Block Heater vs oil pan heater....or neither
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wyotaco06, Nov 4, 2010.
  1. Nov 4, 2010 at 2:23 PM
    wyotaco06
    wyotaco06 [OP] Well-Known Member
    Offroad 4x4 06
    I live in North Western Wyoming, and the winters here get pretty harsh. Temps like -20 are not uncommon, but around 0 degrees seems to be the norm in the morning...and I have to start up around 5am. Thinking of getting the stock plug in block heater that is easily installed in the V6, and found one locally for 45 bucks.
    Is this a waste of money in these temps? Is heating the coolant with this block heater better than a standard oil pan heater which heats the oil? Just looking to give the truck a break this winter, and I want my engine to last a long time.
    Any info or experience with these heaters is appreciated!!!!
  2. Nov 4, 2010 at 2:30 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I just installed one of these block heaters in mine yesterday. Haven't really noticed anything different yet.
  3. Nov 4, 2010 at 3:28 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    Take it from Alaskans a block heater Is awesome
  4. Nov 4, 2010 at 8:21 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I live in the CO mountains and I am also thinking of adding a block heater...
  5. Nov 4, 2010 at 8:30 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Block heater, no question. Block heaters heat the entire engine slowly and from the inside out and can be left plugged in for long periods of time -overnight. Pan heaters only heat the oil which will then cool down rather quickly once its cycled through the cold engine and should only be plugged in for short intervals (according to a mechanic friend). I've had both on vehicles in the past and definitely saw better results with the block heater. It still amazes me that they're not considered standard equipment in areas like ours!
  6. Nov 4, 2010 at 8:32 PM
    mserino
    mserino Member
    Thunder Bay Ontario
    05 Tacoma TRD Sport Stock
    Block heaters work well... but make sure you have the plug on a timer so you dont pay a ton in electricity! i use mine every day in the winter up here in thunder bay ontario canada -40 and up to -60 degrees celcius with wind chill (our vehicles come standard with them)
  7. Nov 4, 2010 at 8:35 PM
    MTgirl
    Weesa
    Lucky! Adding a block heater was the first 'mod' I did to my truck. Not sure how the previous owner survived without one for so long. But I do only use mine a few times a year, I have a garage to park in so that keeps the truck happy through most of the winter. When it gets below 0 though I have mine plugged in for at least a few hours.
  8. Nov 5, 2010 at 2:59 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I bought my truck in Calgary, and it came with a block heater already installed. Now living in Ontario (winters can get to -25 easily) I use the block heater every cold night, and it makes a noticeable difference. I'd recommend it in your cold climate.
  9. Nov 5, 2010 at 6:56 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    negotiated one in on my sale. without question, a block heater is the way to go.
  10. Nov 5, 2010 at 7:42 AM
    wyotaco06
    Offroad 4x4 06
    Thanks for the replies, I am definately getting it next time I go to town! Never really thought about how oil pan heaters heat up the oil ok, then when cycled through a bone cold engine it would most likely return pretty cold....plus the plug in block heater looks so easy and effective! Will also be nice to have a semi warm pickup quicker on those cold mornings.
    Thanks
  11. Nov 5, 2010 at 10:30 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I loved the block heater on my F250 6.9. I would get in and the truck would start right up and the heater blew nice warm air.
  12. Nov 5, 2010 at 11:05 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thread hijack but do you guys have front grill covers. I want my truck to heat up faster so I was thinking about adding cover on the grill to slow down air.
    Not so much hijack anymore but is there are different heaters (wattage wise) ?
  13. Nov 5, 2010 at 11:19 AM
    canadiancon
    canadiancon Member
    Tom
    Whistler, Canada
    05 trd
    Stock
    get both, you can have a pan heater plugged in all night. If you have a block heater and an oil pan heater it will be less stress on the engine when you go to start your truck due to the oil being able to flow better. I live in northern Canada, i have used both on all my vehicles.
  14. Nov 5, 2010 at 11:32 AM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    I don't think this will help much because until the engine is warmed up, the thermostat is closed and the rad isn't providing any cooling effect anyway.
  15. Nov 5, 2010 at 4:57 PM
    08WhiteTRD
    Ben
    Rocklin, NorCal
    Had a pretty cold morning today so I plugged my truck in after I got up. It was in for about 2 hours and when I started it I noticed a huge difference from when I didn't have one. If you are in a cold place these are a must.
  16. Nov 5, 2010 at 4:59 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    link to these heaters.....
  17. Nov 5, 2010 at 8:11 PM
    08WhiteTRD
    Ben
    Rocklin, NorCal
    I got mine from the dealership. It was 70 dollars from them.
  18. Nov 5, 2010 at 8:17 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    I'm in Winnemucca NV, not quite as cold as WY but it can still get down there. The Taco 4.0 block heater is only 400 watts; you won't notice much difference in time to get warm air. I have one, and will probably get an oil pan heater soon. The heater in my old F-250 diesel was either 1000 or 1500 watts- it would blow luke warm air on start-up!!! Toyota really blew it on this one IMO; it should have been closer to 800 watts.
  19. Nov 5, 2010 at 8:43 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    Are these freeze plug heaters? or in hose heaters.
  20. Dec 1, 2010 at 3:12 PM
    wyotaco06
    Offroad 4x4 06
    Got my block heater at dealer in Boise for 37 bucks and installed in less than 30 minutes, no raising the truck or taking off tires. Plugged it in the other night when it got below zero and it definately helped starting the truck!! Really glad I got this...
