Blocking off Fresh Air Vent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billybob50, Nov 13, 2015.
  1. Nov 13, 2015 at 1:17 PM
    billybob50
    billybob50 [OP] Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    I got tired of smelling exhaust fumes in traffic. So I removed the wiper arms, and popped off the plastic molding that's located at the base of the windshield. Covered the fresh intake vent opening door with cardboard and filled the area with GREAT STUFF (insulated liquid foam) couldn't be happier! While I had the molding off I washed it and painted it black. get-attachment.jpg
    DonDonDon likes this.
  2. Nov 13, 2015 at 1:49 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    It's likely you will have issues with your defroster, among other things.
    themanbearpig012 and TegoTaco like this.
  3. Nov 13, 2015 at 1:50 PM
    Pigpen
    Northwest Montana
    You must not live in an area that gets humid.
  4. Nov 13, 2015 at 1:51 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
  5. Nov 13, 2015 at 1:51 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Can the ac/ heat pull air with this blocked?
  6. Nov 13, 2015 at 1:54 PM
    tb3625
    tb3625 Well-Known Member
    Tyler
    Ohio
    2013 Tacoma access sport
    Couldn't you have just rerouted it to pull air from the cab?
  7. Nov 13, 2015 at 1:54 PM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    Blocking off the fresh air inlet will cause your blower motor to overheat and eventually become noisy unless you leave the recycle on
  8. Nov 13, 2015 at 1:56 PM
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    Doesn't the recirc button do that?
  9. Nov 13, 2015 at 1:57 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Interesting. I get it. I've had the same hellish experience of breathing fumes while stuck in traffic for hours at a time. I just turn mine off and open the window.
    Your solution seems extreme to me. But if you spend all your time sitting in traffic I guess it works for you.
    Let us know if you notice any issues develop. I think you can run the defroster and AC fine on recirc. No fresh air required.
    Did you know a healthy adult farts 14-30 times a day? Yes, so that might be a consideration to keep in the back of your mind as a reason against recirc air. Also, I see you have a dog that apparently rides in your cab? That might also be another reason against recirc air.
    billybob50[OP] and tinker_troy like this.
  10. Nov 13, 2015 at 2:17 PM
    billybob50
    Bob
    On the older cars you never had a choice of recirculation or fresh air option. I've always drove around with the a/c on, and if my dogs dislike the smell of my farts! I'll roll the windows down! LOL! 11165296_443779012449625_7554719918065010509_n.jpg
    Knudsen likes this.
  11. Nov 13, 2015 at 2:24 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    This guy must be trolling.
  12. Nov 13, 2015 at 2:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes it does. And then you can push a button and open it to outside air when needed.
    matt 157 likes this.
  13. Nov 13, 2015 at 3:27 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Wow just Wow...:confused:
  14. Nov 13, 2015 at 3:31 PM
    Iamraiderpower
    the OCD in me makes me want to trim that smooth and flush with the opening! Im about to die looking at the bubbly expansion :eek:
    rhion82, Colchicine, MadDaddy and 7 others like this.
  15. Nov 13, 2015 at 4:08 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Won't have to worry about leaves getting into the cabin air filter. That's a plus.
    billybob50[OP] likes this.
  16. Nov 13, 2015 at 4:29 PM
    billybob50
    Bob
    Yea, I noticed that when I changed the cabin filter every year, was amazed of all the amount of dirt and leaves. The fumes is what got to me, I was so upset about smelling the fumes all the time, it was either try sealing it or sell it!
  17. Nov 13, 2015 at 4:36 PM
    Fitz235
    Rob
    New Hampshire
    Why not just use recirc?
  18. Nov 13, 2015 at 5:14 PM
    billybob50
    Bob
    Even if you have it set on recirculation. It's still pulling in a small percentage of fresh outside air. Haven't you ever pulled up behind an old oil burning car and smelled the fumes?
  19. Nov 13, 2015 at 5:21 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That means your recirc setting is bad I would just fix that instead of clogging the air intake but hey +1 for creativity. :D
  20. Nov 14, 2015 at 5:31 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    I've noticed this with our Tacoma. My old Honda Accord doesn't have this problem on recirc. Going to buy a charcoal filter next time.
    I would've attempted a fix that was a bit more reversible. Maybe some sort of cover.
