Blower fan keeps stopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dblasingame60, Aug 30, 2021.
  1. Aug 30, 2021 at 5:30 PM
    dblasingame60
    dblasingame60 [OP] New Member
    Donald
    2014 Tacoma
    I replaced the resistor for my blower motor and the plug for the blower motor. The plug had gotten hot, so I replaced it. Now it’s doing it again. The blower will start if I giggle the wires, but woo stop randomly.
  2. Aug 30, 2021 at 6:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If it works when you wiggle the wires you have a bad connection either where you spliced it or on one of the connectors.
    jpmorrisvb likes this.
  3. Aug 30, 2021 at 9:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the connector(s) at the resistor and motor are still good it may be the motor itself, like bad brushes. Sometimes you can disassemble the motor and clean them, or it may need to be replaced
  4. Aug 31, 2021 at 8:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Since you have replaced the resistor nd connector (four wire connector). Check the two wire connector on the motor it may also be burned and loose.
  5. Aug 31, 2021 at 8:29 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Dm93 and b_r_o like this.
