    ABA180
    East Bridgewater MA
    It happened to me before, so I know it is rare but never out of the question..
  20. Nov 30, 2012 at 12:15 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    try twisting the rcas at the connection. if it is an old install, there may have been some corrosion forming. clean your connections(head unit side and amp side), reinstall and check for results. otherwise, try replacing the rcas.
    also, might want to check the integrity of the speaker connections at the amp and at the speakers as well.
    edit: at that note, might as well check your amp grounds, remote connection at the amp, battery connection, etc. check all of your physical connections' integrity. start out cheap before you start throwing parts at it
