Blinkers/Emergency Flashers only blink once
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hunt365, Dec 5, 2020.
  1. Dec 5, 2020 at 9:01 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    Hey yall, new to the forum, couldn't find any specific info for a 2017 Tacoma. All my turn signals and hazards quit working. They blink once and then that is it, and wont even blink once sometimes. Can't find any info on relay existence or location. Headlights work, brake lights work. Any input would be MUCH appreciated. Thanks
  2. Dec 5, 2020 at 9:14 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Just a complete shot in the dark, but does your truck factory spec bulbs?
    Chew and Junkhead like this.
  3. Dec 5, 2020 at 9:21 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    Yes, my truck is complete factory. Only mods are one size bigger tires and a camper shell.
    Junkhead and shakerhood like this.
  4. Dec 5, 2020 at 1:10 PM
    caribe makaira
    Caribbean, Puerto Rico
    The turn flasher relay is integrated into the combination meter...not a separate item to be removed n replaced.
    mtip, jmneill, Chew and 1 other person like this.
  5. Dec 5, 2020 at 1:35 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Sounds like too much resistance. You don't have led bulbs in the turn circuit and added resistors? Are you the original owner?
    Chew likes this.
  6. Dec 5, 2020 at 2:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Does your shell have a light?
    The reason we are asking all these questions is a completely stick vehicle does not have electrical problems. 99.99% of electrical issues are caused by mods.
    jmneill, Chew and shakerhood like this.
  7. Dec 6, 2020 at 5:05 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    hiPSI, it does have a light. The shell has been on my truck for 4 years with no issues, but I suppose it is worth looking in to! Shouldn't be hard to eliminate it as a culprit.
    I am the original owner as well.
  8. Dec 6, 2020 at 5:07 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    I am not familiar with a combination meter? Doesnt sound like something i could just investigate?
  9. Dec 6, 2020 at 5:14 AM
    caribe makaira
    jmneill likes this.
  10. Dec 6, 2020 at 5:24 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    Oh hell, so it's the whole instrument cluster? Everything else in the truck is acting normal. So I'll start with disconnecting my camper shell wiring. After that, idk what I will chase if it doesnt work.
  11. Dec 6, 2020 at 9:45 AM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    You’re right! The chassis T harness to power my shell lights got a little melted spot and shorted out. Removed it from the factory harness and the flashers all work. Much appreciated all!!
  12. Dec 6, 2020 at 9:47 AM
    shakerhood
    Southern Ohio
    Glad you found the culprit
    hiPSI likes this.
  13. Dec 6, 2020 at 11:02 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    That's curious that it's been installed for so long and just went bad. Were you able to locate the short that caused the harness to melt?
    hiPSI and caribe makaira like this.
  14. Dec 6, 2020 at 1:18 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    thanks for letting us know, way too many people ask for help on this forum and then dont respond as to what actually fixed the problem. Glad you got it fixed...
  15. Dec 6, 2020 at 1:26 PM
    hunt365
    hunt365 [OP] Member
    Southern, IN
    Apparently LEER had a recall on harnesses. I never got contacted. It finally got enough heat built up and failed
  16. Dec 6, 2020 at 2:12 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Electrical mods usually work... or not.
    However I have been around long enough to see a wire take years to rub through or potted controls degrade. But most of the time it's a add on or a mod. OEM automakers test for years to get wiring correct because of liability.
