Blower Motor Fuse Location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beaudeen, Feb 3, 2022.
  1. Feb 3, 2022 at 6:44 AM
    beaudeen
    beaudeen [OP] Active Member
    Ontario, Canada
    2005 trd off road
    Blower motor died last night on All speeds. Is the fuse located under hood or in the cabin...?
    Asking as it's cold out there and planning my attack.
  2. Feb 3, 2022 at 7:18 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    50A fuse under the hood.
  3. Feb 3, 2022 at 7:46 AM
    beaudeen
    Ontario, Canada
    2005 trd off road
    Thanks for the reply....Forgot to do a google search proir to posting....
    ZMan2k2[QUOTED] likes this.
  4. Feb 3, 2022 at 8:01 AM
    beaudeen
    Ontario, Canada
    2005 trd off road
    A light tap on the blower motor and all is right in the world again....
    Connector is not burnt...ordered a new motor just in case as it is a 17 year old truck. $70 Amazon...no big deal.
  5. Sep 12, 2022 at 2:54 PM
    RnROffroad
    RnROffroad A mf’in Japanese Ranger!!!
    2007 TRD Offroad Prerunner
    Same thing happened to me, spent forever trying every possible fix and this was the solution all along. Thanks man, you saved me
  6. Sep 7, 2024 at 4:36 PM
    NTTaco
    NTTaco Member
    David
    2024 Bronze Oxide TRD Off-Road Double Cab; 2006 Red Tacoma PreRunner Double Cab
    2024: Stock (so far) | 2006: LED interior lights, in-dash double din Bluetooth/ DVD player screen
    Unbelievable. Replaced the resistor and still didn’t work. Came back to this forum and found this. “No way “ I thought. Went back outside, turned on the blower switch on high, gave the blower a moderate tap with a mallet and, voila. It works.
    Thanks, my man!
    volcomman and Fenwick1993 like this.
  7. Sep 8, 2024 at 8:55 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Take a close look at the connectors - the four-pin on the resistor and two-pin on the blower. It is likely that one or more of the pins have corrosion build up. Both of mine were bad. Many a time, simply removing and reconnecting the connectors will fix the problem, but only temporarily.
    Fenwick1993 likes this.
