Blown head gasket. How much is the truck worth?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taj90, Mar 24, 2018.
  1. Mar 24, 2018 at 7:12 PM
    taj90
    taj90 [OP] Member
    Tyler
    Encinitas
    2010 Tacoma DCLB 4x4
    I have a 2001 Tacoma 2wd extended cab. A head gasket popped and two mechanics say I need a new engine. How much could I sell the truck for as is?
  2. Mar 24, 2018 at 7:32 PM
    taj90
    taj90 [OP] Member
    Tyler
    Encinitas
    Has 196,xxx on it. Tires have about half tread on them. Interior is in good shape. What else would you like to know?
  3. Mar 24, 2018 at 7:42 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Really depends a lot on where you're at.
  4. Mar 24, 2018 at 8:04 PM
    taj90
    taj90 [OP] Member
    Tyler
    Encinitas
    San Diego
  5. Mar 24, 2018 at 8:06 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    You're in luck. Ground Zero for asking top money BUT it's prob. worth fixing then selling.
    It looks pretty good in photo. Gone are the days i could buy broken down 4R's and trucks for 500 bux.
  6. Mar 24, 2018 at 8:08 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Edit: NVM 2wd
    Running Board Man likes this.
  7. Mar 24, 2018 at 8:15 PM
    tony2018
    tony2018 Well-Known Member
    Sell the cap for 500-600, sell truck for 2k.
    cruxofthebisquit likes this.
  8. Mar 24, 2018 at 8:17 PM
    tony2018
    impossibro...
  9. Mar 24, 2018 at 8:22 PM
    tcjacado
    tcjacado Well-Known Member
    @Speed Freek May be your answer send him a pm and ask if it's worth fixing or not.
  10. Mar 24, 2018 at 8:25 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Hehe, I paid that for my '80 4WD Pickup a couple years back that was broken down at the time. Just needed a carburetor and new fuel lines but the guy didn't wanna mess with it! It's in great shape too surprisingly, most are beat to hell.
  11. Mar 25, 2018 at 5:39 PM
    1997tacomav6
    Denver
    Just fix the head gasket at 2k, it has plenty years left in it
  12. Mar 26, 2018 at 7:02 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Do you need a new motor, or a head gasket? You could pull the cylinder head in the driveway and put a new HG on. I would go ahead and redo the timing chain as well (you have half of it off when you pull the cylinder head). It is a pain in the ass to change (I pulled the motor completely).
    *Edit: If you are going to get rid of it, I would pull the cylinder head and replace the HG. I rebuilt mine at 197730. Bottom end looked fine. I wasted many months and $$$ rebuilding it (because I was in no rush), but I could have easily swapped the HG and Cylinder Head in a single day.
    1997tacomav6 likes this.
  13. Mar 26, 2018 at 7:36 AM
    tony2018
    There is a reason why he took it to someone, no time or no experience. Which is why the op is pondering whether it should be wise to pay that amt on an engine replacement or put it into another 1st gen.
    Most of us are sentimental to our 1st gen's therefore we'll keep it until the mighty lord or, to be respectful of different religions, their god decision to strike it down.
    2003Squirrel and 1997tacomav6 like this.
  14. Mar 26, 2018 at 9:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can get a jdm engine swapped in for $2k or find a local donor motor or just fix the head gasket. Your truck should fetch $5k when it's running again. W/o running engine probably $2k like others have mentioned.
  15. Mar 26, 2018 at 9:53 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Question: Why a new engine vs. a repair. Is the head or block cracked? Yes, 196K miles is a bit but if the only the gasket is bad or the head just needs machining, I would think you have many more good miles left on it. If the oil change interval has been good you could see 400K miles on it.
  16. Apr 16, 2018 at 12:49 PM
    taj90
    taj90 [OP] Member
    Tyler
    Encinitas
    I don't think the block is cracked but the mechanic said there is risk hurting the engine after the cracked head gasket gets repaired. I think I'm going to do a JDM swap and keep my truck alive!
    Thanks for the responses!
    Dalandser likes this.
  17. Apr 16, 2018 at 3:08 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The price and / or time into doing two head jobs would be the same or less than a simple engine swap, plus you can redo all the seals and clutch in one shot. Lower mileage engine with one bank I could see doing the repair, but since OP said he wanted to do both, that's at least the cost of a new long block.
    License2Ill likes this.
  18. Apr 17, 2018 at 4:55 PM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    OP, can you do the work yourself? I am assuming not but??? I did my 2rz head job, its not bad. OEM gaskets should be used and are pricey but even if the head needs resurfaced its not that expensive.
  19. Apr 17, 2018 at 7:22 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Those engines are known to crack the head. But a new head and install. Bottom end is solid I bet, unless it was run til it quit and melted the spark plug wires. Clean truck btw
  20. Apr 17, 2018 at 7:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP said he wants to pull both heads... that would put some serious hours into the job and you're right - there's a good chance he could find cracks in the valve seats. But he won't know that until he or someone else tears apart both heads. Found some in both of the heads from the bhg long block I tore down for fun...
