Blower motor connector burnt!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarrosMoto, Nov 21, 2023.
  1. Nov 21, 2023 at 5:39 PM
    BarrosMoto
    BarrosMoto [OP] Member
    2009 toyota tacoma access cab trd offroad
    Hey guys I'm new to TW but in need of help to figure out what's going on with blower motor.
    To start its a 2009 taco (2nd gen) and can't figure out why my connector to my blower motor keeps burning. I have replaced the blower motor and connector 6-7 months ago due to the same issue. Where I had the blower motor completely sh!t the bed and the connector was smoking abunch. So the last week or so i noticed the blower motor made a squeaking noise when on but also cuts in and out. So I decided today to check out the connector to see if it was loose and that's when I noticed that the connector has been burnt again! I dont want to keep running the heat if its going to catch fire or somthing. Looking for all the help I could get since it is snowing where I am.
    Thanks
  2. Nov 21, 2023 at 5:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Hate to say it but unless your using OEM parts it's probably just shitty chinesium junk.
  3. Nov 21, 2023 at 5:49 PM
    Finbox
    Finbox Well-Known Member
    Tim
    15' access cab 4x4
    Taco 422 likes this.
  4. Nov 21, 2023 at 6:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That's for the resistor.
    The aftermarket pigtails you can buy for the blower itself is usually a smaller wire size.
    Which increases the chances of it happening again.
    AFAIK, No one makes a "good" aftermarket pigtail for the blower.
    You're stuck buying the connector and terminals individually building your own OEM pigtail.
    Jimmyh and Dm93 like this.
  5. Nov 21, 2023 at 6:34 PM
    Finbox
    Tim
    15' access cab 4x4
    But the resistor is part of the power feed circuit for the blower. So if the resistor has a problem it can effect the blower. I don't think bigger wires are the answer. Toyota engineered the circuit & wire sizes.
  6. Nov 21, 2023 at 7:01 PM
    TnShooter
    Deogee
    STOCK
    What I am saying is, If OP bought an aftermarket pigtail for the blower, It likely had a smaller diameter wire than the OE wire.
    For instance, just read the reviews on Amazon.
    https://www.amazon.com/Connector-Co...ma+blower+motor+pigtail&qid=1700621884&sr=8-3
    Again AFAIK, all the aftermarket pigtails are the same cheap low quality.
    I wish someone would make a good pigtail. It might be a decent gig for someone on TW if they wanted to buy all the parts and make a batch.
    joba27n and Dm93 like this.
  7. Nov 21, 2023 at 7:46 PM
    BarrosMoto
    I replaced the connector with an OEM one
  8. Nov 21, 2023 at 7:47 PM
    BarrosMoto
    How could I tell if the Resistor is bad?
  9. Nov 21, 2023 at 7:55 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    a) when a connector cooks, both side are compromised
    b) the initial heat that started the deggation comes from the resistor pack
  10. Nov 21, 2023 at 7:56 PM
    TnShooter
    Deogee
    STOCK
    Do you happen to have the part#?
    Or remember where you bought it?
  11. Nov 21, 2023 at 8:37 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Also where did you get the blower motor. Sometimes the motor drawing too much current causes issues with the connector and/or resistor.
    Also any water leaking into the blower area?
  12. Nov 21, 2023 at 8:42 PM
    BarrosMoto
    The blower motor is the only thing that's not OEM.
  13. Nov 21, 2023 at 8:45 PM
    TnShooter
    Deogee
    STOCK
  14. Nov 21, 2023 at 8:53 PM
    joba27n
    Nolan
    Alberta
  15. Nov 21, 2023 at 9:31 PM
    BarrosMoto
  16. Nov 21, 2023 at 9:32 PM
    BarrosMoto
    Should I get a OEM one?
  17. Nov 21, 2023 at 10:31 PM
    joba27n
    Nolan
    Alberta
    I would get either an oem one or known oe manufacter like denso, acdelco, delphi.
  18. Oct 21, 2024 at 9:26 AM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    Hi
    I can confirm the same issue. I built and replaced the connector for my climate control module after going through the original factory and a spliced factory connector. Not to mention 2 panels.
    this last time I also replaced the resistor, blower motor, and pigtail to the blower motor. I did buy the Toyota upgraded resistor (82141-04Q80 & 87138-04070) but failed to buy genuine Toyota pigtail to the blower.
    After a strong electrical fire smell my AC suddenly stopped working and upon investigation I found a totally trashed connector. See for yourself and never by the crap. Despite it being advertised as 12ga, it’s clearly not.
    https://www.amazon.com/dp/B07YXLJP18
    the replacement I put on today I can confirm was significantly thicker gauge wire and I don’t anticipate an issue from it.
    https://www.amazon.com/dp/B0B37K4TZ1
  19. Oct 21, 2024 at 11:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All that heat damage was due to a loose terminal that acted as a heater and the actual current would be reduced due to the increase in resistance.
    If it were an over current condition it would have blown the fuse and the damage would be the entire wire not just heat damage at the terminal and immediate area.
    Ohms Law cannot be avoided.
    Some basic info:
    https://www.electrical101.com/ohms-law.html
    ridefreak likes this.
  20. Oct 21, 2024 at 12:44 PM
    Perfuseme
    Rick
    I’d say the wire was just too small for the current at least. Ohm’s law still applies. Could be a loose connection too but I always pack new connections with di-electric to best my chances
