Blower Motor Power Connector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrandoGoodo, Jul 12, 2022.
  1. Jul 12, 2022 at 9:47 PM
    BrandoGoodo
    BrandoGoodo [OP] New Member
    2013 White Tacoma SR5
    Alright, I just recently replaced my blower motor resistor and enjoyed 4 days of glorious AC. On the 5th day, I was on my way home from work and the motor shut off completely, leaving me with instant regret, should've bought the motor and resistor at the same time. I have the motor on order but, I did a little more investigating and to my surprise, I found that the connector that supplies power to the motor is nice and toasty. I'm having a hard time finding a replacement connector that I can just splice in. Any help on replacement connectors would be greatly appreciated!IMG-7056.jpg
  2. Jul 12, 2022 at 9:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Jul 12, 2022 at 9:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I matched mine up from a mid 2000's Honda Accord in a junkyard, Toyota does sell the pigtail harness for the blower motor but it's the same junky kind of plastic, the Honda one was black and of a higher temp rating with larger conductors.
    I also packed it full of dielectric grease to insulate some of the heat off the plastic.
    jackn7 and TnShooter like this.
  4. Jul 12, 2022 at 9:55 PM
    BrandoGoodo
  5. Jul 12, 2022 at 9:56 PM
    BrandoGoodo
    Dielectric grease is such a good idea! I'll have to pick some up when I find a good replacement connector.
  6. Jul 12, 2022 at 10:01 PM
    TnShooter
    Deogee
    STOCK
    No, I wouldn’t use anything smaller than what it is now.
    Since you’ll be cutting it anyways, you cam measure what it is now.
    https://www.powerstream.com/Wire_Size.htm
    Raylo likes this.
  7. Jul 12, 2022 at 10:04 PM
    Key-Rei
    Key
    Florida
    Blower motor P/N was also superceded, they got a different one now that's more efficient and doesn't get nearly as hot at the plug if your motor is original it might not be a bad idea to pick a new one up from the dealer, they usually run between 75 and 130 bucks I think I got mine for 90.
    When I replaced my plug I didn't replace my motor (which was definitely original) until later when it started squeaking/chirping. After pulling it apart and cleaning it and relubricating it twice I got tired, brought the dealer the part number off the old one and they said the new one was a different number.
    TnShooter likes this.
  8. Jul 12, 2022 at 10:48 PM
    caribe makaira
    Caribbean, Puerto Rico
    TnShooter and Key-Rei like this.
  9. Jul 13, 2022 at 11:18 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    JGO and TnShooter like this.
  10. Jul 13, 2022 at 1:55 PM
    caribe makaira
    Corsa sells the terminals to avoid multiple crimps.
    Jimmyh[QUOTED] likes this.
  11. Jul 13, 2022 at 5:33 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Can't tell how many wires are on the connector in the photo - but the replacements look like 2 as expected. You could temporarily, or I'd consider permanently splicing and wire nutting the 12v leads to the motor. There will be no connector points to burn and not a big deal to replace the motor later.
  12. Jul 13, 2022 at 7:18 PM
    caribe makaira
    :smack:
    Jimmyh and jackn7 like this.
  13. Jul 14, 2022 at 11:48 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You could do that, but in order to wire nut the motor to the vehicle wires you would have to connect a set of wires to the male terminals on the motor as that plug goes directly into the motor housing.
    I wouldn't do it.
    JGO likes this.
  14. Jul 14, 2022 at 11:51 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Please, never use wire nuts in an automotive (or marine) application. Save them for use in your house.
    Jimmyh likes this.
  15. Jul 14, 2022 at 2:20 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    T
    Now that I see the motor I wouldn't do it either! I thought there were leads coming from the motor to a connector.
    Even at home I'll secure wire nuts with electrical tape and a wire tie. I agree for automotive/marine use there's the potential for them to become loose. Forget that idea.
  16. Jul 14, 2022 at 2:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I figured that is what you were thinking and why I posted the picture and explained it.
    :thumbsup:
    TnShooter and Stelcom66[QUOTED] like this.
  17. Jul 14, 2022 at 5:28 PM
    Stelcom66
    2007 2.7L 5MT 4WD
    As the saying goes - a picture is worth a thousand words... Good to see parts and electrical connectors seem to be available for gen 2 Tacomas - at least online. Something I'll have to get used to doing rather than buying local.
  18. Jul 14, 2022 at 9:52 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    My blower connector did the same thing. I cut the connector and wired directly to the connector in the blower housing, using, I believe, .187” female blade terminals.
